View Full Version : '73 Nova Door hinges...
cornerblade
03-31-2009, 11:21 PM
Anyone know where a good place is to get some door hinges for my Nova? I already replaced the hinge pines but the hole is egged out way larger than the bushing. Also will a '68-'72 door fit a '73?
jmisbpd
04-01-2009, 06:17 AM
Hey, I have a set of hinges upper and lower hinges for the left side but I can only find the upper hinge for the right side. Still in original packaging, aftermarket parts that I never used. I have a 73 Nova and these will suit your needs, please email me if you're interested, I was just about to put them on Ebay. Located in North NJ.
[email protected].
Joe
NovaPwr
04-01-2009, 03:09 PM
If the hole is not egged out too badly, you can drill out both holes, and install the much heavier door bushings and hinge pins from the 73+ full size Chevy trucks. An old bodyshop guy showed me that back in the 80's. I did mine on the 72 couple of years back, can't remember the correct drill size but you could just mic the new pin.
manicmechanic
04-01-2009, 04:17 PM
You can also weld up the holes and redrill them.
cornerblade
04-01-2009, 04:38 PM
Yeah on the driver side, upper, the hole is real bad. I thought about drilling it out and welding a steel bushing in place and just using a long bolt or other pin.
cornerblade
04-01-2009, 04:39 PM
anyone know about the door fitment of a 68-72 on the '73?
NovaPwr
04-01-2009, 05:00 PM
I think they should interchange, I have seen 68-72's with 73 doors on before.
cornerblade
04-01-2009, 09:41 PM
jmisbpd, I e-mailed you regarding the hinges, def. interested.
