View Full Version : Project-"Evade"
68/CamaroFL
12-27-2008, 09:58 AM
Well its finally coming together Project "Evade" thank God for Tom Argue @ HydroIllusions! here is Project “Evade” LS2 Build specs
LS-2
Bore and stroke: 4.00 x 3.62 in.
Displacement: 364 cu. in. (5.967 liters)
Compression: 10.9:1
Induction System: Sequential fuel injection
Gross Horsepower (SAE net) 400 @ 6000 rpm
Gross Torque (SAE net) 400 lb.-ft. @ 4400 rpm
Block All-new 319-T5 Aluminum
Livernois Heads:
Stage 2 CNC Ported Stage 2 GM LS-Series Cylinder Heads
New GM 243 casting
5 axis CNC machined
220cc Intake Runner
Intake Flow Rate 305 CFM
Exhaust Flow Rate 235 CFM
2.000 intake valves / 1.550 exhaust valves
GM valve seals and locks
Livernois dual coil valve springs good to ~ .690 lift
Livernois titanium retainers.--Jessel 1.7 Rollor rockers
Livernois Motorsports LS-Series Stage 2 Camshaft
Intake Duration 232 @ .050
Exhaust Duration 232 @ .050
Intake Lift .595”
Exhaust Lift .595
LSA 114
Fast 92mm Intake ,Fast 92mm T.B. ,Fast Fuel Rails, 42lb Fuel Injectors, Katech Valve Covers
AutoKraft Oil Pan & Engine Mounts, Synister Billet LS Series Serpentine Belt Systems
SpearTech Custom Wiring Harness
Suspension/Chassis:
Front Sub Frame
Speed Tech Performance • NEW Design hi clearance upper and lower control arms with Moog TM Problem Solver ball joints, QA1 single adjustable coil over shocks, QA1 coil springs, Billet aluminum upper coil over mounts, Unisteer complete rack kit.Adjustable trans cross member will fit to a T56, 1.25"solid sway bar (only works with HiClearance control arm package) ,Adjustable motor Mounts, Brakes Front: Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
Rear Suspension Chris Alston's Chassisworks Camaro g-Bar Suspension
With Pivot Ball Lower Link adjustable length link,
Low-friction, pivot ball mechanisms.,G-Bar Sliding-Link Adjustable Anti-Roll Bar,VariShock Single adjustable coil-Oversm,Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
Keisler Engineering Inc. TKO-600 5 speed Lakewood SFI Steel Bellhousing for Chevrolet LS, Hydraulic Clutch Actuator Kit
Rear End: Strange Engineering
S60, S/T Series 35-spline axles, 1/2” studs, Trac-Lok Posi unit, 3.73 gears
Brakes Rear: Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
https://static1.pt-content.com/images/pt/2008/12/Picture004-2.jpg
https://static1.pt-content.com/images/pt/2008/12/Picture009-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Picture003-1.jpg
https://static1.pt-content.com/images/pt/2008/12/LS2Motor3-1.jpg
icebird84
12-27-2008, 10:06 AM
like your motor but I love your rims :) excellent project you have there
skeeters65
12-27-2008, 11:43 AM
Damn what are those wheels 33"..
Sweet car
Memphis
12-27-2008, 12:13 PM
Love the wheels :)
syclonetommy
12-27-2008, 04:59 PM
Bill, Looks like i should start making wheels to sell.
There 27" in the frt.
Tom
FirstGenZq8
12-27-2008, 05:01 PM
tom argue of syty fame? does he have a website?
syclonetommy
12-27-2008, 05:07 PM
yes, Thats me?
www.Hydroillusions.com (http://www.Hydroillusions.com)
Working on new web site for are car projects.
FirstGenZq8
12-27-2008, 06:34 PM
i don't want to hijack this thread any worse than i already have. i've never met you, but i read hundreds of emails from you on the syty mailing list 10-15 years ago and your posts on syty.net. nothing big. 68/CamaroFL, your project is in good hands!
cdoggy81
12-27-2008, 11:42 PM
nice ride!
BTW what did he charge you to cover that intake in a carbon print?
68/CamaroFL
12-29-2008, 09:21 AM
Here is the Project before tear down
https://static1.pt-content.com/images/pt/2008/12/68camaro1-1.jpg
Out with the Old small block and front subframe
https://static1.pt-content.com/images/pt/2008/12/68camaro19-1.jpg
Mocking up the New Speedtech Subframe and LS-2 Motor
https://static1.pt-content.com/images/pt/2008/12/68camaro23-1.jpg
Speedtech Subframe and LS-2 Motor with Keisler Transmission
https://static1.pt-content.com/images/pt/2008/12/Picture074-1.jpg
javablack
12-29-2008, 09:26 AM
very cool project
DriverzInc
12-29-2008, 11:51 AM
Looking good man! We'll be sure to ship you those parts as soon as they are ready!
68/CamaroFL
12-30-2008, 06:49 AM
Thanks Jon for help
BP
killer69
12-30-2008, 08:50 AM
Bill the car is looking good, comming along nicely.what is your antisipatde finish date? and Jon? when did you release those WHEELS Dude! tell Jason he really hit a home run with those.
syclonetommy
12-30-2008, 07:12 PM
Blake, antispatde finish date asap?Bill has been one of the best owners I have worked with, Just wish we started the project with Bill from the start. Evade is starting to come along well THANKS for all your help on getting us back on track with motor mount. The sub frame is KILLER.
I'll send you a set of wheels,do you like oak or cherry wood...:)
Thanks again,
Tom Argue
Hydroillusions.com
Tom Argue Design.com
scogin918
12-30-2008, 07:25 PM
Engine looks killer. I like the the paint on the block. Nice touch.
68/CamaroFL
01-01-2009, 09:00 AM
Here are Current Pictures of the Undercarriage
https://static1.pt-content.com/images/pt/2009/01/Picture001-1.jpg
Undercarriage Tunnel
https://static1.pt-content.com/images/pt/2009/01/Picture002-1.jpg
Rear Undercarriage with Chris Alston's New G-Bar
here is a pic of the Kit for the Chris Alston g-Bar/g-Link Rear Suspension
https://static1.pt-content.com/images/pt/2009/01/5804M10_AT-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture0051-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture003-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture0041-1.jpg
1971CHEVELLE
01-01-2009, 09:09 AM
:1st:this car is going to be awesome. Good work
Simbad68
01-01-2009, 09:35 AM
The undercarriage looks great. Is that the U-Pol Raptor Liner?
T_Raven
01-01-2009, 10:19 AM
SKEET SKEET SKEEEET!!!!!!!!!!!
And girls wonder why I ignore them to surf these boards LMAO!!
KAILUAZ
01-01-2009, 05:53 PM
Great looking project!!
KnightMare
01-01-2009, 09:47 PM
I cant stop looking at that intake!
68/CamaroFL
01-02-2009, 07:46 AM
Yes it is! U-Pol Raptor Liner!
Simbad68
01-02-2009, 12:05 PM
I've read alot of people stripping the pan down to bare metal then applying the raptor. Can it be applied over Epoxy with the same results? The car looks great!!! We need more pics!!
syclonetommy
01-07-2009, 07:36 AM
Sent you a pm.
Tom
killer69
01-07-2009, 07:28 PM
[quote=syclonetommy;475420]Blake, antispatde finish date asap?Bill has been one of the best owners I have worked with, Just wish we started the project with Bill from the start. Evade is starting to come along well THANKS for all your help on getting us back on track with motor mount. The sub frame is KILLER.
Thanks again,
Yea it sounds like Bill now has the right guy on the job, hahaha
glad we could help out.
Bill has been a great customer from our end also
AND where do you get the raptor liner???
syclonetommy
01-09-2009, 06:17 PM
Thanks again,
I buy the raptor liner from a local ppg paint supplier.
