BSER
04-02-2009, 05:50 PM
The brakes are bled and the power steering works fine. The problem is that as soon as I press the brakes the engine stalls, I even increased the idle just for grins and it still died.
I have checked all the lines and they are all routed properly, with this kit you really can't plumb it wrong since each fitting is different. I have the return line Teed into the power steering return line, an option is to drill and tap a hole in the reservior and plumb the return line direct but I don't see how this would make a difference.
It seems there is a large load being placed on the power steering pump. Like there is to much preesure building up and engine is working harder and harder as pressure builds until the engine stalls.
I have been building this Elcky for over a year and this is the last item before I get the alignment done and get to finally drive it. But no brakes no drive any help would be appreciated.
