View Full Version : BMW wheels or Corvette Wheels?
LONE*STAR
03-12-2009, 04:32 PM
I've been looking at wheels for my stock disc/drum 67 firebird. $900.00 is about my max. I've been looking around on ebay for c6 corvette repo's and bmw aftermarket tuner wheels.
My questions are as follows.
1) For the 18"-19"C6 reproductions about how much of a spacer will I end up with? Not exact just need an idea.
Specs-19 x 10" - 65mm / 18 x 8.5" - 46mm
2) For bmw wheels I am seeing like 20-25mm front and 30-35mm rear for 8.5 and 9.5 inch wheels respectively. Again about how much spacer is usally needed.
What are your guys recommendations and any idea's here I would prefer 18/19 and pretty much know 245mm front and 275 rear is pushing it with stock tubs.:)
dhutton
03-12-2009, 04:40 PM
This calculator will let you convert those offsets to backspacing:
http://www.rims-n-tires.com/info_specs
Lots of info around for backspacing, search the forum and you will find it. I read that Firebird rear ends are an inch wider so Camaro backspacing needs to be adjusted by a half inch.
C6 wheels will require thick spacers, around 2 inches or so if I remember correctly. BMW wheels often fit without spacers if they are the 5/7 series wheels.
DriverzInc
03-12-2009, 04:52 PM
If they are 8.5s with a 20mm offset, that is a 5.5" backspace, and you might need to run a .25" spacer.
If they are 9.5s with a 30mm offset, that is a 6.5"(ish actually 6.43") backspace and you'll need a .5" spacer. Just to give you an idea. Hope that helps.
LONE*STAR
03-12-2009, 05:27 PM
Thanks alot guys. I feel a lot better. I think after I get my car back this weekend I might just order me up some wheels.
LONE*STAR
03-12-2009, 05:43 PM
What is the best offset for a 19x10/19x8.5 on the same car... that way I can just use the Calculator dhutton recommended thanks guys
LONE*STAR
03-12-2009, 06:50 PM
https://www.pro-touring.com/forum/showthread.php?t=53592
found this thanks again
dhutton
03-13-2009, 12:00 PM
Make sure you use hubcentric rings if you go with BMW wheels. More information about using BMW wheels here:
https://www.pro-touring.com/forum/showthread.php?t=50804
bochnak
03-13-2009, 12:27 PM
Here is my thread on C6 wheels for my 70' chevelle:
https://www.pro-touring.com/forum/showthread.php?t=42366
BTW,
BS is 7"/8.5" F/R for the C6 wheels I am running (w/o adapters)
Ended up with 2"/2.5" F/R for adapters.
