View Full Version : What do I need to do to make these fit?
JaySB
12-10-2008, 01:10 PM
For my 69 Camaro....
http://cgi.ebay.com/ebaymotors/19-IFORGED-WHEELS-TIRES-M3-328-330-335-540-545-745-18_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7 c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1 Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem36 0115082466QQitemZ360115082466QQptZMotorsQ5fCarQ5fT ruckQ5fPartsQ5fAccessories
I'm not too worried about the rear, just need to know what I'd need to have done up front to get the wheels to fit. Thanks.
tumper93
12-10-2008, 01:23 PM
That offset that I asume he is saying is to the outside is only 1 3/8" so you would have 7" back spacing on the front wheels!! I am not sure you can fit them without have the "skated" look. I would leave them alone and find a set that you can get in the offset you need to do it right not make it work cause you like them. In the long run you will be happier.
maldo
12-10-2008, 02:14 PM
agree
dhutton
12-10-2008, 03:00 PM
The backspacing on the 9.5" is 6.2 inches and on the 8.5" it is 6". You can check it for yourself here:
http://www.rims-n-tires.com/info_specs
I don't think this is so far off that you could not use them with some spacers. Something as small as 1/4 to 3/8" on the 9.5" rear and maybe 1/2" on the front. The fronts might be a little trickier than the rear, you may end up having to buy an adaptor if you go much thicker on the spacer.
It's a bit of a gamble with the 19" wheel but the tire diameter is 25.8 inches which should be fine. I think it will depend on how low your car is.
Maybe some of the wheel experts will offer up an opinion.
Don
