View Full Version : who makes tires for a 19x12 or 20x12?
datsbad
03-08-2005, 07:47 AM
anyone know . we have a convertible 69 being mini tubbed now . we would like to do 20" but not sure if a tire is made for a 20x12 wheel ? 19's may work
Travis B
03-08-2005, 07:54 AM
We are doing a Willys right now with a 20x12! We got tires from tirerack Pilot sport 2 (335/30R20)! Not the coolest tread pattern but they are huge! :bananna2:
datsbad
03-08-2005, 10:18 AM
thanks . i really do not like the tread pattern but if its the only thing out not much choice huh? thanks again
TitoJones
03-08-2005, 10:51 AM
Pirelli
I had a 67 Camaro that left my shop with a 345/25/YR/20 on the rear.
Tyler
TonyL
03-08-2005, 10:58 AM
a pic of a pirelli
ViperBlue68
03-08-2005, 11:13 AM
theres a red camaro in Camaro Performers this month running 20x12s out back I believe it was at SEMA as well :dunno: not sure what tires hes running tho.........
datsbad
03-08-2005, 12:18 PM
i did see that but i think it was a misprint to his tire size . it said i think 235/35/20 . which could not be possible.
does anyone know what the complete width is of a tire that will fit with the DSE kit ? what is being used for a section width on a 12" wheel .
Travis B
03-08-2005, 01:00 PM
Micky thompson is also making a tire in various sizes for 20' wheels! But I don't think you can get your hands on them yet they have a wicked tread pattern! Look at the pics of the autorama and look at the truck with the lift off front end and lift up bed it has the MT's on it! We tried calling they said not tell the end of the year!! :banghead:
JV69z/28
03-15-2005, 08:40 PM
The red Camaro that's in Camaro Performers has 295/40-20s on the back. At least it did when I saw it in person. Tooo smallllll - LOL
ProdigyCustoms
03-17-2005, 02:43 PM
Prodigy runs 345/25/20s. Pirrelli asemetricos One thing to be very carefull on a 69 is rubing. The 20s are nearly 28 tall where as a 335/30/18 is under 26 tall. 345s will rub big time if you lower it at all.
Also, 345s are to wide for standard offset spring / mini tub kits. We are able to use them on Prodigy because it is a full chassis, no leaf spring, full tub project.
F70t/a
03-17-2005, 04:16 PM
Are the side walls on the 345/25/20 almost the same as a 345/30/19?
Ralph LoGrasso
03-17-2005, 05:41 PM
Relatively speaking, they're similar, but considering how small the sidewall is, there is a difference.
You can figure out the sidewall height by using the following formula: Section Width X Aspect Ratio (as percentage) / 25.4
That will give you the height of the sidewall, and in order to find the total height, simply double the height you got for the sidewall, and add the rim diameter. (The 25.4 is the conversion for MM to inches).
So for total diameter use Section Width X Aspect Ratio / 25.4 X 2 + Rim Diameter.
To answer your question:
345 X 25 % = 86.25 / 25.4 = 3.395" Sidewall
345 X 30 % = 103.5 / 25.4 = 4.074" Sidewall
So, the difference is about .7"
rocketman
03-19-2005, 07:23 PM
i got info on the mickey thompson street radials from my mt rep size are.for 18 and 20 inch wheels theres also 15 for those who like the old school look.
24-5-18
26-6-18
26-8-18
26-10-18
26-12-18
29-18-18
31-18-18
33-22-18
29-18-20
31-18-20
33-22-20
i manage to talk him out of a couple display tires.look real cool
will be out for sale the first of august.
i dont have scanner or i would load the pics.
HOOLIGAN
03-20-2005, 09:23 AM
The Porsche Carrera GT runs 20x12.5's with Michelin Pilot Sport 335/30ZR-20's on the rear.
maleezer
03-24-2005, 09:17 PM
I found a 325/25/20 michelin . 12.9 section width and 26.1 tall . this is very close to a 335/30/18
