dplenzig
03-04-2005, 06:04 AM
I want to put a 6-speed in my 69 camaro. I found the Keisler engineering kit for $3995. I was wondering about my other options or other kits maybe a little cheaper. This will be behind a standard small block, and car is a 4-speed.
Thanks, Daren
Ralph LoGrasso
03-04-2005, 12:10 PM
Check out ATS' kit at www.t56kit.com.
barraza
03-04-2005, 12:30 PM
If you already have a manual, the best and cheapest way is to get the aftermarket version of the t56. Liberty sells them for under $1900. All you will need is a 26 spline clutch disc and a new tranny crossmember. Shorten the driveshaft you have now. Your original bellhousing, pressure plate, clutch linkage, and speedo cable will be fine. Sixth gear is .62 instead of .5 and is in my opinion better for most carbed cars and becomes more usable. That keisler kit is way too expensive.
