View Full Version : The Stickman's BattleCruiser Build Thread
The Stickman
12-07-2008, 08:25 PM
Ok let me start off by saying this isn't some high buck high tech build. It is about as oldschool as you get. Doing what you can with what you have. Now some may also look at this car and think it doesn't belong. But here's some things to consider. One I have always been a roadracer. I have always been into racing like the IMSA GTP(L)/O/U. In fact I own an IMSA GTU bodied Fiero with the racing Super Duty 4 cylinder engine. I plan on making this wagon so much better in all respects than when it was new. Although I must admit it has impressed me with it's handling as I bought it for the type and size it is. But let's start from the beginning. It's a 1984 Oldsmobile Custom Cruiser. It came with a 307 Olds engine, 200R4 OD trans, and 2.73 8.5 rear. And Yes the 2.73 gears are staying. I love them for highway cruising. I can always increase hp to compensate. It has 15X8 steel Wheel vintiques on it with 255/60-15's all around and they do handle well. It has the 2 bench seats in the front and I added the rear 3rd row (Rear facing)seat. it gives me a nice place to sit at cars shows and cruise nights. Here is how it looked before anything has been done to it.
https://static1.pt-content.com/images/pt/2008/12/100_0445fi-1.jpg
The first thing I added was a repro Olds Batwing style aircleaner. I always thought they looked cool.
https://static1.pt-content.com/images/pt/2008/12/100_0454-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0453-1.jpg
After that I added a touch screen reciever/cd/dvd player.
https://static1.pt-content.com/images/pt/2008/12/100_0493-1.jpg
I also wanted a unit like this for another reason. Since this wagon is so huge I wanted a back up cam and this allowed my to do it without adding a separate screen. All in all it was pretty simple. Just alot of extra wiring due to the lengh of the car.
https://static1.pt-content.com/images/pt/2008/12/100_0494-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0495-1.jpg
the screen doesn't look great here but it was dark out when i took the pics so the back up cam didn't pick up much. Here is the cam I used. It is totally hidden and no one knows where it is.
https://static1.pt-content.com/images/pt/2008/12/100_0499-1.jpg
While I was at it I added a remote hidden antenna because for one the fender mounted one was broken off. And I didn't want to put one back in that spot because it would be a pain in the butt and because this simply looks cleaner. Here is the remote hidden antenna I used. It works pretty well I think.
https://static1.pt-content.com/images/pt/2008/12/100_0517-1.jpg
Now onto the upgrades since I have gotten it.
The Stickman
12-07-2008, 08:59 PM
Ok the next thing I did was to buy this off of Ebay for $400.
https://static1.pt-content.com/images/pt/2008/12/100_0506-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0507-1.jpg
It's a 1972 350 Olds with 7a heads.
https://static1.pt-content.com/images/pt/2008/12/100_0508-1.jpg
An Edlebrock Performer 350 intake.
https://static1.pt-content.com/images/pt/2008/12/100_0512-1.jpg
And Competition Cams roller tipped rockers.
https://static1.pt-content.com/images/pt/2008/12/100_0513-1.jpg
Now the person I bought it from said they thought it had a cam in it and I believe them. But it would be awhile before This engine would be installed let alone running. But my next purchase would go in right away. I went to a junk yard looking for a rear sway bar for this car and found this.
https://static1.pt-content.com/images/pt/2008/12/100_0518-1.jpg
An aluminum radiator out of an LT-1 Caprice. It is wider and taller than my stock one. I also allows me to get rid of that damn clutch fan. Here are some pics of it installed.
https://static1.pt-content.com/images/pt/2008/12/100_0973-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0974-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0975-1.jpg
Now while I was at it I decided to add an external trans cooler. And this is the unit I choose. It's a 24 inch aluminum finned unit. The construction is very nice.
https://static1.pt-content.com/images/pt/2008/12/100_0976-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_0977-1.jpg
Now before I added this the trans was acting up a bit. And from the research I've done the symtoms seemed like those generally atributed to the 200R4. But after installing this cooler most went away so maybe those problems were heat induced and this fixed it. Now with a new rad and electric fans i decided to add a thermal switch to turn them on. I didn't want them running continuously or rely on my flipping a switch to operate them. So I added this to handle the situation.
https://static1.pt-content.com/images/pt/2008/12/100_0979-1.jpg
I would say it works pretty well. Now from what I understand this 2 fan set-up was one that would normally use one fan for cooling and the second was for when the A/C was on. I wired them to both go on at the same time. They sure do move alot of air.
The Stickman
12-07-2008, 09:26 PM
Now the next thing I needed to do was to get the 350 engine ready to install. I picked up a Holley cheap off Craigslist and rebuilt it. Now with the Edelbrock Olds intake in order to use a Holley you need atleast a 1 inch spacer becuase the throttle arm huts the intake. I also wanted to add wire braided hose. It looks a whole lot better than the stock steel line and as things progressed it's a good thing I went this way. Here is the engine mocked up with the Holley.
https://static1.pt-content.com/images/pt/2008/12/100_1352-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_1353-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_1354-1.jpg
I actually installed the engine this way.
https://static1.pt-content.com/images/pt/2008/12/100_1599-1.jpg
Only to find I wasn't getting any fuel into the bowls. I couldn't figure out the problem so I Bought a new Quadrajet. I fured it was a better bet as I could keep my fuel economy with the small primaries. Now I also had an Edelbrock carb laying around and to use that carb I would have had to use atleast a 2 inch spacer and I wasn't cutting a hole in my hood or using different aircleaner. I had a Holley mechanical fuel pump but to run the lines with the stock A/C brackets would be hard the way I wanted. SO I took the mechanical pump off and had my wife make me up a blockoff plate.
https://static1.pt-content.com/images/pt/2008/12/ATT00002-1.jpg
And then I added a Holley electrical one back on the frame rail. This is where my choices actually come to help me. Because If I had not wanted braided hose and the electric fuel pump I would have never distrubed my steel fuel lines. Just from the slight movement they started to leak. They were very rusted and I wouldn't have known how bad had It not been for my choices. So now I have all new wire braided hoses and steel lines front to back. I finally got it all together and working. Here is a vid of my start up with no exhaust.
http://www.youtube.com/watch?v=ocZ8_tTMbr0
Not bad if I do say so myself. Now I planned on running dual exhuast with this new engine and there are two problems with that. One is that Oldsmobile in there infinate wisdom thought it was a good Idea to take the exhaust out of the drivers side manifold route it down and under the oil pan and up into the passenger side exhaust manifold. Where the exhaust would then exit out of a separate hole. So the passenger side exhaust has two openings. SO one needs to be plugged. I had my wife weld(yes my wife is a welder)up a plug for the hole where the exhaust from the drivers side would come in. Here are those pics.
https://static1.pt-content.com/images/pt/2008/12/ATT00008_jpg1_-1.jpg
https://static1.pt-content.com/images/pt/2008/12/ATT00009-1.jpg
https://static1.pt-content.com/images/pt/2008/12/ATT00011-1.jpg
The guys at the exhaust shop were impressed with her welding. Now for the second problem. I needed a dual hump crossmember. So again I had my wife fab me up one. We had a piece of channel playing around so I simply had her cut a section out of my crossmember and weld it in.
https://static1.pt-content.com/images/pt/2008/12/100_1591-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_1593-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_1590-1.jpg
The Stickman
12-07-2008, 09:32 PM
So after getting the car running it needed a new and complete exhaust system. We had the car towed to the shop, and the tow truck operator wasn't the happiest having this as his first tow on a early damp Saturday morning. But the exhaust came out nice.
