JLM
03-09-2005, 08:04 AM
I'm meeting with my fabricator this weekend to talk about how we are going to plumb the system on this car. I'm still struggling on turbo selection however.
I'm not sure if we are going to have room to go with twins because of drivers side. The brake power booster, power steering lines and upper control arms will likely interfere with the exhaust plumbing. I don't for see a problem plumbing from the heads to the turbo, but room for the downpipe would be extreamly short.
With that said I may end up going with a big single. It's nearly impossible to kill the low-end on a 455 so I'm not worried about loosing low-end on a big single application. My problem is still in sizing. I'm looking to push between 650-700 which should be about the limit on pump gas with this size motor.
What turbo would you guys recommend for both a twin application and a single. My RPM range is 2000-6000 on the motor build. I would like to reach full boost no later than 3500 rpm. My stall speed is 2800-3000 on the tranny, so full boost closest to these rpms speeds would be ideal.
thanks in advance.
thanks in advance.
