gearheads78
12-14-2008, 12:51 PM
After reading a few threads about ball joint failure and ball joint torque I decided to go back an torque my ball joints to recommended specs. The plan was to pull the cotter pins and loosen the nuts torque and put it back together. Well as I loosened the top the spring pressure was just pushing the spindle right off as the nut went down. I checked the bottom and I had to use a puller to separeate as I think I would have to. I took and magic marker and colored the top ball joint and snugged the nut up pretty good this time with no spring pressure. Loosen and it fell apart by hand and you could hardly see any of the marker rubbed off.
My spindles are off a 67K mile car that still had original ball joints so I did not think there could be a worn spindle problem. I called Macus at SC&C to see if maybe I got a misboxed part. Since I am running a Chrysler bolt in ball joint I thought maybe I got a Chrysler stud unstead of a GM stud.
He was thinking a may have got Gbody studs based on what I was telling him and had me measure some things for him. I called back with the measurement and he said I do have the right Abody stud. He thinks I have a worn spindle and would fix them for me for next to nothing just have to box them up and wait for shipping turn around.
I was about to pull them up to box them up today and decided to check with a couple of other spindles I had laying around. Now I have 4 spindles with the same issue on these ball joints. I decided to pull off the rubber hose that goes on the stud and noticed this. I can slide the spindle up the stud and it easily bottoms out on the step of the stud. See attached picture.
I can't call Marcus today so I was wondering if anyone else has run in to this? Is the stud taper machined too short or do I really have 4 baddly worn original GM spindles?
