View Full Version : C6 Z06 wheels on 1st gen yet?
CamaroJesse
01-26-2009, 10:24 AM
Has anybody put C6 Z06 wheels on a 1st gen yet? If so hows the fit and are any adapters or spacers needed? I really want to upgrade from rallys this year. If these work easily ill buy them.
thanks
Jesse
Taylor1969
01-26-2009, 10:47 AM
Gonna need spacers for sure...
http://www.skulte.com/index.php/cPath/21 has spacers
http://www.tomzwheels.com/catalog/Home/oecon.htm has the wheels
Payton King
01-26-2009, 11:40 AM
It is going to take an aftermarket subframe taking a corvette offset.
Fronts are 18x10
rear are 19x12 Need a custom width rear and mini tub
CamaroJesse
01-26-2009, 12:52 PM
Damn. Time for a new idea then. Thanks for the help.
nicks67camaro
01-26-2009, 04:58 PM
I am running this on the front. LINK (http://www.tirerack.com/wheels/results.jsp?autoMake=Chevrolet&autoModel=Corvette+Z06&autoYear=2002&autoModClar=)
These will work for the front (its only 8.5 inches wide) the rears get funny I am running the 10.5 rear (I have mini tubs) but you can run an 8.5 on the rear as well.
Use this (http://www.rims-n-tires.com/rt_specs.jsp) web site to play with offset and to find out how they will fit with tires. I have the 8.5 front and 10.5 rear and will post up once I get tires and spacers. could be a couple weeks still.
Worst case senerio you will need to have play with studs but use the tire/rim comparision site will give you an ideal what you need.
Good Luck
