Socrates
03-15-2009, 07:20 PM
Hello hello,
I'm working on a 66 GTO. I've read a few interesting postings regarding re-drilling a new hole for the rear upper control arm mount, placing the new hole .75" or so lower then the factory location. This reportedly has the same effect as the edelbrock/lakeside no hop bars on suspension geometry with the well discussed gains had therein for missile-like launches. This makes sense to me, though I'd still like to know: Has anyone here actually done this who could provide pictures or at least moral support?
I would be using the 66 GTO boxed-in factory uppers for this with rubber bushings initially and would set the location of the hole forward or back a bit to also set the pinion angle more favorable at around -2.5deg. I'd use the edelbrock adjustable uppers with the johnny joint in the future if I can't get the pinion angle where it needs to be, though if I can accomplish the same task that $400 in shiny parts do with just $10 in drill bits or at worse a little welding, I think I'd rather spend the $400 on... :idea: some different shiny parts! Any thoughts or suggestions?
Additionally, to describe the lower control arm and suspension situation, I have a 1" UMI rear sway bar and tubular lower rear arms with an adjustable QA1 joint that are waiting to go in asap. I'll install Eibach 1" lowering springs as soon as I roll back the fenderwells to fit the wheels/tires I'm running. The car suffers from destructive wheel hop and hopefully these mods/parts will help a bit with this, while also improving handling dramatically over the current open stamped factory arms, worn bushings and no anti-sway bar. If the rear UCA relocation doesn't pan out I can always go back to the factory hole with my tail between my legs, right :D
