View Full Version : 68 camaro alignment ?
130fe
02-28-2005, 06:17 PM
I installed the hotchkis front/rear spring set up on my car and haven't gotten it realigned since the changing the springs. I need to have it aligned because driving it the way it is not so fun. I have an AGR steering box with KYB shocks (bilstein in the future). I end up feeling EVERY groove/bump in the road and the steering is so sensative. I was wondering if a "stock" alignment specs will work until I can tear it down and put the guldstrand mod and/or tubular UCA's. Any info would be appreciated.
Marcus SC&C
02-28-2005, 06:34 PM
The hyper sensitive steering feel is probably due to toe (out) change caused by dropping the ride height combined with the factory bumpsteer curve. I`ll bet you`ve got some + camber now too. I`d set the toe first,at say 1/16"-1/8" in. If you`re doing the other mods very soon you can probably get away with setting the camber at 0 with a carpenters level at home. If it`s gonna be a little while you should do a full alignment. I`d shoot for -.5* camber,+5* caster and 1/16" toe in for starters. Marcus SC&C