Just got the update part for the sub frame "killer" mounts
Tom Argue
68/CamaroFL
01-11-2009, 07:04 AM
Here are a few updates Tom Installed the Strange-60 rear end and Chris Alston's Chassisworks Camaro g-Bar Suspension upgraded the Lower bars to the "Pivot Ball Lower Link" and added Sliding-Link 5/8”-diameter Adjustable Anti-Roll sway bar.
Installed Ricks Tank and ran the fuel rail see pics Also We are test fitting the "Stainless Works" 3' Exhaust !:razz:
https://static1.pt-content.com/images/pt/2009/01/Picture009-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture0081-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture004-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture013-1.jpg
Stainless steel Fuel Rail
https://static1.pt-content.com/images/pt/2009/01/Picture015-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture021-1.jpg
Also Tom Finished the Katech Valve Covers to match Intake
https://static1.pt-content.com/images/pt/2009/01/Picture024-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture025-1.jpg
BMF Machine
01-11-2009, 09:56 AM
OOOOOOOO AAAAAHHHHHHHHHH, that engine looks SweeT!:yum:
icebird84
01-11-2009, 10:03 AM
indeed
I love it
Brian46
01-11-2009, 12:58 PM
Yes it is! U-Pol Raptor Liner!The raptor liner looks way better than what was used on my car... It looks like it goes on quite thin and shows the contours of the work underneath very well.
Does it require/come with a special sprayer for the liner?
syclonetommy
01-11-2009, 03:58 PM
Does it require/come with a special sprayer for the liner?he
play with the psi and distance @ the gun to come up with the look you want. The raptor kit come's with a gun.
Car has 3 coats on the bottom, it's ??? 5-7 mil
Should work good for some sound damping?
Tom
Brian46
01-11-2009, 11:19 PM
he
TomIt looks like a good product, I have Linex on one of my trucks and Rhino liner on another, this looks like a similar texture and shows the quality of the work underneath quite well.
The stuff that was used on my car however looks like it was thrown on with a spoon and very rough texture, I used a mil build guage on it and it is beyond it's limits (75 mil) so I think something was hidden underneath the coating.
Thanks for the info, I will be sure to consider this after I get the goo stripped of my car.
Thanks, Brian
68/CamaroFL
01-14-2009, 07:02 AM
Test fitting Carbon Fiber Hood & Valence from Anvilauto thanks to Matt!
https://static1.pt-content.com/images/pt/2009/01/Picture011-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture005-2.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture0081-2.jpg
https://static1.pt-content.com/images/pt/2009/01/Picture012-1.jpg
Iamtheonlyreal1
01-14-2009, 07:06 AM
Project is coming along beautifully.. I guess I better get off my ass...LOL
68/CamaroFL
01-14-2009, 07:20 AM
Well i guess you better! LOL
Thanks Robert!
Iamtheonlyreal1
01-14-2009, 03:51 PM
Have a guy working on the crate this weekend, should be able to get it to you this next week, hopefully that will work.
syclonetommy
01-14-2009, 04:34 PM
Sounds Good...,
Tom
68/CamaroFL
01-15-2009, 06:58 AM
Excellent! Thanks Robert
FirstGenZq8
01-15-2009, 07:04 AM
purdy wheels :drool:.
fiske? i can't tell...
68/CamaroFL
01-15-2009, 07:16 AM
Boze-Forged "Mesh"
68/CamaroFL
01-18-2009, 06:39 AM
Here is the Front Carbon Fiber Spoiler from Brian @ Screamin' Performace
https://static1.pt-content.com/images/pt/2009/01/IMG_3764-1.jpg
Also Received on Friday Prodigy Customs Cool Package LSX radiators Thanks Frank!
https://static1.pt-content.com/images/pt/2009/01/6769camaroLS1FS-1.jpg
cdoggy81
01-18-2009, 05:00 PM
"Prodigy Customs Cool Package LSX radiators"
Those look good. Tell me more about them. What years do they fit & how much $$$
68/CamaroFL
01-19-2009, 05:32 AM
Check out Frank's Thread here https://www.pro-touring.com/forum/showthread.php?t=51438&highlight=radiators
67speedfreak
01-19-2009, 05:45 AM
Car is lookin great man.
BMF Machine
01-19-2009, 09:44 AM
Gett'n better every day! I can't wait to see what ya have in-line for the interior! Carbon looks beautiful as always; AnviL must be the ShiZZ!:)
1971CHEVELLE
01-19-2009, 10:04 AM
This build is awesome; can't wait to see more (http://i700.photobucket.com/albums/ww1/wpano/January%2013%202009/Picture007-1.jpg)
icebird84
01-19-2009, 10:42 AM
indeed
68/CamaroFL
01-20-2009, 07:44 AM
Test fitting Trunk
Anvilauto CF Deck lid
https://static1.pt-content.com/images/pt/2009/01/Picture0041-2.jpg
r.a.w.rods
01-20-2009, 04:49 PM
wow looks great!!
T_Raven
01-21-2009, 11:25 PM
How do you like those trunk hinges? I was thinking about getting them
68/CamaroFL
02-14-2009, 06:35 AM
Here are some current updated pics on Evade Front clip on and fitting adjustments How about that CF Hood From Matt @ Anvilauto
https://static1.pt-content.com/images/pt/2009/02/Picture051-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture050-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture045-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture064-1.jpg
A Sneak peek of Engine Compartment
https://static1.pt-content.com/images/pt/2009/02/Picture028-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture032-1.jpg
Peek at the rear with Chris Alston's G-Bar and Ricks Tank
https://static1.pt-content.com/images/pt/2009/02/Picture069-2.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture070-2.jpg
68/CamaroFL
02-14-2009, 06:46 AM
Carbon Fiber-Deck-Lid Anvilauto
https://static1.pt-content.com/images/pt/2009/02/Picture055-1.jpg
Vegas69
02-14-2009, 08:51 AM
One of the trickest looking LSX motors yet.
GHOSTDANCER
02-14-2009, 11:04 AM
Wicked :cheers:
paul67
02-14-2009, 11:52 AM
Great looking car ,what size wheels and tyres are you using.
68/CamaroFL
02-14-2009, 12:31 PM
For now this is what is on.. maybe change??
WHEELS: BOZE ZE FORGED Mesh Wheels
Front 18 x 8 with 4.75 Back Spacing
Rear 18 x 9 with 5.25 Back Spacing
TIRES:Nitto Invo Tires
Front 245/40/18
Rear 275/40/18
68/CamaroFL
02-18-2009, 03:12 PM
Well we just finished installing the (Flush Mount Glass System) by Classic Auto Glass Innovations! Thanks to Robert (Iamtheonlyreal1) here on Pro-Touring.com was able to get a set of Flush Mount Glass to us!
Guys this glass system is Excellent the pictures don’t do it justice in person it’s beautiful! If you’re looking to install yourself please I suggest contacting your local Auto Glass Company like I did it, and One phone call to Robert made it easier to install, Frank from C Thru Glass our local Glass installer stated it is an excellent product for updating the fist gen Camaro’s it took about 3 hrs from start to finish.
Take a look!
https://static1.pt-content.com/images/pt/2009/02/Picture010-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture008-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture042-2.jpg
Inside Rear Glass
https://static1.pt-content.com/images/pt/2009/02/InsideRearGlass-1.jpg
https://static1.pt-content.com/images/pt/2009/02/InsideRearGlass2-1.jpg
Front Windshield
https://static1.pt-content.com/images/pt/2009/02/Picture015-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Picture018-1.jpg
Will Post more Pictures when Completed
Motown 454
02-18-2009, 09:57 PM
It looks good , fits nice and tight.
