View Full Version : p1sc pro-charger on a LS-1 in a 67 Camaro?
Dream68
01-19-2009, 02:46 PM
IS This posible?? I Have a p1sc charger off of a 03 Mach-1 and according to procharger a few brackets and pulleys for the ls-1 re-work the intercooler piping and this should work on the ls1 but my question is will it work in a 67 camaro w/ a stock subframe?? The Ls-1 mounting point is on the bottom of the motor so im wondering if I will run into subframe clearances?? Does anyone have this on a car or know if this will work?? Thanks
WS6
01-19-2009, 05:11 PM
use the C5 vette mounting as it's on top of the passenger side or will the head unit not work in that location? Everything else will have to be custom. ProCharger does make an intercooler that could work for you.
Dream68
01-19-2009, 06:53 PM
thanks, would you recomend still doing the kit or just selling the kit I have and going to a small turbo?
WS6
01-19-2009, 07:35 PM
pro-charger will work just fine and be much easier. It actually works very similar to a turbo in that it needs RPMs in order to build boost. They are fun. You'll need to check with Pro-charger that that head unit will mount on the top passenger side using C5 brackets. I'm not sure if it will. It should though.
Dream68
01-19-2009, 09:06 PM
Thanks, Does anyone have a (C-5) Procharger bracket on a LS-1 that I might be able to see some pics? Thanks I will be checking w/ procharger tomorrow to see what they say about it.
WS6
01-20-2009, 04:10 AM
this is the best I can do for you
Dream68
01-20-2009, 06:36 AM
thanks ws6
