View Full Version : small hole patch
69projectKAOS
03-18-2009, 11:10 AM
i saw another member on here that had small holes in his floor and he used a liquid metal to patch them??? it was something like pd-15 or something! it was silver in color and he placed duct tape on the bottom of the hole and applied this to the top and it sealed the holes and made them solid! i have a few in my trunk that i wanna fix and i was wondering if anyone knew what the name was and where i can get it! or something like this that will work. thanks-dom
vp23271
03-18-2009, 11:11 AM
POR-15
http://www.por15.com/
69projectKAOS
03-18-2009, 01:50 PM
thats it! but which kit do i buy??? the 2 part top coat called whitecote seems like it will do the trick, am i right? thanks
Restomod
03-18-2009, 03:53 PM
Heck I have used JB Weld for small holes, worked good.
dhutton
03-18-2009, 04:47 PM
Here is the thread:
https://www.pro-touring.com/forum/showthread.php?t=48361&page=3
69projectKAOS
03-18-2009, 05:45 PM
thanks guys! that was the thread i saw it on! thats gunna be tomorrows project thanks again -dom
Damn True
03-18-2009, 11:13 PM
Have you thought about getting a hunk of copper to back it with and just welding it up?
minendrews68
03-19-2009, 05:22 AM
X2 what he said.....:)
jackfrost
03-19-2009, 09:47 AM
if the holes are from rust the metal will be too thin to weld.
ask me how I know. :razz:
Damn True
03-19-2009, 10:06 AM
If it's from rust he's going to have to grind away all corroded material prior to the proposed band-aid patch. If you are going that far you might as well cut out the cancer and patch it.
cheapthrillz
03-19-2009, 12:14 PM
If the hole is from rust and you just por-15 it, it wont stop the rusting, and it will continue. I would patch it back with good steel. Hell, if you're going to do it, do it right!
69projectKAOS
03-19-2009, 01:55 PM
well its in the trunk so i think im just going to replace the inner section because i found a coupe of spots that looked like they were on their last legs as it is. and i am installing a roll cage so i need the floors to be strong so in the long run it would definitely be worth it
minendrews68
03-20-2009, 05:35 AM
If it's in the center section of the trunk floor, for no more than it would cost I would just buy a replacement section and replace the whole thing....
