View Full Version : Torque Thrust II's and 13" Baer Brake Help !
D.Alman
12-31-2008, 01:09 PM
I have a 67 camaro with 4 wheel drum brakes. I would like to go with 13" Track system on front and 12" on rear. I running american torque thrust II Cl 205 wheels front are 17x8 with 4.75 BS and rear 17X9.5 with 5.5 BS.
Has anyone ran into any problems with these systems running TT II's and the Baer brake setup. Any Pictures ? Any advice ?
streetk14
12-31-2008, 03:55 PM
I had TT2's on my '68 in the exact sizes you mentioned along with a 13" Baer track front brake kit. No issues with clearance at all, but the brakes fill up the wheels nicely. Hope that helps.
zbugger
12-31-2008, 06:07 PM
I don't think you'll have an issue with the track system. With the GT kit you would most likely need about a 5/16" spacer on it to clear between the calipers and the spokes. It'll be close, but it will fit. It's because it uses a different caliper than the Track kit.
yellowrallys
12-31-2008, 06:23 PM
That is exactly the setup I'm running with no problems.
tom_a
12-31-2008, 09:43 PM
I had CL205's with 17 x 8 front, 4.75" back space and C6 calipers with Baer 12.79 rotor. I had to use a 1/2" spacer. I might have been able with a little shorter spacer but I don't think much shorter. Also I had them on ATS spindles with C5 hubs so that may be something to keep in mind. I have it tore back apart so can't be sure and the wheels might be sold tomorrow if not I will be listing them. Can't help on back as I had 18" there.
https://static1.pt-content.com/images/pt/2008/06/tierod0041-1.jpg