https://static1.pt-content.com/images/pt/2008/12/100_2810-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2812-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2808-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2817-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2816-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2813-1.jpg
I Didn't get the Flowmasters like I wanted as funds were tight that week and I just wanted my baby back. But she sounds good. Give it a look and listen.
http://www.youtube.com/watch?v=B2fmZ68ADVI
The Stickman
12-07-2008, 09:41 PM
Now for the future mods of this thread. I bought these valve covers.
https://static1.pt-content.com/images/pt/2008/12/100_2818-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2819-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2820-1.jpg
https://static1.pt-content.com/images/pt/2008/12/100_2821-1.jpg
They are really cool, But they are very tall, very heavy, and very rough. I am sanding and grinding them down so they can be polished. But the cast was very pitted. So I will need to fill all the holes I can. I like that they are tall. But hate how heavy they are. They should be on sometime soon. My other project is to add fuel injection. I have this.
https://static1.pt-content.com/images/pt/2008/12/100_2184-1.jpg
Its a great billet throttlebody. i figure I can get an Intake and have injector bungs welded on, use this throttlebody and just use a 350 Chevy computer, sensors, and wiring harness to give me a nice FI set-up. Not sure if I will use the BatWing aircleaner with it.
https://static1.pt-content.com/images/pt/2008/12/100_2189-1.jpg
Or this and have it run to a filter under the bumper.
https://static1.pt-content.com/images/pt/2008/12/100_2188-1.jpg
And lastly for the future mods I want the car to look like this.
https://static1.pt-content.com/images/pt/2008/12/bmp-1.jpg
I have been looking for wheels but t is difficult as the car uses 5X5 bolt patterns. So finding nice wheels in the sizes I want is hard. Alot of the wheels with 5X5 bolt patterns are for trucks and therefore look like they are for trucks. So my seach is on. I may go with the Cragar Soft8's as they look pretty nice. But I am not sure the back spacing is ok and I really would rather have 10 inch wide wheels for the rear. With a 9 inch wide wheel the bigest I can go is a 275/40-17 and I ma not sure that would fill the rear wheel well enough. So my search is on.
The Stickman
12-07-2008, 09:48 PM
Oh a couple things I forgot to mention. I lowered the car using Eibach springs. They didn't lower the car in the front near as much as I wanted. And believe it or not the car felt firmer and more stable with the stock F41 sport suspension than it does with the Eibachs. I may take the Eibachs off and put the stock ones back on and cut a few coils out of them. Here is the before and after.
https://static1.pt-content.com/images/pt/2008/12/100_0745-1.jpg
Now over the winter I plan on putting a rear bar on the car, but I will need my wife to fab me up some brackets to make the one I have fit. It seems the wagons were wider at the back and therefore anything made for the sedan versions of this car does not just bolt up. But I'll make it work.
Martin71RS
12-07-2008, 10:15 PM
Cool project!!
aussiebj
12-08-2008, 05:21 AM
wagons look kewl
barno68
12-08-2008, 06:08 AM
Looks great! I love the wagons, almost bought a '72 Lemans wagon last spring, but alas... Good luck and it looks great in the black.
jackfrost
12-09-2008, 07:59 AM
awesome Olds! I love anything different. thanks for posting your project. good luck and keep us updated.
Rocko71
12-11-2008, 02:27 PM
I think 94-96 Impala SS wheels would look good... They are the same bolt pattern too.
83rdracr
12-12-2008, 12:49 PM
since you were thinking soft 8's why not use Aero or Basset stock car rims. 15 x 10 and any back space and bolt pattern you want plus they only weigh about 22lbs each.
Damon777
12-12-2008, 07:01 PM
You sure? My 77 Impala wagon used 5 lug truck pattern.
The Stickman
12-12-2008, 07:41 PM
I really want atleast a 17 inch wheel. I figure I wil go 17X9's all around and then If I go with the Soft 8's I can always have 2 of them widened to 10 or 11 inches wide
The Stickman
12-12-2008, 07:42 PM
All B-body wagons used 5X5(which is the truck pattern) and then when the newer B-bodies came out they used the 5X5 bolt pattern so the Impala SS's used the same pattern.
Roadbuster
12-12-2008, 07:46 PM
Careful with stock car rims. They are made for a 45 degree lug. There was a warning about this in my Speedway Motors catalog but I can't find it on their website. If you want I will dig it out.
Jon
78 Type-LT
12-14-2008, 08:47 PM
cool
The Stickman
01-02-2009, 09:05 AM
Well here is mild update. I recieved my wheels today. They are 18X9 Boss series 304's. I should be getting tires for them soon. But in the next 2 or 3 weeks there will be much progress with the arrival of parts. So stay tuned.
https://static1.pt-content.com/images/pt/2009/01/100_3054-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_3055-1.jpg
singer69
01-02-2009, 09:38 AM
Love the Wagon man!
DvBoard
01-02-2009, 01:05 PM
I'd hit the drum with a bit of hi-temp rattle can black, flat or semi-gloss. It will help it look lots better IMO and is cheap.
The Stickman
01-02-2009, 03:35 PM
Hopefully the drums won't be there long. I am looking to get rear discs on it
The Stickman
01-11-2009, 12:44 PM
Well I finally got some steering wheels for us and installed them today. I took off the old goofy looking plastic one and put on a leather one from a Fiero. It has the nice contoured grips and is so comfy. Yes I know It hasd the Fiero horn cap. I will be trying to fix that in the future. It's also a little dirty. I will need to take some cleaner to it.
https://static1.pt-content.com/images/pt/2009/01/100_3068-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_3069-1.jpg
The Stickman
01-21-2009, 01:32 PM
Well parts have been arriving pretty often lately. I now have a TransGo 200-4R HD2 shift kit for my 200-4R transmission. It will give me either full manual control up or down thru the gears for 1st,2nd, and 3rd gears. Or I can stick in in OD and let it do all the work.
https://static1.pt-content.com/images/pt/2009/01/100_0886-1.jpg
Today I recieved my new shifter. It is made by Brian Kilduff and is one sweet piece. His shifters are made to order so you can't go wrong here.
https://static1.pt-content.com/images/pt/2009/01/100_0871-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0873-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0874-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0875-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0876-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0879-1.jpg
The Stickman
01-21-2009, 01:48 PM
Now if I am going to run a floor shifter I have to replace the bench seat with a set of bucket seats. And I had a few options. I could have found some comfy buckets so it would be similar to what the bench feels like. Or I have a bunch of Fiero seats I could have had recovered. But since this car handles great as is and will only get better to the point I may want to do some track days with it I felt that something closer to a competition seat should be in order. So I found these off of Ebay and it so happens they were fairly local so it saved me some cash. I really like the look. Wait till you see what I do with them.
https://static1.pt-content.com/images/pt/2009/01/100_0881-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0882-1.jpg
https://static1.pt-content.com/images/pt/2009/01/100_0883-1.jpg
The Stickman
02-04-2009, 09:41 AM
Well more parts have been recieved for my build(s). I found two distributors off of Craigslist. The first one was a Mallory Uni-Lite vacuum advance distributor. It is used but looks ok. I paid $100 and the guy threw in the MSD wires and Blaster 2 coil.
https://static1.pt-content.com/images/pt/2009/02/000_0002-1.jpg
The second distributor was a brand new in the box MSD Pro Billet unit. This I got for $175 which I thought was a steal. So much so I didn't even try to haggle.
https://static1.pt-content.com/images/pt/2009/02/000_0003-1.jpg
Now why 2 distributors? Well the MSD distributor must be used with an MSD box. Now I have a used 7AL-2 unit. BUT it happens to be a 4 cylinder only part. So I am trying to find out what I need to do to send it back along with this coil to have rebuild at a fraction of the cost of new.
https://static1.pt-content.com/images/pt/2009/02/100_2796-1.jpg
Note the coil has an aluminum heat sink around it. This will not only look cool but I have yet to see one on another car. So I can't use the MSD distributor until I have a box and coil to use with it. So I can use the Mallory until all that get's figured out. I hope to have the Mallory in this weekend depending on the weather. It should improve my spark and timing. The Mallory has to be a vast improvement over the tired old HEI unit. And once I have all the parts I need to use the MSD distributor the Mallory can go in the wife's car providing we find an Olds engine for her's soon.
