View Full Version : What water pump with OEM Serpentine System?
ed1le
03-04-2009, 07:38 PM
I'm running a serpentine system from a 91-92 camaro. It wasn't until after I ordered the water pump that I realized there was no inlet for the heater hose like on standard sbc water pumps. Anyone know of a water pump that will accomodate this and also work with this belt system?
Chad-1stGen
03-04-2009, 07:57 PM
The GM pump that comes in this system has an inlet for the heater hose, at least mine did.
The aftermarket pump that I put on my 92 truck which is the same serpentine setup also had the inlet.
Sounds like an issue with the manufacturer of the pump you bought.
130fe
03-05-2009, 05:02 AM
The camaro water pump doesn't have a hose connection on the pump (guess it connected to the radiator or something). Get one from a 92 style chevy truck with a 305 like Chad suggested and it will work fine. BTW they are reverse rotation water pumps (can't use the standard SBC one).
ed1le
03-05-2009, 05:56 AM
Correct, the camaro's had the inlet in the intake which I forgot when ordering the pump...glad to know of other options, thanks!