Vegas69
02-18-2009, 11:19 PM
I have to say I'm not sold on the flush mount glass. It changes the proportions of the body. It does look to fit nice though.
icebird84
02-19-2009, 03:03 AM
the new one looks cleaner
https://static1.pt-content.com/images/pt/2009/02/normal-1.jpg
colt zantop
02-20-2009, 10:58 AM
looks great so far!! keep those pics coming!
sharpie
02-20-2009, 11:25 AM
So why, pray tell, are you doing a $$$$$ build yet not even fixing that swiss-cheesed package tray?
68/CamaroFL
02-21-2009, 05:03 AM
:secret:
I Have a Custom Built Package tray for rear speakers and ported sub-box and tube you will see when finished
LT4POWR
02-21-2009, 07:30 AM
wow...awesome build!!!
tillman
02-21-2009, 12:05 PM
Looks great!!! What is the undercarriage sprayed with?
68/CamaroFL
02-21-2009, 12:21 PM
U-Pol Raptor Liner
68/CamaroFL
02-26-2009, 05:30 AM
Ok Here is the Package tray and rear seat area
Covererd with sound deadening No Swiss cheese!
https://static1.pt-content.com/images/pt/2009/02/IMG_0998-1.jpg
https://static1.pt-content.com/images/pt/2009/02/IMG_100011-1.jpg
syclonetommy
02-26-2009, 03:18 PM
It was not Swiss cheese!...It was good america cheese.
Thank god me and the guys are not lactose intolerent.
Tom
NVR2L8
03-04-2009, 09:44 AM
This is OFF TOPIC,
I purchased a rear Sway Bar from Bill, and he promptly sent it out. No hassle, no problems. He stood behind his word. I would purchase from him again without hesitation.
If this can be moved to the correct location, Thank You.
Marc
68/CamaroFL
03-29-2009, 05:15 AM
Special thanks to Zak Kingsland @ Boze Alloy's for getting me the rear wheels in (Pro-Touring Mesh) 19 X 10
https://static1.pt-content.com/images/pt/2009/03/BozeRearWheel-1.jpg
https://static1.pt-content.com/images/pt/2009/03/BozeRearWheel1-1.jpg
Also Tom is finishing up the wiring harness on the engine special thanks to John @ Speartech! **please not orange tape not incuded LOL
https://static1.pt-content.com/images/pt/2009/03/LsEngine2-1.jpg
https://static1.pt-content.com/images/pt/2009/03/LsEngine3-1.jpg
https://static1.pt-content.com/images/pt/2009/03/LsEngine-1.jpg
Code Red
03-29-2009, 07:02 AM
extremely sexy car
CruizinKev
03-29-2009, 08:18 AM
extremely sexy car
x2 really is :twothumbs
Moabdude
03-29-2009, 11:32 AM
19x10"?
nice!
No mini tubs right?
What Backspacing do you have and what tires are you going to run?
69sleeper
03-29-2009, 05:27 PM
That car is absolutely sick!!!!! :jawdrop:
srh3trinity
03-29-2009, 06:02 PM
Nice wheel choice and the engine looks great.
68/CamaroFL
03-30-2009, 10:13 AM
19x10"?
nice!
No mini tubs right?
Rear 19 X 10 with 5.5 Backspacing 275/35ZR-19 BFGoodrich g-Force T/A KDW 2
No Mini Tub
Bozeforged
03-30-2009, 03:30 PM
Hey Bill, Thanks for the compliments. I'm glad I could help you out.
Zak
www.bozeforged.com (http://www.bozeforged.com)
68/CamaroFL
04-01-2009, 08:46 PM
We Mounted the Front and Rear tires today
Rear 19 X 10 with 5.5 Backspacing and the 275/35ZR-19 BFGoodrich g-Force T/A KDW 2
https://static1.pt-content.com/images/pt/2009/04/1RearWheel2753519-1.jpg
https://static1.pt-content.com/images/pt/2009/04/2RearWheel2753519-1.jpg
https://static1.pt-content.com/images/pt/2009/04/4RearWheel2753519-1.jpg
Here are the fronts 18 X 8 245/40ZR-18 BFGoodrich g-Force T/A KDW 2
https://static1.pt-content.com/images/pt/2009/04/FrontWheels-1.jpg
CruizinKev
04-02-2009, 09:14 AM
:worship: :twothumbs
Mr.VENGEANCE
04-02-2009, 09:17 AM
that thing is gonna be really nice..
BossaNova
04-02-2009, 05:46 PM
Man, those wheels are beautiful! Great choice!
icebird84
04-03-2009, 05:03 AM
https://static1.pt-content.com/images/pt/2008/11/2301-1.gif Love it
1971CHEVELLE
04-03-2009, 05:35 AM
Wow... I love how that looks,wheels look amazing on there
68/CamaroFL
04-04-2009, 08:11 AM
Installing Unisteer complete rack and Steering Shaft w/Column Bearing from Speed Tech Performance
Blake and Roger are Great to work with! The Best customer service bar-none!!
https://static1.pt-content.com/images/pt/2009/04/Picture023-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Picture021-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Picture026-1.jpg
Also Installing Clutch Master Cylinder from Keisler Engineering T-56 Kit
https://static1.pt-content.com/images/pt/2009/04/Picture014-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Picture015-1.jpg
Mock up the DSE Closeout panel!
https://static1.pt-content.com/images/pt/2009/04/Picture034-1.jpg
Tires Mounted and balanced check out the stance
https://static1.pt-content.com/images/pt/2009/04/Picture028-1.jpg
68/CamaroFL
04-10-2009, 07:04 AM
Special Thanks to Tyler @ ATS he was able to get me a set of his Coil mounts! We installed them on the inside of the SpeedTech Subframe check out pics!
https://static1.pt-content.com/images/pt/2009/04/ATSCoilMounts-1.jpg
Drivers Side
https://static1.pt-content.com/images/pt/2009/04/DriveSideCoils-1.jpg
Pass-Side
https://static1.pt-content.com/images/pt/2009/04/PassSideCoils-1.jpg
Here it is Wired up!
https://static1.pt-content.com/images/pt/2009/04/IMG_1144-1.jpg
Motown 454
04-10-2009, 02:39 PM
You have an awesome project the coils look great there. The whole car is awesome!
icebird84
04-12-2009, 01:45 PM
Excellent work :1st:
68/CamaroFL
05-31-2009, 07:53 AM
Tom is Installing and relocating Parking brake in the center side console along with cables
https://static1.pt-content.com/images/pt/2009/05/IMG_0127-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0084-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0087-1.jpg
Now Running the Fuel Line with new clips to hold looks like it's Floating along the under carrage
https://static1.pt-content.com/images/pt/2009/05/IMG_0076JPG2-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0104-1.jpg
68/CamaroFL
05-31-2009, 08:03 AM
Special Thanks to Justin @ Wilwood was able to help us out to upgrade Calipers to the Six Piston
Rear
https://static1.pt-content.com/images/pt/2009/05/IMG_0102-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0122-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0121-1.jpg
Front
https://static1.pt-content.com/images/pt/2009/05/IMG_0099-1.jpg
Installing Brake Lines and proportioning valve
https://static1.pt-content.com/images/pt/2009/05/IMG_0080-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0105-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0082-1.jpg
A Sneak peak under the LS-2 Motor and Tremic TKO600 Trans Kit from Keisler Engineering
https://static1.pt-content.com/images/pt/2009/05/IMG_0094-1.jpg
Tom Finishing up Polishing the Speedtech-Stainlessworks Headers and Exhaust 3' X pipe to the mufflers and 2.5 Over the rear axle, Tom Custom cut so it would clear the Chris Alston's Rear link Suspension
https://static1.pt-content.com/images/pt/2009/05/IMG_0116-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0110-1.jpg
https://static1.pt-content.com/images/pt/2009/05/IMG_0125-1.jpg
68/CamaroFL
05-31-2009, 08:29 AM
Look what else came in Ring Brothers New Hood Hinges Thanks Jim!
https://static1.pt-content.com/images/pt/2009/05/1238694116_6056910067_69_Camaro_blk-1.jpg
CamaroJesse
05-31-2009, 08:37 AM
I love the black with all the carbon fiber! I was going to do the same thing but im worried what it would look like with my orange. Nice car!