Shiro666
02-04-2009, 10:41 AM
That shifter!
Oh, Snap!
The Stickman
03-14-2009, 05:20 PM
Ok the wife and I worked all day on getting the old bench seats out and the new buckets in. We had to(ok ok she had to)custom make the brackets as there was nothing to use. I did get sliders with the seats but needed a way to mount the seats and sliders to the floor. We ended up making some nice brackets using nothing more than scraps we had laying around. We did use the outer studs that the bench seat was orginally mounted to. We only got one front seat done but the other one should be a piece of cake now that the first one is done. And the wife did take a good bit of time getting the welder back to where she wanted it as it has been sitting for a long time. Anyway here are the pics. Let me know what you think.
https://static1.pt-content.com/images/pt/2009/03/100_3121-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3122-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3123-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3124-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3126-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3127-1.jpg
The Stickman
03-15-2009, 04:59 PM
Ok bucket seats day 2. My car is becoming more and more like my vision of a high performance touring car like i want. We worked on getting the drivers seat perfect and making brackets for the passenger seat. It took most of the day(well started at 1pm) but now I have both front seats mounted, and I can work on the backs. Here are the newest piccs of both installed. BTW there should be alot of updates this week as I plan on lowering the front end and will be getting my wheel spacers and poly bushings for the front end.
https://static1.pt-content.com/images/pt/2009/03/100_3129-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3130-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3131-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3132-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_3133-1.jpg
srh3trinity
03-15-2009, 06:36 PM
Those seats look nice. I like the shifter more and more each time I see it. Cool build.
67apostle
05-20-2009, 10:12 AM
Very cool ride! Keep it up.
NOT A TA
05-20-2009, 11:32 AM
It's coming along Neil! That shifter is cool! It's got a functional "industrial" street fighter look about it I like.
twosaturns
05-21-2009, 05:32 AM
stickman, I KNOW i've seen your car around here in Easton! isn't there another guy around w/ a primered lowered wagon you hang with also? I seem to remember one w/ red scallops.
btw, I like the low buck approach w/ an odd choice of car. my family once had a '79 caprice wagon for trailer towing (handled like a boat, though).
chevy42083
05-21-2009, 05:45 AM
4 buckets would look sweet :)
Nice unconventional build.
jackfrost
05-21-2009, 08:53 AM
I'd love to see a pic of this car on the track w/ 4 people wearing helmets in it. :razz:
The Stickman
06-01-2009, 09:43 PM
Well I have been slacking off with the updates so I will try to get up to date in the next few days as I will have more after that with a new radiator and intake, as well as a rebuilt trans with shift kit after it's rebuilt.
So here's what you have missed. I rebuilt the front suspension with Energy Suspension bushings and I took the Eibach springs out of the front and put the F41 RPO code springs back in. First I took a half coil off and it brought it down to the level of the Eibachs and I wanted more of a drop. SO I hacked off a whole nother coil. That might have been more extreme then I had originally wanted. But the looks and ride are perfect. So I got way lucky. Here's some picks.
https://static1.pt-content.com/images/pt/2009/04/100_3292-1.jpg
https://static1.pt-content.com/images/pt/2009/04/100_3291-1.jpg
https://static1.pt-content.com/images/pt/2009/04/100_3289-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_3297-1.jpg
Here's how I want the rear to be with some help from a friend.
https://static1.pt-content.com/images/pt/2009/04/100_3298-1.jpg
Here are some coilover brackets that my wife made. Problem is I have 2 pair of Coilovers that are too long so we have to figure a way to find the extra space for them.
https://static1.pt-content.com/images/pt/2009/06/100_3299-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_3307-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_3308-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_3306-1.jpg
hechtrod
06-02-2009, 06:21 AM
This is a cool build and car. Love wagons! I really like those seats too?
The Stickman
06-02-2009, 07:32 PM
Well I promised more updates and here they are. Here are some body mods I did with the bumpers. First the front bumpers are tucked in. The one bumper shock was partially collapsed so I collapsed it all the way. Now to collapse the other one I had to drill a hole in it. Then I stripped the bumper down and painted it black.
https://static1.pt-content.com/images/pt/2009/05/100_3952-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4034-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4033-1.jpg
Then onto the rear bumper. I stripped it down and painted it black like the front. I took it off the mounts and put it against the body and it looks great. But I have to figure out the mounts to get it right but here is how I want it to like
https://static1.pt-content.com/images/pt/2009/05/100_3944-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_3946-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_3945-1.jpg
hechtrod
06-02-2009, 07:52 PM
Nice bumper mods! Wagon lookin' sharp!
ProTouring442
06-03-2009, 03:26 AM
Just an idea on your horn button....
If you find a way to mount a Corvette horn contact:
You can then utilize an Olds sport wheel horn button:
https://static1.pt-content.com/images/pt/2009/06/238768766_tp-1.jpg
Just a thought!
Lookin' good!
Shiny Side Up!
Bill
The Stickman
06-03-2009, 07:46 AM
Just a thought!
Lookin' good!
Shiny Side Up!
Bill
Wow thanx for the idea. Now I need to get to a junkyard to see what I can find and make work.
jackfrost
06-03-2009, 09:05 AM
cool progress. could you shave some of the holes on the bumpers?
The Stickman
06-04-2009, 05:25 AM
At this point I am not sure if I just want to weld them up or fill that channel in completely. If I weld up the whole channel it's more weigth that I don't need. If I can find a lightweight solution then maybe.
The Stickman
06-04-2009, 05:33 AM
Here is the rear suspension mods I have done. These are my Metco Billet Aluminum LCA's. I really like these arms. They are very nice quality pieces.
https://static1.pt-content.com/images/pt/2009/05/100_4106-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_4110-1.jpg
They allowed me to mount a sedan swaybar on may wagon until I can get a set of much bigger wagon bars.
https://static1.pt-content.com/images/pt/2009/05/100_4113-1.jpg
Here are the arms mounted without the swaybar mounted.
https://static1.pt-content.com/images/pt/2009/05/100_4115-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_4118-1.jpg
Here it is with the swaybar mounted.
https://static1.pt-content.com/images/pt/2009/05/100_4123-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_4125-1.jpg
https://static1.pt-content.com/images/pt/2009/05/100_4126-1.jpg
ANd here is a pic showing the twist in it.
https://static1.pt-content.com/images/pt/2009/05/100_4129-1.jpg
jackfrost
06-04-2009, 09:28 AM
you could make a fiberglass skin pretty easily. sort of the way some body kits just slip over the steel bumpers.
those control arms are real nice. what bushings are in them?
The Stickman
06-05-2009, 08:44 AM
Ok I bought a new Edebrock High rise Performer intake part #7111. I bought it cause the old Performer is warped to hell and I need to fix the leak problem. ALthough I think it might be a problem with the head because the cast iron intake leaked at the EGR crossover too. But then again I didn't read the turkey try gasket directions either time i did it until after the last one that said to use gasket sealer around the ports. Never had to do this on any other car. So hopefully this will seal right and I can get all the performance outa my engine that I should. Here are so some pics comapring the 2 Performer intakes.
https://static1.pt-content.com/images/pt/2009/06/100_4174-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4172-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4173-1.jpg
You can clearly see the new intake is about 2 inches taller than the old one.
