View Full Version : What to do with leftover ports on the gas tank???
Chevelle LT1
01-02-2009, 03:17 PM
In my quest to (finally) get my project car finished and on the road, I am running into one more road block: On the fuel tank, I have two unused ports on the fuel tank; one looks to be 1/4" and the other 1/2". For obvious reasons, I am trying to avoid having any open ports on the fuel tank, and would like to plug these. That being said, I have not yet come up with a clean way to plug these ports, and wanted to know what others may have done in the past. For what it's worth, the specs on the car are as follows:
- 1970 Chevelle
- Rock Valley Fuel Tank (original style)
- Vented fuel cap
- '94 LT1 motor
Any feedback/suggestions for what does (or does not) work is greatly appreciated.
Thanks.
~ Jason
CarlC
01-02-2009, 09:03 PM
What kind of ports are they? NPT? AN? Holes?
Hammered
01-03-2009, 05:19 PM
The 1/4" one is probably the vent. If it's just a tube, cap it off with a swage fitting, but make sure you have an alternative vent.
DeltaT
01-05-2009, 12:12 PM
I would get rid of the vented cap and put a vertical loop (to prevent fuel spurting out of the filter) of 1/2" hose out to a filter someplace at the rear of the car. Cap off any others.
Jim
Hammered
01-05-2009, 07:08 PM
Missed the vented fuel cap. Most vented caps let air in, but not out. You need a two-way vent with an EFI car. You can buy sintered metal breathers from McMaster Carr that thread onto the end of a tube.
Chevelle LT1
01-06-2009, 04:26 PM
Thanks for the replies, and the suggestions. Can someone please explain to me why you need a non-vented cap, or is it just that you need the 2-way vent, which you can't get with the fuel cap?
Thanks again.
DeltaT
01-09-2009, 12:24 PM
You need a 2-way vent. This was driven home to me when Fuel Safe screwed up and put a spring-loaded (1-way, in only) check valve in my fuel cell, and I was having early fuel heating and expansion problems and one day found the walls of my cell bulging with trapped pressure.
You want a angle-activated check valve (tipover protection) but you must have 2-way venting.
Jim
Here's the pic with the loop. It goes out through a bulkhead fitting to a small K&N filter:
https://static1.pt-content.com/images/pt/2009/01/4dr_reartrunkshot_090705_mini-1.jpg
Chevelle LT1
01-20-2009, 11:22 AM
Sorry to dredge this up again, but in regards to the 2-way vents, can someone please provide some direction as to which to get? McMaster Carr was mentioned as a possible source, but after doing some digging on their site, I can't find anything that is obvious for working. Thanks again for the help.
~ Jason
Hammered
01-20-2009, 07:31 PM
Look at their breather vents on pg 345 of the online catalogue. I'm using one on the end of a 5/16" OD SS tube turned upward and above the top of the tank. I stole the idea after seeing some race cars with the same setup.
DeltaT
01-23-2009, 12:51 PM
Also check Summit, search for 'tipover valve' and you get 8 choices.
Jim
