View Full Version : New member with a 1968 firebird
lsb
03-29-2009, 06:04 AM
Need a new subframe!
1971CHEVELLE
03-29-2009, 07:04 AM
Welcome to the site
Pzary3233
04-02-2009, 06:47 AM
Welcome Fellow Bird owner!
I know of a couple in the Memphis Area if you need one!
Steve Firebird
04-02-2009, 10:55 AM
Welcome. Check out speedtech it looks like they just came out with a pretty nice one for the money unless you need a new old frame if so they do come up for sale on the site once once in a while. 1968 Firebirds rock! Good luck. Steve
Ralph LoGrasso
04-02-2009, 01:23 PM
Welcome to the site. Lots of options as far as subframes...
6'9"Witha69
04-02-2009, 01:32 PM
Welocmeto the site.
68Formula
04-02-2009, 01:57 PM
Use the search function (Suspension section) and research thoroughly before you buy. Some subs correct the inherent geometery flaws, which is the most important factor. Others just look prettier, but don't address negative camber gain, caster adjustment, or bump steer (tubular arms, coil over shocks, and rack and pinion doesn't necessarily mean a much better handling system).
Rag-Rat
04-02-2009, 02:53 PM
Are you looking for a GM or aftermarket subframe. Detroit Speed & Engineering is in your town. Have you tried them?