Here is it mounted and with the carb on it.
https://static1.pt-content.com/images/pt/2009/06/100_4182-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4184-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4183-1.jpg
Now it did represent a big problem. The base plate for the batwing aircleaner is flat so it sits up off the carb. Thankfully I had an old HUGE aircleaner that had a drop down base that is the same size. So I swapped one for the other(will need some trimming) and low and behold I can close my hood.
https://static1.pt-content.com/images/pt/2009/06/100_4180-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4179-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4181-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4177-1.jpg
hechtrod
06-05-2009, 09:39 AM
Diggin' the new 'mani Stick! I love those aircleaners too. My favorite!
Ron L
06-09-2009, 12:00 PM
About that shifter, why does it not ratchet from first?
The Stickman
06-09-2009, 12:38 PM
Not sure what you mean because it does, just like all the other gears.
Ron L
06-09-2009, 07:27 PM
I'm looking at this picture:
It doesn't look like you can upshift out of first without lifting the lever. Am I seeing it wrong? I must be, since there are seven positions, (P R N IV III II I) but eight detents. I've never seen or used a ratchet shifter so pardon the ignorance.
The Stickman
06-09-2009, 08:46 PM
In order to opperate the ratchet part of the shifter you must "arm" the shifter by lifting up on the center section that looks like brass knuckles then letting go. then you can shift to the next gear when you are ready. This applies for every up or down shift. it sounds like more work but it works nice. Now if you want to use it as a normal shifter you simply hold the center section up until you get to the gear you want. If you go to my Youtube video's you can see how it works in part 3 of my installation video's. Brian Kilduff also has some YouTube video's of how it works.
KlasSic68
06-10-2009, 08:47 AM
I like this project! Nice and unique but is looking sic! :twothumbs:
ProMav71
06-10-2009, 10:09 AM
Coming along nice. Different but I likey! I'm going with those seats as well. Are they decent material wise and comfy?
The Stickman
06-10-2009, 04:05 PM
Ya know I was worried they wouldn't be comfortable. Then right after I installed them I took a 2 hour trip to see a friend. I tell you what I didn't even think of stopping, getting out or even trying to change seating position. they really are that comfortable. I went from a comfy bench seat to these and I love them. the material is nice too.
ProMav71
06-11-2009, 07:01 AM
Thanks for the info kinda eased my fears! Always good to talk to someone that has tested them out. I will be putting these in the Maverick.
The Stickman
06-12-2009, 07:20 PM
Well I got my transmission back from the rebuilder after the front seal went. I figured I might as well get the shiftkit put in and have the whole trans rebuilt. I also figured while the trans was out to replace the LT-1 radiator with an all aluminum one and to replace the Edelbrock Intake that was warped with another better one. The Intake was easy and I covered that in a previous post. The radiator was a bit more involved. I could not use the LT-1 radiators fans and since I had to shell out big dough for the trans rebuild I couldn't get new fans which can cost a good penny. So I bought 2 junkyard fans and made my own mounts. I think it came out very well.
https://static1.pt-content.com/images/pt/2009/06/100_4187-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4188-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4189-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4190-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4191-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4195-1.jpg
The Stickman
06-14-2009, 08:41 PM
Very short update. I got the trans cooler on. I will actually be running two The cylinder heatsink one plus this Perma Cool one with the fan on it. I think this one wll not only help keep the trans temp down. Not sure it was high to begin with but now that the trans is built up I don't want to take any chances. But it should also help with keeping the engine temps down due to the extra fan. I also got some work done to the fan shroud for on top of the radiator. But it's not quite finished.
https://static1.pt-content.com/images/pt/2009/06/100_4207-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4208-1.jpg
The Stickman
06-19-2009, 08:50 AM
Ok here is the top shroud I made for the new radiator. It needs to be polished but it looks pretty good I think. I may need to move the fans a bit closer to the rad but I'm not sure at this point.
https://static1.pt-content.com/images/pt/2009/06/100_4217-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4215-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4216-1.jpg
hechtrod
06-19-2009, 11:46 AM
That shroud looks good. How about flat black? :)
I like your satin paint. what did you end up using?
The Stickman
06-24-2009, 04:57 PM
I didn't paint the car but Rustoleum Black Satin is a perfect match.
The Stickman
06-24-2009, 04:58 PM
I thought about it but not sure how the paint will stick to it.
The Stickman
06-24-2009, 05:02 PM
FINALLY!!!!! I have all 4 seats in and mounted. Finally. And I have to say it makes the interior look great. I still need to put new carpet in and fix the headliner as well as other things but the seats and the way they are in the car really look cool. It has a theater style arrangement.
https://static1.pt-content.com/images/pt/2009/06/100_4261-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4260-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4264-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4259-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4262-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4263-1.jpg
https://static1.pt-content.com/images/pt/2009/06/100_4266-1.jpg
srh3trinity
06-24-2009, 05:48 PM
Cool seats, what brand are they? That shifter gets cooler every time I look at it.
NOT A TA
06-24-2009, 05:58 PM
4 Seats!!!! Stick thats awesome! You can take people on tours like Sabine does at the Nurbergring!!!!
Tom Welch
06-24-2009, 08:17 PM
This is my kind of build, all done on your own, (with help) cant leave out your wifes contrbution! and a different kinf of car being built. I really dig it.
The Stickman
06-25-2009, 06:01 AM
They are MCR's I believe. I paid $200 a pair. The place was pretty local so I went to pick them up.
BTW thanx for all the comments giys.
The Stickman
06-25-2009, 06:03 AM
How cool would it be to take this wagon on the Nurbergring? I was there once but the weather was so bad you couldn't drive the track. But they have one hell of a museum. Mostly bikes though. And no I didn't get to take any pics, darn it.
twosaturns
06-25-2009, 06:39 AM
what ideas do you have for the door panels? the old fogey crushed velvet fake wood look just isn't cuttin it anymore :)
The Stickman
06-25-2009, 07:18 PM
I am thinking of doing the whole interior over in gray and black. The doorpanels wil be stripped and fiberglassed, then covered in tweed I think. I am considering some kind of cage so I can mount proper belts.
1971CHEVELLE
06-26-2009, 04:58 AM
awesome project:1st: cool seats
The Stickman
08-18-2009, 07:21 PM
Ok time for a tiny update as I haven't done much. But I did a very simple cheap mod that I thought I should pass on. I thought the rear sat a touch higher than I liked and someone from another forum let me in on a secret. Seems G-Body rear springs work in a B-Body and lower it quite nicely. It gave me anoth inch drop over my Eibachs. Not only that but it slightly softened up the ride on the front suspension. I thought they would be too weak to hold the rear up and not bounce. But it worked quite nicely. Still have to see how it corners but the ride seems great.
shizzy
08-18-2009, 07:52 PM
L O V E the project.
L O V E wagons
Is the wood grain going to go from the interior? I think it pulls the car back in to the 80's a little. Maybe brushed aluminum or CF in its place?
The Stickman
09-06-2009, 09:08 AM
Well I finally put my Rocket Racing valve covers on. They are way heavy though which I hate but they do look good. They will probably go on the wife's car when we get an Olds engine for her car. Do mind the fact that they are all spotted, and the plug wires are all over the place. I took the pics after my carb fire.
https://static1.pt-content.com/images/pt/2009/09/100_5093-1.jpg
https://static1.pt-content.com/images/pt/2009/09/100_5097-1.jpg
https://static1.pt-content.com/images/pt/2009/09/100_5094-1.jpg
twosaturns
09-06-2009, 04:45 PM
hey stickman, I saw your car again, a few weeks ago up in Forks. one of these days I'll stop to say hi.
