View Full Version : Line Lock kit recommendations?
1969CamaroRS
03-29-2009, 09:01 PM
Who makes a good line lock kit? Hurst? Moroso? Any suggestions or experiences with different kits would be welcome. Would be going into a 69 Camaro.
Thanks in advance!
NOT A TA
03-30-2009, 05:51 AM
I've had Hurst kits with no problems.
racecrafter
04-10-2009, 11:01 AM
I have run most of the common brands at one time or another....no real difference. but you might want to invest in a brake pressure gage to go with it.
minendrews68
04-10-2009, 05:17 PM
I have the Hurst version, no problems..
MonzaRacer
04-14-2009, 06:07 PM
Hurst and rebuildable too, I still have my old one!
1969CamaroRS
04-14-2009, 07:08 PM
Hurst seems the clear favorite.
andrewb70
04-14-2009, 07:16 PM
I've had great luck with these solinoids:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SBR-LL&N=700+301367+115&autoview=sku
It comes bare, which is just fine, because I always end up using my own wiring, switch, and indicator lamp.
Skip Fix
04-15-2009, 08:12 AM
The Summit brand side by side looks identical to the Hurst.
Rallye455
04-24-2009, 02:04 PM
Never had a problem with the Hurst.
Bryce
04-24-2009, 02:12 PM
i have a summit one, it works good and good price.
buds87gn
04-24-2009, 03:21 PM
Hurst... all the way, i knew someone who had a solinoid fail a mile or so from his house, lets just say that the flat spots on his front tire from the ride home made for a bumpy ride...
MarkM66
04-26-2009, 06:21 AM
So when they fail then lock the brakes up?
69dragracer
05-03-2009, 06:49 PM
I have used both the Hurst and the Jegs brand, no problems with either one.
1969CamaroRS
05-03-2009, 06:52 PM
Thanks for all the suggestions, ended up ordering a Hurst unit from Summit.
65BBODY
05-04-2009, 04:21 PM
Well since you got that one, now is the time to post a video of you using the thing!!
How did your install go? I bought a LL and did not end up putting it in cause it was a little too over my head.
1969CamaroRS
05-04-2009, 04:53 PM
I won't get the piece until tomorrow. Hopefully later this week or next it should go in. I'll post pics then, still a bit aways from being able to demo the thing (still have a few things + electrical to do).
1969CamaroRS
05-16-2009, 05:38 AM
Here is some pics of the line-lock installed:
https://static1.pt-content.com/images/pt/2009/05/EngineInstall087-1.jpg
https://static1.pt-content.com/images/pt/2009/05/EngineInstall085-1.jpg
Still have some minor adjustment shortening of the brake lines to get them away from the headers a bit.
Bracket is made out of 1/8" thick steel that was polished and then powder coated clear. My first time trying the clear and I guess the heat discolored the clear or the steel a bit, now has a bronze tint to it, but actually looks very interesting.
Skip Fix
05-17-2009, 07:18 AM
Slick bracket!!
mnm99
05-31-2009, 04:49 PM
B+M here
