View Full Version : Problem with Hotchkis front bar
Northern Goat
01-07-2009, 08:41 PM
I have a 1971 Firebird and purchased the Hotchkis TVS system. I am trying to bolt up the front sway bar bushing brackets and the spacing of the holes in the bracket seems too wide for the holes in the frame. When I try to use studs the cap goes on; however the studs are so close to the curve in the bracket that I can't get a nut on.
Anyone else have similar problems???
zbugger
01-07-2009, 08:58 PM
The kit comes with Allen head screws. At least it should. There's no way to get a normal head bolt on there. I just put one of these, well, the DSE bar, on my '77 Camaro.
Northern Goat
01-07-2009, 09:09 PM
Thanks. I will go out and look for the bolts.
01-07-2009, 09:10 PM
Header bolts work too! :)
PT Goat
01-08-2009, 06:06 AM
Had the same issue on my GTO, and had to re-tap the mounts for the supplied allen head screws. Just start the bolts and tighten them slowly, going back and forth a few turns at a time. Everything should snug up just fine.
Turbo67camaro
01-09-2009, 01:23 AM
I just had the same issue with a different brand sway bar, but luckily I had another set of bushing brackets that fit properly.
Northern Goat
01-11-2009, 07:26 PM
The good news is that I bought some allen head bolts and they work in 3 of the holes. The bad news is I screwed up the 4th. I think I will have to use a helicoil or nutsert to fix the offending hole.
01-11-2009, 08:09 PM
Nutsert is the way to go. There isn't enough metal thickness for a Helicoil.
PT Goat
01-12-2009, 06:18 AM
I had the same problem with one of the holes, but was able to get a nut on the bolt through the front of the frame.