The Stickman
09-06-2009, 09:44 PM
Might be a bit now till I fix the parts damaged in the engine fire.
Dragonsnake
09-07-2009, 02:41 PM
Just found this thread,and just read it.What a great project:1st:.Using one of the cars not mentioned in road racing terms,makes it even cooler.And the suspension is waaay beter than all camaros and firebirds got originally.
Sorry to hear you have had a engine fire.Lost much goodies??
The Stickman
09-07-2009, 06:08 PM
The carb needs to be rebuilt. But the intake that was on it had to come off to be sent out to have it set-up for EFI, so that part is ok. it's the making sure the water is out of everywhere that is the real pain. That and the temp intake that was going to go on has super small ports for vacuum so they need to be drilled and tapped so that sucks. But hopefully I will be on my way to EFI so things should get better.
The Stickman
09-18-2009, 12:34 PM
Well I am bored and my carb won't be done till monday so I figured why not get something done. SO I worked on getting some of the paint off of my aluminum hood. Take a look and judge for yourselves.
https://static1.pt-content.com/images/pt/2009/09/100_5100-1.jpg
To bad I am light sensitive so I couldn't drive with it stripped. It would probably blind anyone. Now this hood is 5 foot by 5 1/2 foot but is seriously lightweight. As are the hinges. These I will leave polished
https://static1.pt-content.com/images/pt/2009/09/100_5102-1.jpg
When My car is running again I think I'll throw the hood on and see what she weighs.
The Stickman
12-18-2009, 05:06 PM
Well Christmas came early this year for me. My new swaybars arrived today. They are made by Hellwig and the front bar is from the catalog but the rear bar is a custom bend based of the old Herb Adams design but is special for the B-Body wagons. The front bar is 1 5/16th and the rear bar is 1 1/2 inches. Here are some comparison pics of the bars that were on it and the new ones. These are the rears.
https://static1.pt-content.com/images/pt/2009/12/100_5395-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5397-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5399-1.jpg
And the fronts
https://static1.pt-content.com/images/pt/2009/12/100_5400-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5402-1.jpg
And I had to install them right away. Here are some shots of the rear while it was still up in the air.
https://static1.pt-content.com/images/pt/2009/12/100_5403-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5404-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5405-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5406-1.jpg
And the front.
https://static1.pt-content.com/images/pt/2009/12/100_5409-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5411-1.jpg
The rear on the ground.
https://static1.pt-content.com/images/pt/2009/12/100_5412-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5414-1.jpg
HotRodKush
12-18-2009, 05:17 PM
This is an awesome project, I love wagons. Maybe I missed it, but are those control arms aluminum?
NOT A TA
12-18-2009, 06:00 PM
The bars look good stick! That rear one is burley!
The Stickman
12-18-2009, 08:27 PM
Yea the rear lower control arms are Metco billet aluminum ones. Almost to pretty to put on the car. There should be a post somewhere in this thread about them.
The Stickman
You have no idea. That rear bar is wicked heavy.
jackfrost
12-22-2009, 07:40 AM
so did you get to drive it w/ the new bars yet?
The Stickman
12-22-2009, 01:09 PM
Looky what I just got in the mail. It's a new MegaSquirt II v3.57 with wiring pigtail. I am so excited. I have been looking at their site and some of the info and videos and it seems like this will be a fairly easy conversion. Now I just need to clean up my intake to get it sent off to have the bungs welded on and drilled out for injectors and the fuel rails put on.
https://static1.pt-content.com/images/pt/2009/12/100_5419-1.jpg
https://static1.pt-content.com/images/pt/2009/12/100_5418-1.jpg
The Stickman
12-22-2009, 01:11 PM
No unfortunately. The car will probably be down for a the winter. See my new update and you will understand why. Right now the tank is empty and it needs wheel bearings as well so no sense getting her all filled and fixed just to have to drain the tank and take it all apart again.
Smock67
12-22-2009, 05:24 PM
I just read through this whole thread. I have got to say your wagon is sick I love that is out there and the low budget aspect.
amargari
12-23-2009, 02:03 PM
Just read the thread. Very cool project. I would like to see the installation of the Megasquirt system.
critter
12-23-2009, 04:05 PM
Good to see the MS unit in hand, Stick. I'll let you figure it out and then pick your brain over in chat one day soon. Keep on rolling with wagon!
The Stickman
12-24-2009, 09:18 AM
Thanx. It is a lowbuck build for sure. But it will still perform just as good. It is really getting there, thanx for the comments.
The Stickman
12-24-2009, 09:28 AM
Critter not sure anyone will be on chat this week or next. But The MegaSquirt looks easier than I thought. The wiring pigtail has all the wires stenciled with what they are for. There is a good video that walks you thru some of the startup steps. I still have to clean up my intake to send it off. I bought it used and it was painted so I need to get all that off and will take the sand cast finish off for more of a polished look. I have the cash to send it off so as soon as I get it done I will ship it off. Then I need to get a tank with the fuel pump in it and some fuel line to run new feed and return lines. But wiring it won't be as bad as I thought. I will do a full write up and maybe some videos of it.
Roadbuster
12-24-2009, 10:37 AM
Don't know if I can make the chat tonight, but I would definitely like to hear your opinion of the MegaSquirt. I have looked at that as an upgrade to my GTO.
Love how you are adapting and modifying what you need to make it work for this car. Wagons can really be a sleeper and surprise people. I would love to see the expression on peoples faces when you take this out to an autocross course!
Jon
critter
12-24-2009, 10:40 AM
You notice I said "in chat one day soon". I doubt I'll be around chatting either. Besides, next week I'm hoping to be stuffing that 4L80e in the car and hooking up the paddle shifters. ;)
The Stickman
02-23-2010, 08:22 PM
Well I bought the wife a new shifter like mine and one of the new features that are availible for these shifters is a lighted top plate. Well I decided I needed on to so I had him make me one up too. I have yet to install it but here it is.
https://static1.pt-content.com/images/pt/2010/02/100_5589-1.jpg
Pretty cool huh?
RKHiPerformance
03-09-2010, 12:31 PM
Great build...Cool car and very well documented.
Is it necessary to use the sway bar spacers with the aftermarket rear sway bar?
The Stickman
03-10-2010, 09:34 AM
Thanx, and to answer your question Kinda. See when the ends of the bar were squashed flat there is a little bend or bulge that keeps the bar from sitting completely flat against the LCA. Now I could have used a slightly longer bolt but I didn't like that empty space between he bar and the LCA. Probably an irrational fear but I thought it might create stresses there. So I flipped the bar and used the spacers. The reason for flipping the bar was it cut down on the distance of the bar away from the LCA when using the spacers.
youngdeezy
03-15-2010, 11:16 AM
nice build bro, i just checked everything out and i dont see to many of these wagons with the type mods you have so props for that. do you have any install pics of the overdead console. what did you use to get it to stick to the roof and did you get the compass and thermostat to work with it? thanks man you can pm me if you dont want to post answers here
The Stickman
03-15-2010, 01:17 PM
Sorry about not responding to your PM I just forgot which is a huge problem of mine. I don't have any install pics of it. I simply drilled 2 holes one front and one rear to hold it on and used screws to hold it on. But like the dolt I am I used to long a screw in the back one and dimpled my roof. I did hook the 2 lights up to the dome light but there are more than a few wires to make them light up. Just have to go through thme and figure it out. I did try getting all the other stuff working but never hooked it up. The compass seems to just need power. The thermostat needs a sensor which I don't have. I didn't feel like running a power wire up to the compass just to have it work. I will be taking it down as I have to add some plastic to the side as it doesn't quite contour to the headliner. Maybe then I will make everything work better.