68/CamaroFL
05-31-2009, 08:52 AM
Thanks Jesse -->The CF with Orange would look Bad A$$
68/CamaroFL
05-31-2009, 08:53 AM
Tom is also finishing covering the wiring harness!
https://static1.pt-content.com/images/pt/2009/05/IMG_0119-1.jpg
67speedfreak
05-31-2009, 09:17 AM
Lookin good brother !
rsk68
06-01-2009, 09:04 AM
very nice build Bill.
68/CamaroFL
06-01-2009, 11:14 AM
Just received the replacement glass from (Flush Mount Glass System) by Classic Auto Glass Innovations! Thanks to Robert the other glass was a test fit.
https://static1.pt-content.com/images/pt/2009/06/IMG_0131-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0135-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0137-1.jpg
RodDawg
06-01-2009, 12:45 PM
This thread has cost me lots of $$$$$, j/k. Very nice and tasteful scheme!!! This is the first thread that I have ever subscribed to. Other than the lack of mini tubs and CF, seems to be similar to the direction of my '67.
BAD ASS!!!!!!!!!!!! :twothumbs
NOPANTS-68
06-01-2009, 01:30 PM
awesome job on the car so far. Love the coil mounts and where you have them located. Nothing room-wide like that on my stock stub, so I'm jealous. Very sharp.
68/CamaroFL
06-04-2009, 05:49 AM
Dave,
Speed Tech has a Subframe that would work for you!
here is there Link http://www.speedtech-performance.com/index.cfm/page/ptype=results/category_id=222/home_id=222/mode=cat/cat222.htm
KeislerGene
06-04-2009, 08:13 AM
Dave,
Hey I just realized I did see this thread before. Even though I told you I didn't. Good looking Challenger :rotfl: J/K cant wait to see it finished!!!
ROACHZ28
06-04-2009, 06:05 PM
Sweet! Your exhaust looks like a work of art.:)
SamHatco
06-04-2009, 07:19 PM
Do I detect a GTO parking brake?
Awsome build. :1st:
Sam
68/CamaroFL
06-06-2009, 07:39 AM
We decided to use products from Heatshield Products covering the fuel lines with Black Colored Sleeve coatings make it capable of withstanding 1200°F continuous so we don't have vapor lock issues, Also covering the brake lines was a must take a look
https://static1.pt-content.com/images/pt/2009/06/IMG_0156-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0160-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0158-1.jpg
Rear Brake Lines
https://static1.pt-content.com/images/pt/2009/06/IMG_0154-1.jpg
Plastic stand offs
https://static1.pt-content.com/images/pt/2009/06/quickclip-1.png
https://static1.pt-content.com/images/pt/2009/06/IMG_014411-1.jpg
Rear Braided Brake Lines
https://static1.pt-content.com/images/pt/2009/06/IMG_0143-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0147-1.jpg
Gas Tank in!
https://static1.pt-content.com/images/pt/2009/06/IMG_0153-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0177-1.jpg
68/CamaroFL
06-06-2009, 07:49 AM
Finishing installing front braided brake lines and hard line, Also installing the Safety Wire on Wilwood Rotors and Calipers
https://static1.pt-content.com/images/pt/2009/06/IMG_0162-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0164-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0165-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0166-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0167-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0171-1.jpg
syclonetommy
06-14-2009, 07:03 AM
Gene, Thanks for all your help.
Great product, With out standing Customer Service!
Parts will ship back to you next week
Tom Argue
68/CamaroFL
06-14-2009, 07:23 AM
Tom finishing installing the Tank from Ricks Tanks! and the single line fuel filter regulator on a custom bracket that Tom made on the tank
https://static1.pt-content.com/images/pt/2009/06/IMG_0189-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0179-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0187-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0180-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0191-1.jpg
Received the drive shaft and installed with the safety loop
https://static1.pt-content.com/images/pt/2009/06/IMG_0192-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0184-1.jpg
68/CamaroFL
06-14-2009, 07:48 AM
Painted the Diff Cover black looks better!
https://static1.pt-content.com/images/pt/2009/06/IMG_0199-1.jpg
68/CamaroFL
06-14-2009, 08:07 AM
Plastic Stand offs are in the front brake lines (Received them from Joe McCullough) They can be purchased from kdhotrods.com
https://static1.pt-content.com/images/pt/2009/06/IMG_0196-1.jpg
Motown 454
06-15-2009, 11:58 AM
Looks great..
Young Gun
06-15-2009, 02:43 PM
looks great!
syclonetommy
06-16-2009, 04:23 PM
Well as of today 4:30 pm project "Evade" has a pulse.
Tommorow she's comes Alive!
Tom Argue
Ripped
06-16-2009, 06:15 PM
Lots of eye candy on what's usually the 'dirty' side. Nice job!
Iamtheonlyreal1
06-16-2009, 06:22 PM
You guys have alot more patience than I do... I would have had to work through the night to hear it run if I was that close...LOL I guess that is why the car looks so good, you guys can wait for the Reward and Satisfaction.. Great Job
syclonetommy
06-17-2009, 04:44 PM
Thanks Robert,
Well patience is everthing, One more day of life support before she comes alive.
Should have the Production set of glass you sent, installed next week. The package looks Awsome.
Tom Argue
67speedfreak
06-17-2009, 05:37 PM
Tom,
Car looks great!
syclonetommy
06-18-2009, 01:12 PM
She has a heart beat, got to love fuel injection! lit on the frist try.
I think Bill might have to change his pants.
Tom Argue
69LT1Nova
06-18-2009, 01:32 PM
Bah! Don't you know that its a requirement on P-T.com to have a video of the car the first time you light her up!?!?!?! :slap:
syclonetommy
06-18-2009, 03:50 PM
I think Bill's working on it.
tom
68/CamaroFL
06-19-2009, 07:39 AM
Many Thanks to Jim @ StainlessWorks to help us with the exhaust system, Tom Custom made the tail pipes to run through the new Chris Alston's G-Bar rear suspension! Also Steve Heye from Heat Shield Products was able to hook us up with there Lava Wrap Tom wrap the tail pipes so we would not have any issues with vapor lock. Check it out!
https://static1.pt-content.com/images/pt/2009/06/IMG_0201-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0202-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0204-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0206-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_0210-1.jpg
68/CamaroFL
06-19-2009, 08:59 AM
Here is "Evade"s first start! sorry my video camera is on the frits
ZFhe6qjdua8
s-Th918Qmw0
NOPANTS-68
06-19-2009, 11:06 AM
awesome dude! congrats! That's a monster step.
Just fired my LS last night!
69LT1Nova
06-19-2009, 01:31 PM
Ughhh!! That is SICK! Love the exhaust system. Thanks for the video! :)
RodDawg
06-28-2009, 06:54 PM
Hey Bill.
Got any new videos or pics?
68/CamaroFL
07-04-2009, 04:09 AM
He Guys! Project "Evade" in July's Camaro Performers magazine page 13 check it out! Many Thanks to Ben Hermance, Nick and Steve from Camaro Performers
https://static1.pt-content.com/images/pt/2009/07/FridayJuly032009-1.jpg
https://static1.pt-content.com/images/pt/2009/07/FridayJuly0320092-1.jpg
68/CamaroFL
07-04-2009, 04:17 AM
Roger from Speed Tech was able to get Paul that works with him to get this sign made for us for the Goodguys show in Columbus O.H.
https://static1.pt-content.com/images/pt/2009/07/EVADEFINAL-1.jpg
68/CamaroFL
07-04-2009, 04:22 AM
Guy's Sorry no more pics!
