ebncrdr
01-31-2009, 05:27 PM
I am having trouble figuring out how to get the "open track" feature to work properly. This is what would be used for an autocross track. I can make the track map, set up the start and finish lines, and break the track up into segments. The problem I am having is when I do this I don't get any entry or exit speeds for the segments. I do get the split-times for each segment though.
Also when I try to upload another run using the same track map the "X" to represent the car will not move around the track. I dont know if I am following the correct procedure.
I hope this is enough information for someone to understand and any help would be greatly appreciated.