youngdeezy
03-15-2010, 02:34 PM
thanks bro and no worries about the pm. anyway i have sensor part # i'll share with you. autozone.com # SU1405 or the oem# 15971127
The Stickman
06-10-2010, 05:21 PM
Well time for an update. I had a water pump go and used this as an excuse to do some upgrades. I added some aftermarket fans, an stainless resivior and a better fan controller. Now I hoped to save some weight with these upgrades but with the water pump going it forced my hand. See I was running an Aluminum water pump that came with the engine I bought off Ebay. But when it came time to change it I had a hard time spending a $100 more just to go aluminum. Now the cast iron pump is 5 lbs heavier than the aluminum one. But the fans I was using were stock GM ones without the shrounds with my own custom mounts. Well the new fatermarket fans would have saved me 5lbs but since that got added back on with the cast pump It's a wash so to speak. But it does look cleaner and I think it will cool better.
https://static1.pt-content.com/images/pt/2010/06/100_6775-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_6776-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_6773-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_6772-1.jpg
jackfrost
06-11-2010, 09:24 AM
lookin' good, Neil. you'll probably want to come up with some sort of shroud, though. it'll make your fans a LOT more effective.
do you have a target of getting her back on the road?
Motown 454
06-11-2010, 11:05 AM
It looks good, where did you get the overflow tank.
The Stickman
06-12-2010, 02:16 AM
I was thinking of making one but this seems to work really well. You can sure feel the heat coming off fans.
The Stickman
06-12-2010, 02:17 AM
I bought it off of Ebay. It wasn't that much either.
The Stickman
06-23-2010, 06:52 PM
Well I think I got my cooling issue fixed. And while I was at it I finally got the new magnesium valvecovers on. I was super worried drilling into these things. I have heard horror stories when working with magnesium. Then to top it off I thing some got in my eye and I am still freaked from getting metal in my eye the last time. That and the tops of the valvecover are kinda thick so getting grommets to fit is a pain. I hope the PCV one stays in. But I finally found my oil leak. There is a puddle under the distributor behind the intake. The rear of the intake must be leaking. Anyway here are the pics.
https://static1.pt-content.com/images/pt/2010/06/100_7126-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_7127-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_7128-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_7129-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_7130-1.jpg
https://static1.pt-content.com/images/pt/2010/06/100_7131-1.jpg
Scott Parkhurst
06-24-2010, 06:22 AM
Lookin' good man-
Keep working the bugs out and she'll be right as rain soon.
Can't wait to see how the EFi works for ya!
srh3trinity
06-24-2010, 07:17 AM
Nice valve covers!
critter
06-24-2010, 07:53 AM
I like it, Stick. Chat tonight so you can tell us in detail what it took to drill those suckers.
FRENCHBLUE72
11-08-2010, 05:38 PM
Just read your whole thread and i have to say very nice work on a car that is often over looked..
The Stickman
02-08-2011, 01:56 PM
Minor update. Today I have started taking things apart as I want to swap intakes and have to replace the water pump. So while I have the front of the engine apart I am toying with mounting the altenator on the passenger side. It might really come out well. I also looked at the underside of the rear of the car to see about making a diffuser and came up with some really nice ideas. I also weighed the aluminum hood, hinges and springs. The hood weighs 26lbs and the hinges and springs another 4lbs for a total of 30 lbs.
sr73bu
02-08-2011, 03:47 PM
Cool wagon! its nice to see everyone getting their cars ready for RTTS. see ya there! Good Luck!
-Sean
tommycomfort
02-09-2011, 03:58 AM
Always good to see a long roof! Excellent!
Tom
LV42DAY
03-05-2011, 11:14 PM
neil, do you still plan on using the air cleaner? i didnt see it today. i always thought that those were custom made. i would have gotten one a long time ago had i known they are an actual production part.
The Stickman
03-06-2011, 09:15 AM
The big round one in the pic above? It was on the bench somewhere. Goona try and do up a cold air intake. Have a nice airhat I want to use. That round one pictured up a few posts has some scratching on the lid from rubbing the hood. But if I get the cold air intake done you can have it if you want.
LV42DAY
03-06-2011, 06:47 PM
i was talking about the olds batwing air cleaner. i love those. ive seen thoem in hot rods and thought they were custom made. i tried searching for one for a while and came up with nothing so i gave up on them. i had no idea that caddy and olds made them.
The Stickman
03-06-2011, 06:52 PM
Nope the Batwing has been gone awhile now. There are repops on ebay which is where I got mine.
The Stickman
03-08-2011, 03:08 PM
Ok minor update. Took some more pics today. We will start off with some that posted in the diffuser thread. Here is the untouched bumper.
https://static1.pt-content.com/images/pt/2011/02/001-1.jpg
And one side done to show the difference between the 2 sides.
https://static1.pt-content.com/images/pt/2011/02/002-1.jpg
And both sides done.
https://static1.pt-content.com/images/pt/2011/02/003-2.jpg
Over the weekend with the help of my wife and LV2DAY who stopped over(Thanx for the help btw) we got it mounted. It's not quite as close to the body as I would like but I think it looks good. Yea I know it needs paint. It's all scracted up from taking it on and off and laying on the floor.
https://static1.pt-content.com/images/pt/2011/03/100_8090-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8091-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8093-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8095-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8096-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8097-1.jpg
critter
03-08-2011, 06:02 PM
Yeah, it's getting there.
LV42DAY
03-08-2011, 07:34 PM
it was fun hanging out, thanks for having me. your wife has some serious welding skills. i'm hoping she could knock out a few thing i'm looking to get done on the camaro or maybe even teach me so i can do my own work.
The Stickman
03-08-2011, 07:51 PM
Here are some engine pics. The Holley Street Dominator is out and the Edelbrack Perfromer RPM is in. And Here is the air hat I am going to use. Believe it's a Spectre.
https://static1.pt-content.com/images/pt/2011/03/100_8100-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100b8160-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8101-1.jpg
Six_Shooter
03-08-2011, 08:45 PM
What happened to going EFI?
The Stickman
03-08-2011, 08:49 PM
Still in the plans. Just no idea when. I have the computer, harness, injectors, TB, and intake that needs to be converted. So I still need a tank, run fuel lines, and some sensors.
The Stickman
03-09-2011, 11:57 AM
OK got some new parts today. It was a sugggested mod by Yelcamino so thanx to him for the idea and info. Should be a much better system than just a PCV and breather. I had a could instnces of oil in the breather so this should fix that. It's a Moroso catch can/breather, AN fittings, hose, and an AN bulkhead fitting to mount to the valve cover. It all looks very cool and hopefully it helps.
https://static1.pt-content.com/images/pt/2011/03/100_8161-1.jpg
twosaturns
03-09-2011, 04:52 PM
Neil, I passed you going the other way on 13th street by the silk mill a few weeks ago, maybe I'll get to see your wagon up close sometime!
Keith
LV42DAY
03-11-2011, 07:44 PM
i been thinking about doing something similiar. im tired of my breather spitting up on the valve covers. getting tired of wiping them down when i hit the streets. I'll wait and see how yours turns out.
hey keith, looks like we got another local :)
The Stickman
03-11-2011, 07:48 PM
Yea it's a nice set-up but the price of AN 12 fittings will give you a heart attack. I sunk a ton of cash today on parts and a helmet. Should be around all weekend working on the car provided my head is ok if any of the ever growing Lehigh Valley crew wants to show up.