"Evade" will debut @ the Goodguy's show in Columbas O.H. July 10-12th
@ Stainlessworks booth!!!
https://static1.pt-content.com/images/pt/2009/07/swnewlogosmall-1.jpg
68/CamaroFL
07-08-2009, 01:30 PM
Ok The secret was that The man behind all the Big Builds came to Fl is Bob Thrash! To lay out the design for Evade!
https://static1.pt-content.com/images/pt/2009/07/IMG_0317-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0322-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0303-1.jpg
68/CamaroFL
07-08-2009, 01:44 PM
Project "Evade" is on its way to Columbus for the GoodGuy's Show!!!
https://static1.pt-content.com/images/pt/2009/07/IMG_0399-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0393-1.jpg
67speedfreak
07-08-2009, 04:30 PM
Bill,
Any interior shots ? Looks good.
Brian
FirstGenZq8
07-08-2009, 04:32 PM
<- jaw is officially dropped, spit dripping out :drool:
slck6t9
07-08-2009, 05:34 PM
VERY nice!!! The hood scheme looks similar to Larry's Motiv8r. I like it..
HILLBILLY68
07-08-2009, 11:02 PM
I'll see you this weekend, great job!
Mr.VENGEANCE
07-09-2009, 12:11 AM
siiick my boy.. sick!
SamHatco
07-09-2009, 06:09 AM
Awsome! I just wish mine was done. Great job on the build and the magazine spread. :1st:
Sam
silverdenali22
07-09-2009, 04:18 PM
Sick car. Looks good!
Bozeforged
07-10-2009, 11:14 AM
Bill,
Your Car looks Great! I'm glad we could be part of the build. Good luck at the show.
Zak
68/CamaroFL
07-13-2009, 08:23 AM
Well Guys here is Evade in Columbus @ they Goodguys Show! Special Thanks to Stainlessworks! Wow what a blast we had it was a pleasure to meet and talk to everyone there !! enjoy pics!
https://static1.pt-content.com/images/pt/2009/07/IMG_0520-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0426-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0428-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0390-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0421-1.jpg
Taking off to go to the Autocross!
https://static1.pt-content.com/images/pt/2009/07/IMG_0476-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0478-1.jpg
https://static1.pt-content.com/images/pt/2009/07/IMG_0479-1.jpg
RodDawg
07-13-2009, 08:28 AM
Very, very nice work.
Enjoy it now!!!!!!!
I hope to see the car in person...maybe at RTTH?
1968CamaroSS_Sam
07-13-2009, 12:33 PM
Very nice looking ride. Great job.
dmc69
07-13-2009, 07:04 PM
That is hot! Looks even better than I expected. Congrats!
Motown 454
07-13-2009, 08:08 PM
Looks Great...
dat16v
07-14-2009, 03:33 AM
Love the Monaro/GTO center console!
platniumta
07-14-2009, 07:17 PM
Very nice car. Lots of cool ideas.
progoat
07-14-2009, 08:02 PM
Car was awsome Bill! the only thing that would have been better would have been a ride..haha
camaro2nv
07-14-2009, 08:07 PM
Great job on the car, you should be proud! The CF looks very nice the way it was worked in.
Moabdude
07-15-2009, 12:34 AM
Very very nice ride!!!
Congratulations. I know what is is to accomplish your dream car.
More pictures of the dash and center console please.
I love that center console:yum:
68/CamaroFL
07-15-2009, 05:43 AM
My first Autocross with "Evade" Wow what an experience didn't do to bad although #1 did not get a chance to dial in the motor #2 did not get a chance to align the car but here are the times "Evade" ran , Bill – 1968 Camaro – Lap Times 39.579, 36.457, 36.081 the third lap she drifted on me What a Blast!!! Met with Steve Rupp many thanks Steve for the conversations we had! i found these shots on http://www.hotrodhotline.com/feature/2009show/09ggcolumbusaljuly10/html/page_8.php
https://static1.pt-content.com/images/pt/2009/07/db_GG_NATS_F_S_09__632_1-1.jpg
https://static1.pt-content.com/images/pt/2009/07/db_GG_NATS_F_S_09__633_1-1.jpg
Bozeforged
08-11-2009, 02:51 PM
Hey Bill,
I just posted your car on our blog. Check it out at:
http://www.bozeforged.com/blog/
Zak
68/CamaroFL
08-11-2009, 07:21 PM
Hey guys Check out the Septembers Issue of Camaro Performers Magazine! Thanks to Ben Hermance wrote an article and "Evade" the Rendering covers two pages 16 and 17! It looks Wicked! Thanks Nick, Steve and Ben! :twothumbs
https://static1.pt-content.com/images/pt/2009/08/CamaroPerformersSept09-1.jpg
LSfan70s
08-11-2009, 07:38 PM
best interior ever ever ever....!!!!
67 ls1 vert
I may have missed it somewhere in your posts but I see that you have the look of carbon fiber on the rear panel under the rear window. Is that some kind of over lay or paint to look like it or something?
BTW, great job on your cool camaro.:1st:
72camaross
08-12-2009, 05:58 AM
this car is awesome!! That interior is exactly how I've always pictured mine but never knew how I was going to do it!! someone above mentioned GTO console...I'm going to have to look into that!!
Great car! Glad to see you driving it like you stole it!
Moabdude
08-12-2009, 06:01 AM
More pics of the center console please.
68/CamaroFL
08-13-2009, 06:26 AM
What Tom did was painted the Metallic gray and faded it onto the carbon fiber decklid !
Thanks for your comments!
Bill
daryld
09-12-2009, 06:01 AM
Could you post pics of the other cars at the autocross? Looks like there were a number of nice rides there. Your car looks awesome and top of the line quality work I might ad. Enjoy!
colt zantop
09-12-2009, 07:10 AM
wow! awesome car...awesome interior!
Steve1968LS2
09-12-2009, 07:58 AM
December issue of Camaro Performers Magazine..
Just saying.. :)
Iamtheonlyreal1
09-12-2009, 08:08 AM
Hey Steve, I have been very lazy or too busy (not sure which one) to subscribe. But when do the new issues normally hit the news stands? Our area is kind of hit or miss on whether or not an issue will be offered.. Some months are offered, the the next month or months are skipped.. Just wondering if the November issue is out yet?
It is a great Magazine, and I am embarrassed to say that I do not have a subscription.. But, I promise to work on that..
68/CamaroFL
09-12-2009, 08:19 AM
Hey guys! sorry its been a while posting but we have been busy touching up minor things on "Evade" we got her on the Dyno last week! with a Great help from Jeremy Formato with Fasterproms!
Here are some Pictures will post the updated Video! next thread
https://static1.pt-content.com/images/pt/2009/09/200909051423462-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051340111-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051411251-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051339391-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051338282-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051448331-1.jpg
https://static1.pt-content.com/images/pt/2009/09/200909051448332-1.jpg
Iamtheonlyreal1
09-12-2009, 08:24 AM
It says it is a private video... Damn, I was looking forward to hearing it..
68/CamaroFL
09-12-2009, 08:32 AM
Hold on Working on it to upload again!
Bill
68/CamaroFL
09-12-2009, 10:04 AM
"Evade" we got her on the Dyno last week! with a Great help from Jeremy Formato with Fasterproms to Dial here in!
Check out the Video! Crank it up!
nNxomMuiTZQ
Got it!
http://www.youtube.com/watch?v=nNxomMuiTZQ
Vicinity
09-12-2009, 04:43 PM
Oh my god. I love this car.
