View Full Version : 86 vette rear in 69 Camaro
Riderz Cycle
01-04-2009, 02:32 PM
Currently stumped...Has anyone tried to fit a vette rear in a G1 camaro? I have DSE mini tubs installed already and trying to come up with the correct wheel widths / back spacing...I know I'm doing it the hard way. I guess the biggest issue is the track width of the corvette rear which is 61.5 inches rotor to rotor. I believe DSE recommends 55 inches axle to axle with a 6.75 inch backspaced wheel...Is the easy answer to narrow the vette rear set up to 55 inches or to go another route all together...I think this setup will work well and wanted something different from the standard 9" with 4 link....Any help or photos of someone that has already done this would be great appreciated
:hammer:
BMF Machine
01-04-2009, 04:00 PM
TrY contacting FranK at ProdigY CustumS? EveN though he is a SuperstaR, he will probably be able to answer that question really fast. I believe he has a special time even laid out just for Pro-TourinG members to pick his BraiN. I don't belive there is a rear end he has not checked out in Florida or in FirsT GeN Camaro'S?lolol JusT kidd'n LisA?
Find FranK Here......
www.ProdigYCustomS.com (http://www.ProdigYCustomS.com)
Here is a pick of ProjecT ProdigieS ReaR EnD? It is a 67, and I can't remember if it is a C-3 or C-4 Rear? I think it is a C-3? AnywaY he will probably KnoW?
Edit.......... WoW, I just went to ProdigeS site! It has been completely redone and looks IncrediblE!
ProdigyCustoms
01-04-2009, 04:39 PM
We are doing a C4 rear now right now. We narrowed it to 55 1/2" and are running a 6.2 backspace
BMF Machine
01-04-2009, 04:50 PM
A superstaR with a very bad internet addiction?:lol: DamN he is Fast!:eek:
Riderz Cycle
01-04-2009, 05:08 PM
Frank thanks a ton... that is the route I was thinking, So you cut down the shafts and shortened what I would call the "I" links going to the nuckles and what about the composite rear spring?
ProdigyCustoms
01-04-2009, 05:12 PM
Made new doglegs, new camber bar, shorten the tow bar, shorten the shafts, Coil overs now, no more leaf
Riderz Cycle
01-04-2009, 05:21 PM
Frank could I bother you for some pictures whenever you get a chance. Here is my office e-mail [email protected] I wish I knew your location before, I just spent 4 month in West Palm for work I would have made the drive up to see your shop, Next time I'll be there again soon...Again thanks for all your help
ProdigyCustoms
01-05-2009, 01:22 AM
https://static1.pt-content.com/images/noimg.gif]
kaptainkw
01-12-2009, 09:48 PM
Oh man... I'm right in the middle of doing this very thing. It's a nightmare!!!
I was able to get ahold of a kit made by Wayne Due for putting C4 IRS's in first gen. Camaros. The problem I'm having is the width of the C4 (it will require a serious backspace on the wheels or shortening of the half-shafts and associated camber and toe-in supports) and the ride height. The Wayne Due brackets leave you with half shaft angles of about +4/5 deg (sloped up). I believe you want between 0 and -2 deg otherwise it would look funny as well as not be an optimal set-up. In order to do that you'd need to mount the batwing almost to the frame rails.
Questions for Frank:
Why 55 1/2" and where is the measurement taken (outside to outside of hubs, etc)? I want to use the factory dogbones and narrowing too much will interfere with the frame rail.
What tire width are you running? I'd like to run 245-275/18's
Cheers!
