View Full Version : Turn signal/Hazard ?
slck6t9
12-31-2008, 04:58 PM
I am in the process of installing the Marquez front LED park/turn signal lights and the Digi-tails rear LED light kit. The rear harness is currently disconnected and the front LED lights are installed. I have installed the new Hazard and turn signal flasher's meant for this application also.
My question is, the turn signal's and hazards work in the front with the lights off but do not with the lights turned on. Is this because I have the rear harness disconnected? With the lights on you can hear the flasher's clicking like the turns or hazards are working but nothing. Guess I need to finish up the rears and see if it is still the same. https://static1.pt-content.com/images/pt/2005/04/willy_nilly-1.gif
Also, my two wires were black and purple not orange like the instructions.
slck6t9
12-31-2008, 08:23 PM
Anyone!!
zbugger
12-31-2008, 10:36 PM
Well, you may want to finish up the rear harness before really thinking something is wrong, but you're still going to want to check your grounds up front. I had a similar issue on my car once and it was a ground issue.
MuscleRodz
01-01-2009, 12:30 PM
Flip the wires. The no loads do not differentiate load like a mechanical flasher will. It works when it sees 12v.
