View Full Version : Thoughts on Holley ProJection system?
ed1le
12-29-2008, 07:37 AM
I found the 900cfm projection system locally for sale for $400. I still have to call to confirm this includes the harness and everything. Assuming it does, it seems like a pretty good deal but curious as to what everyones thoughts/experiences are with this system? I wasn't planning on going the EFI route but would consider it for this price.
MonzaRacer
01-01-2009, 09:19 AM
Well I am not a big fan of the Holley controller but if its working go for it after proper research on which controller it has with it.
My preference would be pick it up, its cheap enough and then you can order up a Megasquirt ecm and simply mate it to the injector setup from the Holley kit.
Since the MSII can control just about anything out there including ignition and with add board/ecm you can even control electronic trans and its open source so other than assembly labor and parts you can get lots of help from the MS forums and such.
I looked at a used Bigsquirt3 and from the looks of my grand total i would have nearly $3000 in my whole system but a MSII setup I can use any dist(I happen to have a latemodel small cap, and a GMPP (MSD) centrifical only dist too. and even reuse the LT1 injectors till I get set up for FlexFuel and since I now work for a Ford dealer I can get good deal on sensor haha. Oh and with out E85 sensor I will have less than $1000 total in my FI.
Good Luck.
Lee Abel
AFTERMARKET PERFORMANCE
