Hellsing
01-08-2009, 02:00 PM
This is my first post and my first thread so please bear with me.
Suspension type, Truckarm. Problem; trying to set my pinion angle which is another first for me, for vibration free driving at high speed and still get the best 'bite' possible, which is a term I've head thrown around although the physics behind it remain mysterious. Apparently a negative pinion angle (pointing towards the ground) is required. I have also heard that a positive pinion angle (where the pinion is pointing up) is undesirable and will result in unpredictable behavior.
Unfortunately, my dilemma is that with my transmission output shaft angle running at 5 degrees down, and my driveshaft running 4.5 degrees down, sloping towards the rear end, will require my pinion to be pointed up at an angle of at least 4 degrees. Which not only seems like a lot but it looks like a lot too!! :eek:
I don't know how much axle wrap up should be taken into account with a truckarm suspension. Although the arms themselves seem vary ridged in this respect some deformation will undoubtedly occur, at least in the bushing, but I would imagine not more than a degree or two.
I could shim my transmission up but I am concerned about the resulting angle of the carburetor. Would I then need to have my intake manifold machined back to level? :hmm:
Am I over analyzing and over complicating this as I've been told many times I have a tendency to do?! Is the thing to do just to set my pinion angle facing up and call it a day or are there some tenths of a second to be gained here?
_Jon
_Jon
