TravisLee
12-22-2008, 02:33 PM
I am about to pull the subframe out of my 68 camaro to complete the suspension, steering, and braking. I am on a budget so I cannot afford to buy a complete subframe so I will use the stock cleaned and powdercoated one.
I was looking at the CPP complete polyplus front end kit, the Hotchkis TVS system with bilstein shocks, subframe connectors, solid body mounts, and the Prodigy customs total g-machine braking system with 4 piston calipers all around. I will be using the stock control arms, as dictated by my budget, and replacing all the steering.
My question is, does this sound like a good comprimise between budget and performance for a big block weekend cruiser? Am I missing anything? Can you recomend any other bushing kits? I want to use all polyurethane and change everything that has deteriorated or worn out from age. Would it be wise to replace all the steering compnants regardless of ware? Centerlink, drag link, pitman arm, etc. while I am at it?
I know this is a lot of questions and I thank you for your time and input. I want to do it right the first time, and do not mind waiting to save up to buy parts that are a little more expensive. My goal is to have a great looking car I can drive to shows and do some of the power tour when completed. It will not be raced or open tracked.
