View Full Version : Ford 9" Housing Bracket JIGS
FURO
01-05-2009, 07:02 AM
I looking for ideas on what others have done. Please post up pics.
I want to build a jig for putting the brackets on a Ford 9" for G-body, Fox Mustang, etc...... I also want to make it universal to do others as well.
Also where is the best price & place to get the brackets for these?
Thanks in advance,
FURO
Ratfink
01-17-2009, 06:35 AM
I have built plates that bolt where the third member does and from there added struts with bungs to all fixing points. On a side note, i like to leave .030-.040 clearance at the bung to ease in assembly of the finished part.
hotrdblder
01-17-2009, 07:10 AM
generally you weld the trailing arm brackets etc on, then use a jig to weld housing ends on, as that is the important part.
FURO
01-17-2009, 07:52 AM
Thanks again for the responces. Yeah I know the ends are always last. I have a MB alignment jig for the ends. The part I want to see is the jig part that holds the upper an lower controls arm mounts.
Thanks again,
FURO
Mathius
01-17-2009, 11:30 AM
I couldn't find this right away... I had it bookmarked once, but the site changed. Used to be at malibunorth. Anyways...
http://jackstandracing.com/9in/
This stuff could be useful too:
http://home.bresnan.net/~dazed/narrowinga9.html
http://www.maliburacing.com/tech_rearend_swaps.html
Everything you ever wanted to know about the Ford 9"
http://www.maliburacing.com/ford_9_inch/ford_nine_inch.htm
Mathius
jason@gmachine
01-18-2009, 10:46 PM
i would show you ours, but its a trade secret! :)
jason