The Stickman
03-14-2011, 03:26 PM
Ok got a few thigs done today. Got my second diffuser tunnel done but made the dumb mistake of not trimming it down like the first one. So tomorrow I have to cut it apart. I also got the Moroso catch can mounted. Might add some small braces under the mount as it flexs some. Also got the bulkhead fitting mounted to the valve cover. This should look pretty nice.
https://static1.pt-content.com/images/pt/2011/03/100_8173-1.jpg
I also worked on my passenger side altenator mount. It is very sturdy. I can get it lined up with the center groove of the 3 groove pulleys. I need to get the power steering pump with the 2 groove pullies out tomorrow. But things are looking good.
https://static1.pt-content.com/images/pt/2011/03/100_8175-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8177-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8180-1.jpg
The Stickman
03-15-2011, 02:19 PM
Ok time for an update. My relocated altenator is almost done. I had to switch crank and water pump pullies as well as switching to a power steering box with 2 droove pulley. Only thing taht is really a problem is my oil fill tube. the aluminum rod I am using as a brace is in the way.
https://static1.pt-content.com/images/pt/2011/03/100_8183-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8185-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8186-1.jpg
I am also getting alot done on the diffuser. Both tunnels are pretty much done. they will simply need a final trimming and clean up. But for now they can stay like they are until I can mount them so I can make a center section to join them. At that point it will be one large piece that can come in and out as needed. I am really liking this look.
https://static1.pt-content.com/images/pt/2011/03/100_8187-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8188-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8193-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8191-1.jpg
critter
03-15-2011, 05:29 PM
Wow! Check out the tail feathers on that one! :)
Motown 454
03-15-2011, 09:13 PM
Nice progress, Its looking good.
wallaka
03-16-2011, 11:11 AM
That's pretty cool. Doing an undertray, splitter, and all too?
The Stickman
03-17-2011, 06:46 AM
Yea I am planning on an airdam and splitter and the splitter would go back all the way to the radiator support. After reading this article.
http://www.autospeed.com.au/cms/A_2455/article.html
http://www.autospeed.com.au/cms/A_2456/article.html
I am convinced atleast front belly pan is a must have. I have more parts from yesterday that need to be installed today. A set of wire braided brake hoses, HD U-joints, Spal temp switch, and a power steering hose. Also hope to get much more done.
The Stickman
03-18-2011, 04:22 PM
Small update. I got the braided performance hoses from Inline Tube on. The rear one was a pain to get in. Plus I had to put a new hard line in as the one that went to the rear hose twisted and crimped on me. Also worked on my diffuser some. I have the center [panel done. Hope to have the 2 tunnels and center sections joined by the end of the weekend. By tomorrow if all goes well. So should be all mounted. Also took some paint off the aluminum hood. Hope to have it painted by the end of the weekend. The 2 groove power steering pump is mounted and has a new hose on the high pressure side. I recieved my race pads from Porterfield. I have R4's for the front and R4D shoes for the rear. They were very helpful and quick as was inline tube. The Spal temp switch is mounted but not wired yet. Also working on a new dash panel. Might be able to unveil it by the end of the weekend. Still need to make a hose for the catch can now that I think about it too.
critter
03-18-2011, 04:36 PM
Looks like RTTS has someone motivated! Go Stickman!
The Stickman
03-18-2011, 04:45 PM
Heck yea it does. I needed this so bad. Lately nothing has gone easy but for the most part I haven't cared that it isn't easy. Just like being outside in the nice weather with my car. I do wish I was a bit neater though. Garage is a mess.
The Stickman
03-19-2011, 04:58 PM
Ok here is what got done today. Worked on the diffuser. Had to weld up the license plate holder. It doesn't come straight across so we fixed that.
https://static1.pt-content.com/images/pt/2011/03/100_8199-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8202-1.jpg
Oh and my welder cleaning up her welds lol.
https://static1.pt-content.com/images/pt/2011/03/100_8201-1.jpg
Finally real progress. One tunnel mounted with Dzus fasteners for easy removal.
https://static1.pt-content.com/images/pt/2011/03/100_8203-1.jpg
And both tunnels and center section mounted.
https://static1.pt-content.com/images/pt/2011/03/100_8206-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8208-1.jpg
Now all three sections need to be glassed together. And there is still alot of trimming and prettying up to be done. But I think it looks great. Not sure if I can get away with leaving the tunnels that deep. Also not sure about leaving them that far off the bumper. I kinda like it that way as it has a European Touring car look. Will have to see.
The Stickman
03-20-2011, 01:38 PM
Ok another long day. Spent the day fiddling with the diffuser. I also made a hose for the catch can. Looked at how I am gonna mount my camera. And then at the end of the day I went to do a leak check on all the brake hoses I installed plus the spot where I had to replace a brake line. Well they all looked ok. There was some moisture but could have been from when I first did the swap. So I dried those spots off and had the wife pump the brakes and all looked well. So I decided time to bleed the brakes. I went around to the right rear and before I could do anything I notice the brake line going to that side has a wet spot right in the middle of it. Dry at the wheel and dry on top of the pumkin. So I rub the line to see how wet it is. AS I do that all of a sudden drops start dripping out. It was rusty inside if that spring thing that is wrapped around the line. I must have disturbed it enough to get it to leak. So in that sense it's good it happened. But sucks that now I need to replace that line and might as well do the opposite side. So more work.
The Stickman
03-21-2011, 06:18 PM
Gee another day another brake problem. I had to tackle bending lines for the rear axle where it was leaking and well the stock line must have been 35 inches and the ones the parts store have are either 30 or 40 inches. So mine are now a little longer than before and not near as pretty. but they are new and work. But that was the easy part. I went to bleed the brakes after and couldn't get the front bleeders open. I snapped one and gave up on the other and headed out to the parts store AGAIN!!! SO the car now has 2 new calipers to go with everything else new. I will clean out the other bleeders from the old calipers so I can have them as back ups.
The Stickman
03-24-2011, 11:05 AM
OK I got some stuff done already today. The new passenger side altenator mount is done. Other than the aluminum tube that needs to be redone It came out nice. The belts are all lined up and the mount is sturdy. For those of you that don't know what I am taking about Olds motors can be tempurmental about having the accessories all on one side. I took off the A/C and relocated the altenator over to the passenger side one to make sure I had no problems and two so it has a more balcanced look and feel. I used the stock drivers side aluminum mount and simply flipped it drilled a hole and sanded the back down some as well as adding the aluminum tube as an upper brace.
https://static1.pt-content.com/images/pt/2011/03/100_8214-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8215-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8216-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8217-1.jpg
Here are some pics of the diffuser after some trimming. It's starting to come together. It is by no means finished but it's getting there. I have 6 inches of clearance with it. I thought I might have to trim the bottom side but it looks like I can keep it that low.
https://static1.pt-content.com/images/pt/2011/03/100_8218-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8219-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8221-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8225-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8229-1.jpg
Things yet to do include a new dash panel for my guages and switches. I am also trying to figure out how to seal up the top of teh radiator support so all the air goes through the radiator. Still trying to decide how I want to do it. I will probably incorporate the top radiator mount with it. I also will be making new bumper mounts and if time an airdam.
The Stickman
03-25-2011, 04:08 PM
Ok I have beed told I should have some kinda radiator shroud. So I made one. Just a quickie but looks ok.
https://static1.pt-content.com/images/pt/2011/03/100_8233-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8234-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8235-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8236-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8237-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8239-1.jpg
https://static1.pt-content.com/images/pt/2011/03/100_8241-1.jpg
I also wired up my fan temp switch, lengthened the wires for my altenator to reach the other side. I hope to have her running maybe tomorrow. Also did a shakedown run of my hauler and everything seems fine.
