View Full Version : Can I use the EGR port for my brake booster?
crazyfireman
03-12-2009, 04:38 PM
I am trying to find a place to hook up my brake booster, the Holley Dominator doesnt seem to have any vac hookups, can I use the EGR place by the dist??
shmoov69
03-12-2009, 08:08 PM
I don't know what intake, but I use a 3/8 plug at the back of the intake under the carb for a vacum source, even if I have to drill and tap it
crazyfireman
03-13-2009, 04:46 AM
it is a B&M supercharger intake
GetMore
03-13-2009, 08:47 AM
You may need to install a spacer between the carb and the supercharger.
crazyfireman
03-15-2009, 01:06 PM
So I cant use the port in back by the dist where the EGR valve goes? I am not running a EGR
MonzaRacer
03-15-2009, 01:31 PM
yes you can just make sure you have the exhaust port blocked good and the vacuum properly connected as this aera can get some extra heat. Tread carefully it will work fine.
crazyfireman
03-15-2009, 04:41 PM
Which one is exhaust??
crazyfireman
03-16-2009, 04:59 AM
Figured it out, Thanks Monzaracer
