View Full Version : Tuning trouble with a BS3... ideas?
davepl
03-17-2009, 05:48 PM
I have a BS3 with 85# Siemens injectors on a ZZ502 with a Hogan sheet metal intake.
The issue I'm having is that the O2 sensor from the BS3 does not agree with the in-dash (wideband). You can tell something truly is wrong, because I have to set the idle fuel cell down to 11% VE to stop it from pulling fuel.
With one arrangement, I get the following:
BS3: avg 14.7 InDash: avg 12.5
If I switch the connectors (they're compatible sensors):
BS3: avg 13.5 InDash: avg 15.5
So clearly one side is reading far leaner than the other. I went around the intake mating surface with a propane torch (unlit but open) hoping to see a change in AF ratio somewhere, but didn't.
I'm guessing it has to be an intake or exhaust leak, but am sort of at a loss on how to narrow it down without just redoing everything.
Any sage-like wisdom on what to look for and how to test it would be very welcome!
Dave
GetMore
03-18-2009, 04:29 PM
Also make sure you don't have a misfire. Typically a misfire throws off the O2. I think it's a lean misfire that'll show up as being rich, I think it also works the other way.
