View Full Version : Decode a 4l80e
critter
03-18-2009, 06:33 PM
Is there a site or can someone tell me how to decode a 4l80e's tag? I know what I have is an earlier model because it has the rib up the top of the bell housing and does not have the 12 o'clock hole.
A second question, are there any weak spots to fix before install. This is going behind a Pontiac 462ci motor making a bit over 400 hp and 500 ft. lb. of torque.
OK, third question, best converter for the money out there for said transmission?
MJ_Bone
03-19-2009, 08:35 AM
I'm pretty sure the first number on the tag indicates when it was manufactured. Cooler fittings together up front indicates early style. The newer style(97+?) has cooler fittings separated.
critter
03-19-2009, 10:13 AM
Thanks. I forgot to bring the numbers with me to work so I'll have to look when I get back home. I'm wanting to say it was a 3. I do know it's an early transmission based on the cooler fittings and other items I mentioned.
critter
03-19-2009, 03:45 PM
I'm beginning to think this is a Goodwrench service replacement transmission. The numbers on the tag are:
13TRP
97-346 193123
I see a cast number of:
24204250 and 7
Anyone out there have an idea what I'm up against here?
Steve Chryssos
03-20-2009, 04:20 AM
I'll post up numbers off a 4l80 trans here for comparison.
critter
03-20-2009, 04:33 AM
I'd sure appreciate it. Thank you.
Steve Chryssos
03-21-2009, 05:09 AM
Sorry I ran out of time yesterday. And I'm still trying to get caught up on orders today. I'll try again later or Monday. I won't forget.
critter
03-21-2009, 04:05 PM
No rush from me. I'm grateful for the help.
MJ_Bone
03-22-2009, 02:10 PM
I can tell it's a 97 transmission. And 24204250 is the part number for the early style GM case (Google).
FWIW, I'm pretty sure that Goodwrench puts their own tag on them when they rebuild/remanufacture them.
critter
03-22-2009, 03:08 PM
Thanks. I should have googled that part number.
So, good, bad, OK? I'm not a monster motor. It's a Pontiac 462ci with about 425hp and 500 ft. lbs.
critter
03-23-2009, 01:45 PM
And after getting some time to research it via the internet today I am convinced it is the earlier case design because of the location of the cooling line ports. Thanks for steering me in the right direction MJ.
