View Full Version : Anywebsites out there?
Brandon Miller
03-11-2005, 09:38 AM
Looking for a website that has an engine displacement calculator but requires you to enter the rod lenght as well as bore, stroke, # of cylinders, etc. All the one I'm finding are just asking for stroke, bore, and cylinder #.
sunkistcamaro
03-11-2005, 10:22 AM
Will this work?
http://kb-silvolite.com/calc.php?action=comp
edit: Opps, guess not... I read your post to fast
GT350Clone
03-11-2005, 12:07 PM
Ummm, because rod length does not impact displacement... Therefore, it's not part of the formula to calculate it.
Going back to geometry class, the volume of a cylinder is:
Radius * Radius * Pi * (stroke)length.
A V8 has 8 cylinders, so take the above result *8 to get total displacement.. :cool:
Brandon Miller
03-11-2005, 08:03 PM
I'm aware of that but I have seen a program before that actually used rod length as well.
79T/Aman
03-11-2005, 08:35 PM
can't be, as rod length does not affect engine size.
03-11-2005, 09:40 PM
You can use all of those and just factor in rod length to figure out compression height. Is that what your after?
