The Stickman
03-20-2009, 10:57 AM
Ok peoples here's the deal. I am putting on a set of Boss 304 wheels with BFG G-Force Sport tires. I know that the rear tires will be 275/40-18. My problems are that my car seems to me to create an optical illussion and makes the rear tires look smaller than the fronts when the tires are the same size. Now part 2 of my post which coinsides with the tire issue deals with spacers. The clearances are tight and I think i need them but advice is appreciated. Ok lets start with the first pics.
https://static1.pt-content.com/images/pt/2009/03/100_3136-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3137-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3138-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3139-1.jpg
Ok all the pics above are with 275/40-18s front and rear with a 1.5 inch spacer in the rear because there is about a 1/2 inch clearance on the inside of the wheel well if a spacer is not used. There is also a 1 inch spacer on the front as the wheel is about touching the swaybar if a spacer is not used. The bracket that the brake line/hose connects at is close by about an inch or less. Also by spacing out the rear wheels it seems to help with the optical illusion.
https://static1.pt-content.com/images/pt/2009/03/100_3142-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3145-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3146-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3148-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3150-1.jpg
Now the pics above are with 275/40-18's and a 1.5 inch spacer on the rear and no spacer on the front. As said before the wheel and rim are within a few slices of paper of the swaybar at full lock. They do seem to have more clearance around the wheelwell though as with a spacer the tire touches the plastic fender liner at full lock. So my questions are should I run 275/40-18's on the front or go with something smaller. I like the 275/40's because for one they are cheaper than the other smaller tires and as they are on sale at Tirerack. Who wouldn't want bigger tires on their car at a lower price? The other question is should I run the 1 inch spacer on the front or can I get away with not running it? Thanx so much for any and all opinions.
