Results 1 to 20 of 28
03-22-2009 #1
- Join Date
- Jun 2006
- Posts
- 26
Ride Height, Suspension Geometry and Tire "Squish"?
I would like to know how how you account for tire "squish" when all of the weight (of the finished car) is on the tires. I thought this dimension might be negligible but I measured my daily driver and came up with 1 1/2 inches of difference on a 28 inch diameter tire (distance from ground to center of wheel = 12 1/2 inches). That is significant, big time.
I see a lot of people on here and other forums laying out suspension geometry. I have always seen this done as though the tire has no "squish". This makes the assumption that the centerline of the spindle is centered on the tire.
In my example above, that would be completely wrong. The centerline would actually be 1 1/2 inches lower at ride height! The suspension geometry would be COMPLETELY different from what had been calculated!
So, can someone tell me if this number is published by the tire manufactures or if it is ignored by builders or if anyone has any information about this or?
03-22-2009 #2I'm not sure how that "squish" would have an effect on geometry. The suspension components are all going to be at the same angles regardless. The only thing that can change is the ground clearance and possibly the rake of the vehicle (from the front squishing more than the rear.)
One other thing to keep in mind is tire pressure. Most OEMs use lower pressure for better ride, while sacrificing some handling. Add more pressure and you will decrease squish.Jason Scheer
03-22-2009 #3
- Join Date
- Jun 2006
- Posts
- 26
If you maintain the same ground clearance that you planned on when you designed the suspension, and now the centerline of the wheels is 1 inch lower, there is going to be a major effect on geometry.
If you reduce ground clearace to keep your geometry, now your calculations are wrong (because you used the wrong ride height). Also, if you could get by with 1 inch less ground clearance, you probably should have done that when you laid out the suspension. After all, you want to minimize ground clearance to reduce CG.
03-22-2009 #4
