View Full Version : Oil Pan Leak 68 camaro
zboss86
11-30-2008, 06:11 AM
My oil pan is leaking on my 68 camaro sbc...
Has anybody replaced the oil pan with the engine still in the car? Maybe I could unbolt the engine mounts and headers and raise the engine up or something to that effect.
zboss86
12-08-2008, 09:56 AM
This was either a dumb question or no body knew.
regardless...
I was able to do this by unbolting the motor mounts, transmission mount and the exhaust collectors.
I tried it first with just the motor mounts bolts. It was almost enough.
Then I unbolted the exhaust collectors and tranny mount. I was able to raise the engine another inch and the oil pan just fell out.
minendrews68
12-08-2008, 06:54 PM
I will make this suggestion. Fel Pro makes a one piece gasket for the oil pan. I have a earlier model (no ls) motor. These gaskets are considerably higher than regular pan gaskets but you've got to see them to believe them. I was lucky, I got my motor back SBC mounted it on my subframe, which was out of the car, and finished putting everything together I started it tweaked it a bit and found that I was leaking around the aftermarket chrome timing chain cover. The new one piece gasket fixed all my leaking problems. Check it out ....
zboss86
12-13-2008, 04:13 PM
You read my mind... I already have one. Great piece..
zboss86
06-07-2009, 07:36 PM
The one piece did the trick for the pan. I have so much blow by, it looks like it's time for the LS swap...
