    Results 1 to 17 of 17
      Jan 2009
      San Antonio, Texas
      71 Javelin Trans Am Clone - Dash Fabrication?
      Fellas -
      New guy here. I have a 71 Javelin that's going to get the Trans Am clone treatment. Interior will be purpose built - no radio, no A/C, two lightweight racing seats, no back seat, roll cage, etc. I just need a bare-bones dash with a plethora of gauges, toggle switches, etc.
      I'd like to ditch my factory dashpad and all the plastic trim, etc. I'd like to sell it all (dashpad, console, rally gauges, etc) to finance a custom-built one. Will probably totally rewire the car, too, or at least from the dash forward, with a Painless kit or something similar.
      My questions - is fabricating a new dash something that a reputable shop can do without too much trouble or expense? Also, what do I need to keep from my factory dash? Nothing? Vents? Defroster? Any ideas on cost? How difficult is this to fabricate? I'm a do it yourself kind of guy, but have never tackled anything like this.
      Thanks!
      Scott
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      Jun 2005
      Quote Originally Posted by Bulletpruf View Post
      Fellas -
      Thanks!
      Scott
      Any decent body shop should be able to fab you a dash, even if they source out some of it to an upholestry shop.
      You can build a nice dash out of wood and have it covered or fiberglassed, or you can make it out of steel. There's a common misconception that a steel dash or console is going to be heavier than fiberglass, but 9/10 that isn't the case.
      As for what you need out of your stock dash, that depends a lot on what your intentions are. If you're going to use the stock ac/heating components, then yes, you're probably going to want your ducts and whatnot. Worse case scenario you'll at least need your stock ducts if you're gonna use the stock heating components. You can buy aftermarket grilles if you want to spend the money.
      If you go with an aftermarket a/c unit, a lot of that stuff is mounted under the dash. As far as vents and stuff goes, a lot of them use rubber hoses. In which case you'll just need a grille, be it your stock grilles or an aftermarket one.
      Then you have to consider your gauges. Gonna use the stock cluster? Save it. Gonna use some autometer pieces? (nice but not original anymore) then at least write down your mileage and information from your stock gauges.
      Also, if you're using any of the stock switches, such as headlight switch, radio, anything, make sure you save the switches and the wiring. Try not to hack up the wiring too much, it will save you time later.
      If you're really interested in doing this yourself, I can provide you some links. Sport truck sites are absolutely wealths of information on this sort of thing as they are always on the cutting edge of customization. They're not afraid to NOT go stock. You'd also be surprised at how many neat things you can find on an import site. Even if you don't think putting a turbo unit on a Civic is a worthwhile expensive for your money, that doesn't mean they don't know some neat interior tricks.
      Personally? I'd go totally custom. Search the junk yards and/or ebay and find some grilles and gauges you think look good, that will work with your engine.
      I absolutely applaud you for going the stock route instead of doing a restore. Restorations are nice if you have a lot of extra money, or your car is worth something and you look at it as an investment. If you're going to actually drive it, make it as comfortable and personalized as possible.
      Mathius
      Oct 2008
      texas
      I can hook you up. I have 3d cad and water jet on hand. This is the dash I created for my LS1 F-85 project with autometer gauges. Let me know if I can help.
      Rocky
      This is Larry Callahan adding to Rocky's profile.
      I'm sorry to say that we have lost Rocky.
      RIP....
      May 2008
      Damn. How cool is that?
      Chris B
      ROCKTOP! BADa$$
      Mountain View, CA
      Quote Originally Posted by rockytopper View Post
      Rocky
      Hmm, so if someone were to send you a cardboard template could you reproduce it?
      True T.
      My blog
      Oct 2008
      texas
      Quote Originally Posted by Damn True View Post
      For sure, I'll redraw it in cad, insure it is identical to what has been sent, send to jet and ship you a custom dash to your specs. Logo's etc.. etc..
      I can do any flat pattern up to 6 inchs thick with the jet. Billet brackets , trans mounts, engine covers. Check out my PT garage you'll see some other work I have done on my LS1 F-85 project
      RIP....
      Mountain View, CA
      Can you do bends as well?
      True T.
      My blog
      Oct 2008
      texas
      Yes but our brake is only a small hand job, any serious stuff I will have to ship out. The engine cover was formed by hand using a rubber hammer and a piece of thick walled tubing that had a .50 radii to form around. If parts are to be bent I use 5052 which is easier to form than 6061 t6. It is much cheaper on the pocket book too. For a dash you would need to send the original so that the bends could be matched.
      RIP....
