View Full Version : Door handle options
ed1le
12-09-2008, 07:31 AM
I would like to install a set of late model, flush style door handles on my skylark vs. the stock chrome ones. I know this will require some cutting & welding and fabrication to the locking mechanisms in the door. Anyone have any experience doing this or have pics of this they could provide? I've attached a pic of the handle on my accord to help give an ide of the style/type of look I'm going for but it obviously doesn't have to be that specific one. Anything similar that may work best.
https://static1.pt-content.com/images/pt/2008/12/DSC01039-1.jpg
craigs73
12-09-2008, 09:27 AM
i was going to do the same thing but was thinking of the ones on the cobalts
mikey
12-10-2008, 09:16 PM
They used Jaguar handles on the Foose Camaros. The handle install itself is pretty simple the linkage is the trouble. Find the handles you want and cut out a section of the donor skin. Go 2-3 inches past the handle in all directions this give you extra to work with. Determine the placement in your door. Do your final trim on your donor piece prior to placing it.Trim out a hole gig enough for the recessed area only and fit your donor piece in place use some tape to hold in place while you make any adjustments needed to get the look you want. Scribe your final cut line remove and trim pieces to fit flush. Weld it up and finish it up.
cluxford
12-11-2008, 01:37 PM
Mine are off late model GM cars (ie 2001 to 2004 model - in Australia but I know they are same on Impala's in the US).
As last poster said it's the linkage that is hard, late model push down, Gen 1's pull up (if you follow my thought process), so working the mechanism is the hard part....
here is a pic of mine
https://static1.pt-content.com/images/pt/2008/12/IMG_3449-1.jpg
https://static1.pt-content.com/images/pt/2008/12/IMG_3380-1.jpg
ed1le
12-11-2008, 02:34 PM
That looks sharp as hell! What did you have to do to get them to work with the stock locking mechanisms?
barno68
12-11-2008, 04:46 PM
These are off of a Grand Prix, but can be had off of Impala, malibu or vette (well just the handles). To get the lock and handle to work just graf the two linkages together.
https://static1.pt-content.com/images/pt/2008/10/doorhandles-1.jpg
https://static1.pt-content.com/images/pt/2008/10/handle__6_-1.jpg
icebird84
12-11-2008, 06:23 PM
this looks good
craigs73
12-12-2008, 09:38 AM
i created this same thread on another site and here is some things i got this handle is from a miata
craigs73
12-12-2008, 09:41 AM
https://static1.pt-content.com/images/pt/2008/12/mufp_0701_13_z1965_ford_mustang_coupemia-1.jpg
craigs73
https://static1.pt-content.com/images/pt/2008/12/mufp_0701_01_z1965_ford_mustang_coupesid-1.jpg
skinnyboy67
12-12-2008, 06:55 PM
Here also is mine out of an accord..
These are on opposite doors switched and upside down to try to get the inside mech.to move to the correct way ie: up/ down
I got the out side to work but the inside handles are still giving me trouble...any thought or pics of the inside mechanics..please.
Ron L
12-12-2008, 10:49 PM
i created this same thread on another site and here is some things i got this handle is from a miataI've thought about using that same type on my '67 but not having seen the workings of one I'm hesitant about buying the ones I see on eBay. Did you use surrounding sheetmetal from the original door or just re-shape the hole in the door? Does the mechanism pull up or push down on the rod?
edit - Being symmetrical on the horizontal plane I guess you could swap left/right to circumvent the push/pull issue.
craigs73
12-14-2008, 04:45 PM
sorry thats for the confusion thats not my car i just posted the same thread on another site just to get a answer because i was thinking of doing the same thing:)
ed1le
12-15-2008, 06:58 AM
Haven't been able to find jack really on ebay for handles with the sorrounding sheet metal...probably start to check out local salvage yards after the new year...
Ron L
12-15-2008, 08:52 AM
I got the out side to work but the inside handles are still giving me trouble...any thought or pics of the inside mechanics..please.Coincidentally I was just looking at a pair of those on Craigslist last week. The guy even posted pictures of the back side and I could see how they would(n't) work on my car. I took the pics into photoshop to see what they would look like upside-down.
Maybe modifying the latch to push instead of pull would be easier? Anyone here done that before?
BK2LIFE
01-09-2009, 06:00 PM
its not that hard to figure the linkages out. most of the time just turn the handle upside down and the problem is solved.
manicmechanic
01-09-2009, 09:35 PM
Another thing to consider is the key lock switch, on my 06 Daytona there is only one key hole on the drivers door. I know that thieves just pry the handle out and access the lock rod to get into these cars so I ordered a new handle for the rear drivers door and replaced the keyed handle in the front door with it. No more lock access for a thief to use. Since the Daytona has the battery in the trunk (if it ever went dead) I was covered. I also keep a spare battery for the fob in the trunk in case it went dead and worst case scenario was the fold down rear seat access to the passenger compartment. So if you wanted to clean it up even more use rear door handles from 4-door cars.
nekkidhillbilly
01-12-2009, 02:35 AM
i dont really like it
but that stang look 10x better than the camaro
