Results 1 to 15 of 15
Thread: Early Chevy Truck Frames
04-08-2009 #1
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
I'm considering a 47 - 66 Chevy truck for my next project. If I did it, I would probably want to do an aftermarket frame or at least a decent suspension setup (no MII). What is out there today for aftermarket frames in the pro-touring theme for these trucks. I really like the 47 - 54 and 63 - 66 trucks.
04-08-2009 #2I'm working on a 49 Chevy right now. What I can figure out is there are three ways to go. Modify the stock chassis if it is good enough. An aftermarket chassis. Or a frame swap like an S-10. The stock frame is nice because you don't have to relocate cab mounts or running board mounts. You can weld all the new stuff right on. An aftermarket chassis would be slick if you afford it, but most lean more towards a street rod style build. I'm using a longbed S-10 chassis in my truck. It works good for me because it was really cheap. The front suspension is the same as a G Body Monte Carlo. I'm changing the rear suspension to a set of truck arms, but you can do whatever you want in the back. Really there is no wrong way to build your truck. Just figure out the balance between labor and money. I have to support my wife and daughter so I plan on doing all the labor. If I won the lottery I would send a deposit to a shop and wait on the beach for updates
04-09-2009 #3
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
The S-10 idea has a lot of upsides. Even if I won the lottery, I'd do most of the work my self, I would buy more expensive parts like a twin turbo LSX. I'm still researching. There seem to be a lot of options for modifying the old frame that don't cost much. I'm looking for a pro-touring build (I'm an autocrosser) so if G body parts work on an S-10, that may be the way to go. I saw a company that sells the bolt on body mounts for an S-10 frame.
04-09-2009 #4I saw the companies that are building the mounts also, I just went ahead and built my own though. Its really not that hard. The later body style that you mentioned would be cool to work on because the 2wd front crossmember is the same until the late 80's. There is a huge aftermarket support for those trucks.
04-09-2009 #5The 63-66 truck frame is a pretty good setup as is. If you notch the back for axle clearance and then box the frame, you should be good to go. That should get you down to a more aggressive stance. The long truck arms are still being used today, check out the underside of NASCAR's.
If you want to bag it, check out air ride. They have a complete set up.
I went with CPP and happy with my set up. I was not trying to turn the truck into a G Machine. I just wanted a better lower ride to cruise around town in and it fit the bill for me.Rick
" Better to Be Lucky than Good "
04-09-2009 #6
