View Full Version : AFX spindle steering stops
jerome
01-02-2009, 11:34 PM
I have a stock g-body lower contol arm with afx spindle, and I am thinking about ways to build a steering stop. I would probably have it hit the lower caliper bracket bolt. I can't find any other place to brace against.
Does anybody have pics of their setups? any steering stop, doesn't have to be specific arm or car.
I would go for a steering box with internal stops but i need about 50-55 degrees of pitman travel, and gm boxstops only go to 43 degrees, or way over 55 degrees (basically no usable stop)
Jerome
greencactus3
01-03-2009, 11:28 AM
having a stop against anything brake related sounds scary... even if it is just a bracket bolt...
how far up is the steer arm on the spindle from the lca?
jerome
01-03-2009, 03:03 PM
pics aren't at ride height because the engine is off of the frame
steering arm is too high to stop against spindle:
https://static1.pt-content.com/images/pt/2009/01/IMG_1797Large-1.jpg
the bolt I am talking about:
https://static1.pt-content.com/images/pt/2009/01/IMG_1798Large-1.jpg
bolt when turned away from arm, you can see the old steering stop where I would have to add a block of material to to hit the bolt:
https://static1.pt-content.com/images/pt/2009/01/IMG_1799Large-1.jpg
The WidowMaker
01-03-2009, 03:53 PM
have you talked to tom lee about an internal box stop? he builds them custom for the nascar guys, so he told me it was only a few shims that needed to be changed. he wanted $50 plus shipping. thats a couple hours of my time, and it would be done properly.
Tim
greencactus3
01-03-2009, 10:55 PM
how hard would it be to make a steer stop that bolt on the inside of the steer arm using those same bolts?
looks like you only need a small 'overhang' stop from there to 'cover' that caliper bracket bolt.