68/CamaroFL
09-13-2009, 06:09 AM
Daryl,
Here is a link of the cars in the autocross:
68/CamaroFL
09-13-2009, 06:59 AM
Here are the Dyno Sheets for HP and Torque also look @ the Temps! the 5th run we ended up with 430.25hp @ the rear wheels and the Temp was @ 99.51-Degrees !
https://static1.pt-content.com/images/pt/2009/09/DYNOMAXHP-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DYNOMAXTORQUE-1.jpg
mroth
09-30-2009, 07:05 AM
That is a great looking pulley system that you have on the new motor.
Chris 68
09-30-2009, 12:40 PM
Where abouts in Fl are you located? I'm in the Cape Coral/ Fortmyers area currently putting an ls2 in my 68 (https://www.pro-touring.com/forum/showthread.php?p=580437&posted=1#post580437) and would love to see this thing person! Also how much was it to get your car on the dyno and tuned? BTW awesome set up! And how bad is that black paint in the sun? I'm debating on color since paint is around the corner and i love the black!
796spdbu
09-30-2009, 06:52 PM
beautiful car! I remember seeing it at columbus. Nice attention to detail!
68/CamaroFL
10-01-2009, 05:17 AM
Chris I'm in St.Pete Fl. Jeremy Formato with Fasterproms here is his web site http://www.fasterproms.net/services.html
as far as the Black I carry with me alot of microfiber towels :seizure:
Jarcaines
10-01-2009, 05:42 AM
This is one of my favorite cars, well done.
Moabdude
10-01-2009, 10:05 PM
More dash/center console pics please please please
Is Evade going to SEMA?
68/CamaroFL
10-02-2009, 05:59 AM
Will post some pics soon!
Special Thanks to Blake and Roger from Speedtech!
Yes "Evade" will be at SEMA!!
canadian
10-03-2009, 03:41 PM
Fantastic build...
If there's anybody who's a stickler for details, it's Tom. If you have a chance, check out how clean his Typhoon is.
syclonetommy
10-09-2009, 12:17 PM
Fantastic build...
Thanks, Is that,.. warren????
compos mentis
10-16-2009, 09:51 AM
X2 :twothumbs
SDS MACHINING
10-16-2009, 03:37 PM
love everything about this car, especially the interior.
68/CamaroFL
10-28-2009, 06:18 AM
Special Thanks to Jim & Staci here are the Door Handles Installed on "Evade" Tom Polished Handles and beed Blasted the Outer piece & Button! --> Heading for SEMA!
https://static1.pt-content.com/images/pt/2009/10/IMG_1364-1.jpg
https://static1.pt-content.com/images/pt/2009/10/IMG_1366-1.jpg
https://static1.pt-content.com/images/pt/2009/10/IMG_1357-1.jpg
Tom Installed the Clayton Machine Works New Pedals!! Thanks Clay and Ron from Hood Pins
https://static1.pt-content.com/images/pt/2009/10/IMG_1347-1.jpg
https://static1.pt-content.com/images/pt/2009/10/IMG_1345-1.jpg
windsor
10-28-2009, 05:08 PM
Good luck there. Seen the car in person and it's saweet! Tom did a great job and is a top notch builder.
68/CamaroFL
11-11-2009, 10:06 AM
It was with Great pleasure to meet some of the members here I had a great time! and a special thanks to Blake and Roger with Speedtech Performance! for "Evade" to be Featured at SEMA.
Here is a couple of Pics of "Evade" @ SEMA
https://static1.pt-content.com/images/pt/2009/11/IMG_0614-1.jpg
https://static1.pt-content.com/images/pt/2009/11/IMG_0625-1.jpg
https://static1.pt-content.com/images/pt/2009/11/IMG_0621-1.jpg
https://static1.pt-content.com/images/pt/2009/11/IMG_0619JPGAAA1-1.jpg
https://static1.pt-content.com/images/pt/2009/11/IMG_0618JPGAAA1-1.jpg
Moabdude
11-11-2009, 09:52 PM
Nice carpet there in Vegas :)
I also saw Evade live at the SEMA and I was astonished by the details and perfection of the build.
It was nice meeting you and again my compliments Bill!:1st: (and of course also for Tom)
Bram
oestek
11-24-2009, 10:41 AM
This car is sick. Love it. We're already taking some ideas like the heat shield wrap on the lines... looks killer. Great job guys!
I was fortunate enough to see the car in person at SEMA, very nicely done.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
devin_22
01-24-2010, 02:14 PM
I've been a big fan of your project since i saw it in Camaro magazine for the first time. I also saw it at SEMA show and was amazed. It came together extremely well.
gold79ta
01-24-2010, 05:37 PM
Hey, What size are those model T rims you have on there?
Bet it is a pretty harsh ride with wooden wheels.
LOL
68/CamaroFL
01-25-2010, 07:04 AM
Thanks Devin for your comment any questions let me know
Bill P
68/CamaroFL
01-25-2010, 07:05 AM
Here is an ad that just came out on the news stand in Hot Rod Magazine March Issue
https://static1.pt-content.com/images/pt/2010/01/TREMEC_HotRod_0310-1.jpg
Iamtheonlyreal1
01-25-2010, 07:12 AM
WOW.....Congrat's Bill That is quite an accomplishment..
progoat
01-25-2010, 10:32 AM
WOW thats sweet your car pulled the Tremec ad Bill it is a sweet ride though:1st:
syclonetommy
01-25-2010, 11:27 AM
LOL
27 X1 zr frt
29X1 zr rear
Tom
68/CamaroFL
02-08-2010, 08:12 AM
Winter National 2010 Hosted by Classic Camaro of Central Florida!
I didn’t think we would make it as of last week on Tuesday Tom Argue’s Baby Daughter went to the hospital having breathing difficulty with a viral infection I told Tom listen your family is more important we do not have to go! But Tom was insisted and said don’t worry my wife will be at the hospital I’ll get “Evade” there….He said the car Must be there!! I drove over early Thursday afternoon and Tom left Thursday night from the hospital Trailerd the car and made to Coco beach @ 1 AM! Friday We got up Friday morning very little sleep unloaded the car and @ 6:30 in the morning Tom left the trailer and headed back to St. Pete at the hospital my thoughts and prayers were with them! In is absent from the show Tom sent one of is employee’s over to help me with the show! Finally on Saturday his daughter was released from the hospital and is doing well Thank God! Tom Argue is dedicated to his customers 100% I will never forget this! I feel like part of the Argue family! Many Thanks Tom & Susan! "Tom Argue Design"
Eckler’s Chevy Classics and Worldwide Camaro Club took it to the Coco beach!
I think there were almost 300 cars there! This was a 1000 point judging 3 judges tearing apart and going all over the car! Body exterior, Paint, Engine & Engine compartment, Driveline & Suspension, Under carriage, Trunk & Cargo area, Wheels & Tires!
First 25 points (Tech-Check) are judged in a tech inspection looking for everything that is working! Head lights, high beams, turn signals, flashers, in the dash indicators, brake lights, back up lights, lic-plate light, dome light, pwr windows, cigar lighter and glove box light ect.
All said and done Project “Evade” Won (4) Awards! @ The 18th Annual Winter National and scored “995”
# (1) Award "Trailered Custom Camaro 68" –Platinum Certificate Points 995 out of 1000
# (2) Award "Best Engine Modified/Custom"
# (3) Award "People’s Choice Show “N” Shine"
# (4) Award "Car That World Wide Camaro Would Most Like To Drive Home"
See below Certificate and Awards!
https://static1.pt-content.com/images/pt/2010/02/PlatinumCert995-1.jpg
Awards
https://static1.pt-content.com/images/pt/2010/02/IMG_0723-1.jpg
Many Thanks to Tom! with "Tom Argue Design" your the best!!!
