rockdogz
03-08-2005, 12:22 AM
Where would you suggest routing the condensation vent tube for a vintage air system in a '68 Camaro? I can't seem to figure out the best location...
Overkill
03-08-2005, 10:27 PM
Don't know about other people, but on mine I took a piece of 1/2" stainless tubing that I had left over from my fuel lines and bent it a little less than 90*. I drilled a hole in the top of the toe board on the passanger side and ran the tube through it. I used the plastic piece that came with the kit and connected it to the tube. I put some sealant on the connection to keep it from leaking inside the car.
A couple of pictures to help you see what I did. This one is a little blurry because the camera wouldn't focus very well in the dark...
https://static1.pt-content.com/images/pt/2005/03/camaro_rebuild590-1.jpg
You can see the tube a little from the engine compartment. It's in the center of this picture.
https://static1.pt-content.com/images/pt/2005/03/camaro_rebuild589-1.jpg
Michael