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by Mathius View Post
      Mathius
      Mathius,
      Thanks for the info. Will have heat, but not A/C. Aftermarket gauges. No radio. Minimal use of stock switches, I think. More of a bare bones racer, lightweight piece.
      Please send links.
      Thanks!
      Scott
      Jan 2009
      San Antonio, Texas
      Rocky
      Beautiful handiwork, Rocky. One thing, though - I intend to ditch my stock dash entirely - - no dashpad, just start from scratch. Think that would take a few bends. What do you think? Guess I need to pull the rest of the stuff out and take some pictures.
      Scott
      dayton, oh
      I would go fiberglass. lightweight and easy to work with. build a plug out of a combination of wood and foam, then pull a part from it. or, you could pull parts from a junkyard and mold them together.
      check out this site:
      http://www.fiberglassforums.com
      you have to join to see the posts, but a bunch of guys have done custom dashes.
      dave.t
      74 Javelin AMX - stocker
      Jun 2005
      Mathius,
      Please send links.
      Thanks!
      Scott
      Well, I gotta tell you for fiberglass, jackfrost's link is great. Those are great forums. They also cover acrylic, and just about anything else that might have to do with custom audio show cars.
      Here's a few examples from that site...
      This guy chose to build his dash from scrap using wood and fiberglassing it:
      http://www.fiberglassforums.com/showthread.php?t=7302
      This guy actually made his dash from a bunch of different junkyard components that he just liked the look of:
      http://www.fiberglassforums.com/showthread.php?t=8462
      Also, like I said, the custom truck and import scene is where it's at for creative DIY'ers:
      Here's a complete guide on fiberglassing written up at Fullsizechevy.com:
      http://www.fullsizechevy.com/forums/...ing-guide.html
      I would supplement that link with the forum that Jackfrost entered.
      Here's another build from FSC where he chose to keep the frame of his dash and glass the rest:
      http://www.fullsizechevy.com/forums/...ash-build.html
      This guy built his from wood, using the stock components he wanted to keep:
      http://www.fullsizechevy.com/forums/...sh-yes-no.html
      And don't overlook the idea of just taking a tape measure to the yard and picking a dash that fits and making it work. This guy took a 2000 Chevy Dash and put it in his '85 pickup:
      http://www.fullsizechevy.com/forums/...2000-85-a.html
      This guy chose to make a custom console and keep his stock dash, but he smoothed it, painted it, and put flames on it. You can also go back and look at this entire truck build:
      http://www.fullsizechevy.com/forums/...-lowrnu-5.html
      This guy chose to build his dash from steel. He built a frame and then welded the sheet steel in place. That's probably how I'd do it as well:
      http://www.fullsizechevy.com/forums/...materials.html
      Speaking of working with metal, this is a great place for ANY type of metal project: http://www.metalmeet.com/forum/index.php
      Here's a guy grafting in a new section to his steel dash:
      http://www.metalmeet.com/forum/showt...ight=dashboard
      Lastly, I could have swore I read that you wanted to go with a real bare bones feel? This guy made a very simple sheet metal dash, pretty much flat rectangular sheet with just a few bends:
      Hope those help, and I definitely encourage you to be unique in your choices.
      Mathius
      Jun 2005
      Oh yeah, this one is good too. Not really a how to, exactly, but has some good step by step photos at least. http://www.hotrodscustomstuff.com/in...camaro-04.html Mathius
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by jackfrost View Post
      Thanks, I'll check it out.
      Scott
      Jan 2009
      San Antonio, Texas
      Mathius
      Mathius -
      Really appreciate the info. This is extremely helpful.
      Scott
      El Cerrito, CA
      hey, how's the trans-am javelin project coming? I'm a little late to the party but I wanted to mention a couple things. First, the real trans-am javelins kept the dash PAD and just fab'd a gauge cluster. here's a pic of the #2 RWR (roy woods racing) javelin dash.
      second, I've reconfigured my stock dash and loaded it with auto meter gauges. might give you some ideas if you haven't already completed a custom dash. here's a pic and you can check out more pics and info on my javelin blog http://asifnyc.com
      My Javelin is yellow with black stripes inspired by the '71 roy woods racing TA javelins. Also, I have a bunch of detail shots of the #2 RWR red/white and blue javelin. depending on how accurate you want to take the clone concept they might answer some questions for you.
      good luck and post some updates.
      -Asif- Penngrove, CA (SF bay area) asifnyc.com - AMC blog
      1974 Javelin NASA American Iron road race car
      1975 AMC Matador road race project
      1973 AMC Javelin/AMX driver
      1975 AMC Gremlin driver
      1975 AMC Gremlin track rat project
