View Full Version : So I just pulled the old cam out.....
zbugger
08-22-2004, 05:41 PM
... And I find that it's an Isky 262 supercam. Pleasant little surprise to me. I knew it wasn't stock but I didn't know what it actually was.
Specs: http://www.iskycams.com/timingchart.php?product_number=201262&timing_chart_id=91
What I'm going to is the Comp Cams High Energy 268H.
Specs: http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=12-210-2
I'm also swapping from the original Goodwrench 350 heads to a set of World Sportsman II's. What effect do you guys think I'm gonna feel? Is it gonna be more from the heads than the cam? Or is the cam really gonna pull through?
nancejd
08-22-2004, 05:47 PM
I think you'll probably see a little loss on the low end, but pick up some top end from the cam change. I bet your major change in performance will be from the heads. I think the stock goodwrench heads are a little restrictive. That's why mine aren't going back on the engine I'm building.
dennis68
08-22-2004, 06:10 PM
Allen, your going to see big change across the board. Down low included. I swear looking at stock GM heads these days it looks like the Mexicans building them are using Aztec ancient chisels to punch out the ports. That is a nice mild cam, a little lobe at idle, just enough to know it's not stock.
yody
08-22-2004, 11:04 PM
i wouldnt use the high energy line of comps cams, if anything go with an extreme 268, the HE line is VERY old, old cam techonology=lost potential. if stuck on a comp cam i would suggest the extreme 268, also if you have a die grinder handy i would give those heads a decent bowl job, they respond well to porting, out of the box they are decent, but they are too an old head that have been aroudn for awhile, in the last few years, head design has come a long way. you will probably be looking at a 325-350 horse motor compared to like 300
zbugger
08-23-2004, 09:28 AM
Yeah, I know that stuff Cody, but I'm stuck with keeping this thing smog legal. Otherwise, things would be quite different. Oh yeah, and my budget doesn't help any either.....