Iamtheonlyreal1
02-08-2010, 09:43 AM
WOW... Again Bill, I will have to say Congrats to you and Tom... That is very impressive and you have to feel great about the directions you and Tom went...
68/CamaroFL
05-13-2010, 10:17 AM
Hey guys I know its been a while but I have enjoying driving "Evade" on the streets of west coast Florida! Here an Ad with Vintage Air of "Evade" in Camaro Performers Mag May's issue Many Thanks to Rick Love
https://static1.pt-content.com/images/pt/2010/05/2010CamaroPerfVAMaycopy-1.jpg
68/CamaroFL
12-15-2010, 06:19 AM
Hey everyone! its been awhile but I have a few changes and updates on Evade I will be posting soon!
I have a new website! :attn:www.evadecamaro.com please enjoy!
special Thanks to Adam with Revolution Industries, Fuel Injected Media www.rev-in.com
cdoggy81
12-15-2010, 10:17 AM
Cool web page!!!
BTW, did you happen to get my PM?
68/CamaroFL
02-14-2011, 01:48 PM
Well this year "Evade" was no trailer Queen it was Driven at the Ecklers Winter National
Ecklers Winter National 2011 Hosted by Classic Camaro of Central Florida!
It was a great drive left on Friday morning little foggy and light rain on and off but the rest of the show weather turned out for the best!
Eckler’s Chevy Classics and Worldwide Camaro Club held in Orlando this year at the Westgate Resort!
I think there were almost 250 Plus cars there! This was a 1000 point judging 3 judges tearing apart and going all over the car! Body exterior, Paint, Engine, Engine compartment,Interior, under carriage and truck!
All said and done Project “Evade” Won (5) Awards! @ The 19th Annual Winter National and scored “984” Platinum Certificate
# (1) Award "Custom Driven Camaro 68" –Platinum Certificate Points 984 out of 1000
# (3) Award "Best Interior Modified/Custom"
# (4) Award "People’s Choice Show “N” Shine"
# (5) Award "Car That World Wide Camaro Would Most Like To Drive Home"
https://static1.pt-content.com/images/pt/2011/02/PlatnumCertWnternats2011copy-1.jpg
https://static1.pt-content.com/images/pt/2011/02/AwardsWnternats2011copy-1.jpg
cdoggy81
02-14-2011, 03:43 PM
Nice & Congrats!!!
Coffee & Cars this Sat?
killer67
02-14-2011, 08:06 PM
Good for you Bill!
ProdigyCustoms
02-15-2011, 04:41 AM
Evade killed it again, they just LOVE that car there. Good for you, and congratulations on DRIVING it there this year. That was a great show venue this year, much better then last year.
68/CamaroFL
02-15-2011, 06:37 AM
Thanks Frank! It was great seeing you again congrats on the Awards you received! Again Many Thanks for hooking me up with the Forgeline Wheels!:twothumbs
Bill
www.evadecamaro.com
ProdigyCustoms
02-15-2011, 07:22 AM
They beat up the black and white Camaro pretty good, I am certain you thought that the black and white car was a lot nicer car then 962. Different set of judges on ours. But then the car got best interior and best engine? Whatever, exactly why I hate car shows.
The scores were on the money with my black and silver 56, I had it at 985 and they nailed it at 987. The judges also nailed both the red Chevelles did really close to what I was expecting, I had them at 980 and 990 and they hit them 982 and 989. And I thought they nailed your car, but I want your judges to rejudge the black and white Camaro though.
All and all I carried out a ton or hardware, so overall I am happy. I am also glad it is over. Preparing 4 cars for 1000 point judging is stressfull to say the least.
Forgeline 1
02-16-2011, 08:08 AM
Congratulations Bill!
Awesome car and well deserved awards. Thanks for letting Forgeline be a part of it.
Scott Main
Forgeline Motorsports
800-886-0093
www.forgeline.com (http://www.forgeline.com)
68/CamaroFL
02-16-2011, 10:08 AM
Ok here is a couple shots of the wheels and car I will get new shots of the car this week!
https://static1.pt-content.com/images/pt/2011/02/IMG_0026A1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0018-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0024JPGA1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0079-1.jpg
68/CamaroFL
02-16-2011, 10:09 AM
Here is the Trunk finished with all JL Audio that Tom Installed
https://static1.pt-content.com/images/pt/2011/02/IMG_0115JPG2-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0056-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0059-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0057-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0100-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0097-1.jpg
68/CamaroFL
02-16-2011, 10:19 AM
Here is the Side Marker Bezels from Marquez Design in Black Anodized
https://static1.pt-content.com/images/pt/2010/10/IMG_0018JPG1A-1.jpg
https://static1.pt-content.com/images/pt/2010/10/IMG_0021JPG1A-1.jpg
68/CamaroFL
02-18-2011, 09:25 AM
Here are a couple of updated pics of "Evade"
https://static1.pt-content.com/images/pt/2011/02/IMG_0122JPGa1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0030JPGa1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0105JPGa1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0047JPGa1-1.jpg
icebird84
02-18-2011, 11:14 AM
very very very nice
68/CamaroFL
02-23-2011, 07:40 AM
C F Bumpers on "Evade" by Tom Argue Design
https://static1.pt-content.com/images/pt/2011/02/IMG_0140-1.jpg
https://static1.pt-content.com/images/pt/2011/02/IMG_0157-1.jpg
2blownstangs
02-23-2011, 07:43 AM
such a nice car
CruizinKev
02-23-2011, 08:01 AM
:drool: :twothumbs
68/CamaroFL
02-23-2011, 08:10 AM
Thanks! Here ya go Another Shot of Evade
https://static1.pt-content.com/images/pt/2011/02/IMG_0142-1.jpg
colt zantop
02-23-2011, 05:20 PM
wow....wheels look killer!
srh3trinity
02-23-2011, 07:02 PM
Very nice. You really have done a great job at selecting the right mix of parts and paint. The Carbon Fiber is a feature, but it doesn't over power the car.
68/CamaroFL
10-19-2011, 07:27 AM
I posted this in manual trans section so i thought i would go ahead and post this in my build section of Evade I Was at the NSRA-Southeast Street Rod Nationals this past weekend and driving the "Evade" all three days back and forth from the house 45 minutes each way it was a great weekend and even took home a Award Pick of the Show presented by (ISCA) International Show Car Association. I was about 4 miles from the house went to down shift in fourth gear and would not go? had a serious grind trying to shift the shifter sounded like it was shifting in each gear however its fricking stuck in 5 gear had no other choice but to drive it home in 5th I now i burned the hell out of the clutch! but was able to make it home, on Monday morning called Keisler and left a voice mail for Shafi Keisler and e-mailed him since I bought the complete TKO-600 package from them its been three days and NO phone call! or NO e-mail what great service! :sleeping:
need help? also Ive been Contemplating for the past 8mo swapping out the TKO and step up to the T-56.. Now since I will be changing the whole clutch it might be a no brainier any advice?
Bill
68/CamaroFL
05-10-2013, 09:27 AM
“To improve is to change; to be perfect is to change often”
A few months ago I finally pulled the trigger and decided to upgrade and install the T-56 Magnum here listed is the complete install
"Installation by Tom Argue Design"
Parts List:
T-56 Magnum Transmission # TUET11009
GM
Engine LS
Torque Capacity:700(lb-ft.)
