View Full Version : Closeout panels for minitub??
nkopper
03-14-2005, 07:19 AM
I got my passenger side floor cut for the minitub, now I have a question about the closeout panels for the shock tower. The DSE instructions seem a little vague and the video doesn't really show this as clear as I would like.
In these pics, it looks like a 3/4 inch flange was bent down and not much of the original metal inside the tower was removed: http://www.detroitspeed.com/ThompsonPage0110.html
http://www.detroitspeed.com/ScottsPage10.html
In this pic, using the current DSE instructions, it looks like the shock tower was gutted, the closeouts became the flange, and the floor was actually cut 2.75" inboard and no flange was left: http://www.superchevy-web.com/tech/0409sc_minitub/
So, where I'm getting confused is where the DSE instructions say that the actual cut line is 3/4" outboard of a line drawn 2.75" inboard of the original mounting surface of the inner housing. If I understand correctly, the actual cuts on the shock tower need to be 2.75" inboard and that area, along with the section of frame that is cut out, will not have a 3/4" flange to bend down, thus the frame closeouts will also become the flange that the Deep Tub is welded to. Is that correct?
Nathan
baz67
03-14-2005, 08:02 AM
Does this help? Have you checked at Lateral-G? Scott has pics of his mini-tub install.
Brian
nkopper
03-14-2005, 08:29 AM
Yea, I've studies those pics several times along with the others. From these shots, it looks like there was no flange folded down on the shock tower: http://www.lateral-g.net/adams/minitub/SAdams-045.jpg
http://www.lateral-g.net/adams/minitub/SAdams-049.jpg
Nathan
907rs
03-14-2005, 08:55 AM
Nathan, I haven't seen any two done the same way. When mine was done, I cut out what was necassary to fit the tubs, then made my own closeouts. The flange isn't necessary if you can plugweld the tub to the close out panel.
Here's a shot of my driver side.
kamaroman68
03-14-2005, 10:04 AM
I'm actually in the process of doing this also. Without actual measurements on where to make the cut into the framerail I'm a little leary. If anyone else out there can help I'd gladly post pictures so I can get moving again. Then again if there is anyone out there from NY that has done this mod please come to my house and give me a hand. Chris
nkopper
03-14-2005, 12:07 PM
Brian, that's the pic I've been looking for. I will probably try to leave some of the original metal inside the shock tower and fold a flange down like you did.
I agree, it seems that there are a few different ways that the closeouts can be handled. Knowing that the flange is not necessarily needed helps alot.
Thanks!
Nathan
Ralph LoGrasso
03-14-2005, 12:12 PM
Nathan,
When I mini-tubbed my car, I made a flange at the shock towers, (a better flange was done on the passenger side since I did that side second, and had a better grasp of the process beforehand). My flanges looked almost identical to Brian's. I made all my own closeouts, as I think it's easiest this way. For what it's worth, I spoke with Kyle before doing my mini-tubs, and he said to make a flange where ever possible.
Chris,
Where in NY are you located? I'm in Smithtown, Long Island, and I've mini-tubbed my '68.
Camaro Zach
03-14-2005, 03:25 PM
i didnt leave any flange hanging on mine because im welding my tubs directly to the floor all the way around with no real "spot" welds. www.cardomain.com/id/43zach there you can see all the progress pics so far
03-14-2005, 11:57 PM
Flange or not to flange.....
It really depends on the sheetmetal your working with. Flanging will provide a spot for rust to hide so seal it up good. I like to over size the close outs and weld the tubs to that. Spot ever 1 1/2" then sealer.
kamaroman68
03-15-2005, 05:59 AM
Ralph I'm in Niagara Falls Chris
2fast4u
05-30-2005, 08:27 AM
Nathan, great question I had the same question myself as I'm in the process of installing a dse mini-tub on my 67 Firebird Convertible.
Now my question guys is do I Remove the factory close-outs on the side of the shocktower to get a little more flang in that area(currently there is only 1/4" of metal sticking off it) as my 2.75 line is just over it(1/2" inboard)?? Or do I add my close-outs over the factory closeouts?
Thanks, chris
68protouring454
05-30-2005, 08:33 AM
just cut the 2.75 line all the way, fold down flange on front half, rear half will begin with closeout then be plug welded to frame rail all the way back
cutting the line will make it apparent where closeouts are needed
jake
