funbnme
02-27-2009, 06:34 AM
I installed a new filler cap...the billet setup from Air Ride.
Here it is installed:
https://static1.pt-content.com/images/pt/2009/02/CamaroGasCap-1.jpg
My trunk floor was replaced and the tank isn't a stock replacement...so the tank filler is centered in the trunk and not offset a hair to the passenger side.
Hard to tell in this picture, but you can barely see that the hose is not going straight into the tank filler and because of that, it's causing a bit of stress on the rear panel.
https://static1.pt-content.com/images/pt/2009/02/DSCN0899-1.jpg
Anyone know of a hose I can use that is flexible and will stand up the gas fumes? The hose I have has barely any give, so it was a bear to even get it connected to both ends and I don't like that it's causing stress on the rear panel.
