View Full Version : TH400 crossmember
cp72ss
04-09-2009, 01:01 PM
Sorry if this is in the wrong section. But im looking for help with a transmission Crossmember. I am running a TH400 with a gearvendors O/D in a 72 SS Chevelle. Its a BBC with a 12 bolt. I have the stock crossmember but obviously with the Gearvendors its not fitting correctly. Any one have suggestions. Modify the one if have?. Have a tube crossmember built? If so, any suggestions on who can do that?
Thanks for any suggestions
Chris
jfaria78
04-09-2009, 03:47 PM
what kind of car is it? I used a stock th400 crossmember with the same setup and it worked fine...
cp72ss
04-09-2009, 09:03 PM
Hello, it is a 72 SS Chevelle that I put a BB into. I am using the stock cross memeber which came from the orig th400. ( My car is an orig 350/th400 car). I purchased a street strip Hughes Tranny and added a GV overdrive. and for some reason the Cross member is not lining up.
thanks for any suggestions.
Chris
jfaria78
04-10-2009, 01:54 PM
do you have it the right way meaning have you flipped it around, you can put it both ways the trans tab facing the front or the rear.
67 caprice
04-10-2009, 03:06 PM
I have a turbo 400, GV in the Caprice. I had to cut and fabricate the transmission brace for the GV to fit. It's all worth it. I think I have some pictures, I look for them and upload later.
cp72ss
04-10-2009, 09:48 PM
Excellent. If you happen to have any pictures that would be very helpful.
Again thanks for anyhelp. I love to get this running soon:-)
67 caprice
04-13-2009, 03:48 PM
Sorry, I looked on the computer @ the warehouse, but was not able to find the pictures of the cross member.
I have a 68 442 on the lift now no motor. "It's a pusher" The motor goes in next week and I well see if I can snap a few pic's for you.
I did find something on the net, it look similar to what i did, and it's for a 68 Chevelle. Hope it helps.
http://www.popularhotrodding.com/features/0809phr_1968_chevrolet_chevelle_ss/turbo_400.html
(http://www.popularhotrodding.com/features/0809phr_1968_chevrolet_chevelle_ss/turbo_400.html)
