View Full Version : ram jet 350 upgrades
6T86SPD
03-13-2005, 06:07 PM
I just got a ram jet 350 installed in my camaro and was wondering what are upgrades you can do to the motor aside from supercharger or turbo? ANd with what upgrades will i have to get the computer re-programed?
P.S. I am a newbie so if this was already a subject dont flip.
gen3bu
03-13-2005, 07:41 PM
lt4 hot cam, afr heads, stroker kit, ls1 nos plate kit. re-program the pcm anyway, you will see an improvement.
hotrod
03-14-2005, 08:38 PM
Is there software to reprogram these guys? I didn't think there was. Most of the posts I've seen have been recomending that you replace the whole pcm and harness. It would be cool if there was something out there. Mine is a MEFI3.
JMarsa
03-16-2005, 07:31 AM
Is your controler the Mericruiser one or the next gen (what's being supplied now with the ramjet)?
--JMarsa
67rsconvert
03-16-2005, 09:07 AM
I was told you need the newest 4th gen computer to make modifications. The 3rd gen doesn't have a means to be modified I was told. You may have to change over to the newest generation computer to have any luck if yours is an older( I believe 1 year or older) ramjet.
EFI69Cam
03-16-2005, 03:05 PM
I have software to re program the MEFI3s I used one to run my 468 until I got a Accel gen 7. The MEFI4 is similar to a 3, but adds coil on plug output, ls1 sensor input, and I think fan and charcoal cannister controls.
I will be using my MEFI3 to run a TPI 350 in my K5, its a decent ECM, for factory combos, but sucks for large cams.
If you want an EFI engine that you are going to leave alone, the Ram Jets are a good buy, but if you want to modify the engine the aftermarket tune on the fly ECMs are the way to go. Accel, Speed Pro and Big Stuff are all good choices.
Scoggin Dickey has some really good prices on EFI crate motors that use aftermarket ECMs.
Reckn8
03-17-2005, 04:01 PM
Well, one thing that I can say about the ram jet is that if you are going to be using a decent cam and a head that flows at all, you need to have the ram-jet manifold sent out and get it extrude honed. I sent mine out and went from flowing 215 at the runners to flowing 270 at the runners. I will try and get the dyno sheet posted tomorrow but the numbers on my 383 Ram-Jet with a GM hot cam, ported fastburn heads, and extrude honed intake, are 434rwhp and 503rwt. The car was dyno tuned at Arizona Speed and Marine.
hotrod
03-17-2005, 06:08 PM
EFI69Cam, where did you get your software and what is it? Can you do any real time recording with it? Does anyone have a program that will? Mine is the MEFI3 but I would like to add closed loop.
67nogo
04-28-2005, 08:52 PM
Hey you say you have the software, is it available? and if so how much and what hardware is required, thanks a lot.
Rusty
70ss
11-10-2005, 06:40 PM
I have a copy of the software available for $2500. Mefi 1-4 It works very well even with large cams.
yody
11-12-2005, 07:58 PM
Ah,you must be the one sitting next to me at the dinner? Now i recognize your user name :cool:
PhillipM
11-14-2005, 03:42 PM
Yeah that was us sitting at your table. The reckn8 is now my dads login because it got to confusing with both of us using the same login. -Phillip
PhillipM
11-14-2005, 03:44 PM
Anybody looking for a tuner of MEFI 4 should also look at UMI ( I think that was their name) in Scottsdale AZ. Scott Urschel and Todd Peterson over there are extremly fluent in tuning these computers.
CarlC
11-16-2005, 04:57 PM
Were the flowbench numbers with the throttle body in place? Does the factory supplied TB become restrictive with the new enhanced flowrates?
PhillipM
11-17-2005, 11:21 AM
To answer you question, no, the throttle body was not in place during the flow numbers. However, originally the throttle body was bigger than the intake so we marked exactly where the intake was smaller because it was really only on the top and bottom. The other areas were all flush. We then just port matched the TB to the intake.
