View Full Version : can you fit 275 tires on a 1st gen subframe?
jeremyS
12-16-2008, 08:27 AM
building a 67 camaro right now, is it possible to fit a 275 tire on the front of a stock subframe?
thanks
TitoJones
12-16-2008, 10:38 AM
Yes. It will require some serious measuring, and you will have to limit the turning raduis to do so. Look for CarlC's website for more details.
Tyler
dhutton
12-16-2008, 10:46 AM
Here's a thread on notching the subframe to allow 275's:
http://www.camaros.net/forums/showthread.php?t=114005
Don
68sixspeed
12-16-2008, 04:43 PM
Carl C has some great info and rim specs on this on his site too--
http://www.geocities.com/casanoc/
CarlC
12-16-2008, 10:50 PM
No need to notch to fit 275's. It should work with stock A-arms as well. Steering limiters would need to be adapted.
For those that feel that the reduced turning radius is a problem, all I can say is that after four years it is still not a major problem. 3-point turns and parking spaces are easy.
Flash68
12-17-2008, 01:10 AM
I am doing 275s on stock sub with Unisteer R&P, Air Ride upper/lower control arms. Our initial turning radius testing doesn't show much of a compromise, at least not as much as we thought there would be. No notching required.
jeremyS
12-17-2008, 06:48 AM
thanks for all the advice guys, iwill look into those suggestions