The Stickman
04-02-2011, 05:39 PM
Blew the engine at RTTS. No regrets. Besides I got my money's worth out of that $400 engine and then some. More later when I am rested.
critter
04-02-2011, 05:43 PM
Very sorry to hear it. But at least your's died having fun. Mine crapped out just driving down the road. Time to build one bigger and better buddy.
The Stickman
04-03-2011, 03:32 PM
It died having alot of fun and will be back. Probably throw the orginal 307 back in just so it can be on the road for now. need to get some 1/2 inch thick exhaust manifold flanges made. Twins may be on the way.
The Stickman
04-03-2011, 03:51 PM
Final pics before heading out to RTTS. Here are the aluminum hood hinges and final bumper mountings. Must be VERY careful closing the hood.
https://static1.pt-content.com/images/pt/2011/04/005-1.jpg
https://static1.pt-content.com/images/pt/2011/04/001-1.jpg
https://static1.pt-content.com/images/pt/2011/04/002-1.jpg
https://static1.pt-content.com/images/pt/2011/04/004-1.jpg
https://static1.pt-content.com/images/pt/2011/04/003-1.jpg
The Stickman
04-20-2011, 08:35 AM
Well here is the next piece of the puzzle. Since my engine went at RTTS I had to figure out what to do next. And this helps me get to the next point. It's a 330 forged crank that is cut for a 3.5 stroke. So I am on my way to a 375 stroker engine.
https://static1.pt-content.com/images/pt/2011/04/100_8303-1.jpg
The Stickman
05-19-2011, 12:17 PM
Well I got my flanges in for the manifolds. Have to say they are pretty darn nice. I will be getting the weld els probably next week. So one step closer to my turbo manifolds.
https://static1.pt-content.com/images/pt/2011/05/100_8532-1.jpg
https://static1.pt-content.com/images/pt/2011/05/100_8533-1.jpg
Crestronwizard
05-19-2011, 12:55 PM
I like it!
critter
05-19-2011, 01:26 PM
Daaahm. How thick are they?
The Stickman
05-19-2011, 06:30 PM
They are 1/2 inch thick. I didn't want any sealing or warping issues due to heat.
chunger
05-19-2011, 08:50 PM
Holy stink-a-mony! I have never seen flanges that thick! How hot does an Olds run?
The Stickman
05-20-2011, 07:33 AM
Well they will be for Turbo manifolds. I look at it this way. How many times have you heard "my headers leak cause the flange to thin" And these manifolds will be supporting the turbos. Not to mention they may need to be ground flat after welding so I have more material to work with in that circumstance. I don't want to have to do this twice because I bought something that wasn't strong enough.
John Wright
05-20-2011, 07:52 AM
You could mill another 1/8" off to make sure they are true/flat ...thickest I've seen were 3/8" then you could use standard length exhaust bolts.
The Stickman
06-09-2011, 01:04 PM
Hey I actually got something done today. Since I have owned the car the passenger side rear door has never worked. Well now it does. Kinda. It will open from the inside. But I need the plastic clip that goes over the rod and into the handle for the outside to work as well. I never saw a need to fix it realy because it never got used. The reason I fixed it? Well it's time to start on the door panels. I have seen other peoples work and want to give it a try. So I took off the front passenger side panel. Stripped it down to the door card. I was going to coat it with fiberglass resin while on the car figuring that would help it hold its shape. But even then it looked wavey. So I took it off laid it on the bench and used a cylinder head to hold it down and put a layer of fiberglass cloth and resin where it was flat. when it is fully cured I will do another section. Then once I get them all done like this I will decide on how I was it to look. I would like to redesign the arm rest and make it look better. I also took a look at doing my airdam splitter. Think I have it figured out for the most part. Just have to start making all the pieces to put it together. I am going to make two noses. One for street use where the splitter will be 5 inches off the ground. And one where it will be 2 inches off the gorund for track days. I amd going to make it all a quick change arrangement where the bumper, airdam, and splitter are all one piece and can be unbolted easily from the outside.
The Stickman
06-10-2011, 04:32 PM
Look what I did today. This is just the start of the piece to fill the gap between the nose and radiator support, cover the top of the rad support, and cover and support the top of the radiator.
https://static1.pt-content.com/images/pt/2011/06/100_8622-1.jpg
I also did some more work to my door cards. I am going to have to decide how I want my door panels to look soon.
critter
06-10-2011, 05:11 PM
Cool!
NOT A TA
06-11-2011, 05:50 AM
I like the idea of being able to swap out the bumper/spoiler combos. Excellent idea!
absintheisfun
06-11-2011, 03:16 PM
What did you use to get your base in under the fiberglass?
The Stickman
06-11-2011, 03:39 PM
Simple cardboard. It really works well. The resin soaks into it making it part of the piece. Allows you to use less fiberglass and is strong if you do both sides.
The Stickman
06-13-2011, 12:44 PM
Ok I got a little more done to the radiator support cover. It is really coming along, Today I got the top part of the radiator done. There are a few spots I intentionally didn't do. I will get to them in finer detail when it's off the car. Once this sets I will remove it do some trimming and put a layer under it and then it should be plenty strong.
https://static1.pt-content.com/images/pt/2011/06/100_8623-1.jpg
https://static1.pt-content.com/images/pt/2011/06/100_8626-1.jpg
https://static1.pt-content.com/images/pt/2011/06/100_8627-1.jpg
https://static1.pt-content.com/images/pt/2011/06/100_8628-1.jpg
https://static1.pt-content.com/images/pt/2011/06/100_8629-1.jpg
Mr.VENGEANCE
06-13-2011, 01:54 PM
i like that closeout!
and i got your Qs man!.. thanks!
BulldawgMusclecars
06-14-2011, 03:21 PM
Cool thread Stickman! Love what you're doing with the wagon!
kadettcqp
06-15-2011, 02:44 AM
Really nice thread!
Could you please help me find the place where you bought those seats? I cannot seem to find them on ebay, or they hide in the millions of hits I get when searching for bucket seats.
The Stickman
06-15-2011, 03:16 AM
Really nice thread!
PM sent
FoxGranadaChuck
07-05-2011, 07:56 AM
Nice thread, Stickman!! Any more progress as of now?
I am glad that I am not the only one to recognize the fact that later GM B-Bodies make for excellent Pro-Touring machines. Terry Stevens proved that with his '77 Caprice SS!
craigs73
07-05-2011, 09:51 AM
neil where did you get the seats i know u said bay but the seller? also how comfy are they?
The Stickman
07-05-2011, 07:05 PM
Here are the seats. I think they are very comfy and have done a few hours at a time in them.
http://cgi.ebay.com/ebaymotors/2-New-MRC-Fiberglass-backed-K6-Black-Racing-Seats-_W0QQcmdZViewItemQQhashZitem3cb9b3ed54QQitemZ26081 3614420QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Racin'Z28
09-26-2011, 04:37 PM
PM sent
Hi Stick,
I just spent two hours reading this entire thread from beginning to end (including the YouTube vids) and all I can say is "wow" and you (& the wife) are truly dedicated to this build. I, along with many others, love the fact you are using the Olds wagon. Its a dare to be different project for sure.
I'm in the same boat as the previous OP. Can you please share where you got those seats? I need to get some. I only saw they were called "MCR"
Great build/thread and I'm following this one all the way through.
Racin'Z28
09-26-2011, 04:39 PM
DUHHHH, I replied too soon..
Frank ZX
11-11-2011, 04:07 AM
Just read the whole thread. Nice car. I can't wait to see it finished.