Speedo Type Mech/Elec
Spline Count: Input / Output 26 / 31
Gear Ratios
1st 2nd 3rd 4th 5th 6th Rev
2.66 1.78 1.30 1.00 .80 .63 2.90
https://static1.pt-content.com/images/pt/2013/05/IMG1b-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-1b.jpg.html)
QuickTime Bellhousing Chevy LS to T56 # RM-8020
https://static1.pt-content.com/images/pt/2013/05/IMG30a-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-30a.jpg.html)
Centerforce New DYAD Clutch and Presser plate # 04614842
https://static1.pt-content.com/images/pt/2013/05/IMG_001-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG_001.jpg.html)
GM Performance Hydraulic throw-out bearing #24264182
https://static1.pt-content.com/images/pt/2013/05/IMG30b-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-30b.jpg.html)
Here are the Parts that had arrived !!
https://static1.pt-content.com/images/pt/2013/05/IMG2-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-2.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG5-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-5.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG6-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-6.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG3-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-3.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG4-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-4.jpg.html)
68/CamaroFL
05-10-2013, 09:30 AM
Here is the TKO before taken out
https://static1.pt-content.com/images/pt/2013/05/IMG11-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-11.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG10-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-10.jpg.html)
Here is the TKO out of the car!
https://static1.pt-content.com/images/pt/2013/05/IMG12-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-12.jpg.html)
Removing the old Lakewood bell-housing
https://static1.pt-content.com/images/pt/2013/05/IMG13-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-13.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG21-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-21.jpg.html)
Removal of the GM Clutch and Pressure plate and Flywheel
https://static1.pt-content.com/images/pt/2013/05/IMG15-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-15.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG20-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-20.jpg.html)
The new T-56 next to the TKO
https://static1.pt-content.com/images/pt/2013/05/IMG22-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-22.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG23-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-23.jpg.html)
68/CamaroFL
05-10-2013, 09:32 AM
Getting the T-56 ready for install i did a lot of research for installing T-56 without Tunnel modifications ... The T56 is a larger transmission than your stock transmission. and the TKO If you are using the proper LS motor mount kit, the LS T56 will fit in the tunnel of the 1967-1974 Camaros without having to cut or enlarge the tunnel.
Note: If you are using incorrect LS motor mounts, if you have shorter, non-stock sub-frame bushings, or if your stock bushing are worn and compacted, the T56 may not fit within your tunnel without modifications
With having the Complete Speedtech sub-frame- LS Motor mounts and the Solid body mounts the T-56 fit like a glove !
68/CamaroFL
05-10-2013, 09:33 AM
We changed the lakewood bellhousing to this SFI-approved Quicktime scattershield. The main benefit here is that its compact design takes up less space in our already crowded trans tunnel.
https://static1.pt-content.com/images/pt/2013/05/Quicktimebell-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/Quicktimebell.jpg.html)
The new DYAD DS twin-disc Part # 04614842
Every DYAD DS clutch that ships from Centerforce comes with what they call a “birth certificate” specific to that unit. It gives all sorts of helpful data like compression depth, travel to release, average clamp load, and most importantly, the average torque holding capacity. In our case it’s 1,387 pounds.
https://static1.pt-content.com/images/pt/2013/05/DYADCLUTCHSPECS1a-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/DYADCLUTCHSPECS-1-a.jpg.html)
Centerforce’s solution was to lighten up a steel flywheel. By removing weight from the outer edge, the flywheel gains much of the benefit found in an aluminum flywheel.....“The entire assembly weighs 45.8 pounds!
https://static1.pt-content.com/images/pt/2013/05/IMG24-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-24.jpg.html)
The DYAD DS is a ‘true sprung’ hub design with the main drive disc built from chromoly steel. The drive disc also has over an inch of spline engagement for stability and strength.
https://static1.pt-content.com/images/pt/2013/05/IMG25-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-25.jpg.html)
The floater then went on and was held in place by the three lugs on the flywheel. Centerforce marked both of these parts with machinist’s ink to let us know how to orientate them.
https://static1.pt-content.com/images/pt/2013/05/IMG26-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-26.jpg.html)
The floating disc is held by six drive pins rather than on the input shaft of the transmission. This meant aligning the clutch parts was a snap.
https://static1.pt-content.com/images/pt/2013/05/IMG28-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-28.jpg.html)
With all the discs in place, Tom could go ahead and install the pressure plate and secure it with the included high-strength fasteners.
https://static1.pt-content.com/images/pt/2013/05/IMG29-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-29.jpg.html)
68/CamaroFL
05-10-2013, 09:34 AM
Before Stuffing the T-56 into the Evade Camaro we installed a new GM Performance Hydraulic throw-out bearing part #24264182
In order to connect the current Hydraulic line Tom had Custom made a billet slave insert to connect the line
https://static1.pt-content.com/images/pt/2013/05/IMG30d-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-30d.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG30e-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-30e.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG30f-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-30f.jpg.html)
68/CamaroFL
05-10-2013, 09:35 AM
Now with the T-56 installed we adjusted the speed tech cross member back to fit and in order to get the correct pinion angle we to custom cut the cross member a half inch drop
https://static1.pt-content.com/images/pt/2013/05/IMG31-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-31.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG32-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-32.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG33-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-33.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG35-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-35.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG37-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-37.jpg.html)
Now with the Cross-member all welded up fits perfect !
https://static1.pt-content.com/images/pt/2013/05/IMG41-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-41.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG42-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-42.jpg.html)
68/CamaroFL
05-10-2013, 09:37 AM
Next we sent out the drive shaft to Local Pyramid Machine for shortening up about 3inches.... next came all connectors
https://static1.pt-content.com/images/pt/2013/05/IMG44-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-44.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG45a-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-45a.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG45b-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-45b.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG45c-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-45c.jpg.html)
After install we went ahead and clean up and re polished all Stainless Works Exhaust
https://static1.pt-content.com/images/pt/2013/05/IMG48-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-48.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG49-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-49.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG51-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-51.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG53-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-53.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG54-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG-54.jpg.html)
68/CamaroFL
05-10-2013, 09:38 AM
After Completion we put about 350 miles plus to break in the T-56 and the Dyad Clutch .....
https://static1.pt-content.com/images/pt/2013/05/IMG_5411resized-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG_5411-resized.jpg.html)
Super Chevy Magazine puts "Evade" to the test Editor Jim Campisano Drives "Evade" like he stole it! coming out "July's Issue
BirdsThaWord
05-10-2013, 02:22 PM
Trying to place where you took your photos. Looks like Jax or St Augustine?
68/CamaroFL
05-10-2013, 03:16 PM
Gainesville raceway now called auto plus raceway
68/CamaroFL
05-10-2013, 03:17 PM
https://static1.pt-content.com/images/pt/2013/05/RoadCourse1-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/RoadCourse-1.jpg.html)
andrewb70
05-10-2013, 07:16 PM
Nice upgrade. What are you going to do with the TKO 600?
T_Raven
05-11-2013, 04:59 AM
One of my favorite 68s. Good to see it getting improvements.
68/CamaroFL
05-11-2013, 05:03 AM
Thanks Andrew!
The TKO-600 Sold
68/CamaroFL
05-16-2013, 09:21 AM
"Evade" 3 + Yrs and still going strong!
Look what came in the mail today! on the Cover of Super Chevy Magazine! Go like Hell!
Special Thanks to Editor: Jim Campisano & Justin Cesler Photographer.... Should be on the news stand May 21st!
https://static1.pt-content.com/images/pt/2013/05/IMG_13601B-1.jpg (http://s700.photobucket.com/user/wpano/media/T-56%20Magnum%20Install/IMG_1360-1-B.jpg.html)
maxgee
09-05-2013, 03:05 PM
Bill, great seeing the car in person and meeting at Hollywood studio in Orlando. I'm looking to feature a couple of well built cars to headline the event. With your permission and if you know you are going to make it; I want to put a link on muscletheheat.com to your car as attending.
Let me know.
https://www.pro-touring.com/content/376-South-Florida-Pro-touring-style-autoX-December-1st-2013
68/CamaroFL
12-05-2013, 09:44 AM
http://youtu.be/eXJMj2qbRzA
http://www.superchevy.com/multimedia...-camaro/20854/
