View Full Version : AXOD-E problems
windzer2
03-07-2005, 09:16 PM
This is driving me nuts .
When i drive for a wile and I stop at a stop sign
I go to leave the car doesn't move i can tap the gas
sometimes and it will jump forward then its ok
tell I stop again. Its fine tell it worms up.
Any ideas.
windzer2
03-29-2005, 04:50 PM
Well this is the low down 2256.20 wow but this is the list
1 assembly set-ls-w/.070 intermediate steels(b) 217.11
1 filter-2nd design(b) ==================15.41
1 band-overdrive(b) = ================ 15.83
1 band overdrive(b) ? ================= 20.03
13 fluid(b) ; ; ; ;==================== 68.25
7.5 labor(rr)(b) =====================525.00
8.4 labor(r)(b) ; ===================== 588.00
1 torque converter ==================329.00
1 chain-drive assembly (chain stre tched) ====99.43
1 piston-forward clutch (was cracked)======= 21.00
1 planet-ary (was comming apart) =========55.00
1 solenoid-L/u (milege) ========= 51.00
1 solenoid-pressure control ; ; ; " ======== 51.00
3 solenoid-shift ; ; ; ; " ; ; ; ; ===== 136.08
1 sprag clutch-low clutch sprag ; ; ; ; ====== 45.00
1 roller clutch-direct clutch roller ; ; ; ; ====== 31.00
1 vb kit-shift kit-transgo(updated Vbody lubeholes)==66.00
tax==================================== 61. 00
cupone (100.00) cupon from web == -139.00
total parts ========================= == 1221.14
labor ; ; ;========================== 974.00
total ; ; ; ========================== 2256.20
patriot68
03-29-2005, 06:33 PM
?? :nopity:
windzer2
03-31-2005, 07:33 PM
:box2: ok
derekf
04-03-2005, 02:59 PM
So what was the actual issue with the tranny? The cracked clutch, stretched chain, and the planetary coming apart?
