View Full Version : How much does a custom center console cost?
Mr Nick
11-25-2008, 05:25 AM
About how much can I expect to pay for a mild custom center console? Nothing too fancy, something like these...
https://static1.pt-content.com/images/pt/2008/11/hP1010047-1.jpg
This is my favorite, which I think is a modified 80's Camaro console.
https://static1.pt-content.com/images/pt/2008/02/0502sc_04z1969_chevrolet_chevelleinterio-1.jpg
Feel free to share any experiences you have of building your own, I'm considering that as well. However I'm a bit turned off by how much a custom console might weigh, being made of wood and all. I'd prefer to find a factory console from a different application that would work in my car.
MCC
11-25-2008, 06:12 AM
You are looking at around $ 200 to $ 400 for one like this. We just finished making molds to made a custom console out of fiberglass and carbon fiber. This console will start out at $ 750.00 and up.
Mike Riggs
Mike's Custom Cars
1-803-329-2835
www.mikescustomcars.com (http://www.mikescustomcars.com)
FULMNTE
11-25-2008, 08:44 AM
I used a bucket seat console from these guys in my 71 Monte:
www.classictruckconsoles.com
Lightweight fiberglass, easy to modify...
Pics of my installation are on their website
GetMore
11-25-2008, 05:07 PM
Some custom consoles are made out of wood, then covered with carpeting. So, you could do it cheap. You may even be able to do it yourself if you went that path.
Mr Nick
11-25-2008, 07:18 PM
Thanks for the info guys, and especially for the link FULMNTE!
trex1270
12-30-2008, 09:13 AM
Mike Riggs
Mike's Custom Cars
1-803-329-2835
do you have any pics....I may be interested
The Stickman
12-30-2008, 09:44 AM
BTW if you know how to work with fiberglass just make your own. What I am going to do it to make a the shape I want out of that styrofoam they use for home insulation. It can be shaped pretty easy. Then simply lay fiberglass over it until it gets the desired strength. Then sand smooth and either paint or cover it with some material.
724tim
12-30-2008, 10:34 AM
here is another option you might like
http://www.roddoors.com/pages/consol-dir.html
jackfrost
12-30-2008, 12:52 PM
what he said. if you can paint, you can lay fiberglass. it's not hard.
and then you can either smooth it out and paint it, or cover it with leather/vinyl and/or carpet for a stock look.
Fesler built
12-31-2008, 05:23 AM
Depends on how nice you want it and what kind of quality you want, we have built consoles from $1000 to $6000 out of steel and painted and so on. The more work that goes into them hours of shapping the more it will cost, if you go on the wood side as sugested you can do it for $500 to a grand depending on what you wrap it with and how complicated you get.
https://static1.pt-content.com/images/pt/2008/12/Img2069-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Img2064-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Img1711-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Img1665-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Img0023-1.jpg
https://static1.pt-content.com/images/pt/2008/05/Img0037-1.jpg
Takid455
12-31-2008, 11:18 AM
nice consoles, but wouldn't that steel one weight quite a bit? Was is used as a structural member as well?
Fesler built
12-31-2008, 01:45 PM
They weight less than a wood built one and will never break.
Mathius
01-07-2009, 04:51 AM
Yeah, that's an 82-92 Camaro console. All they did was use a hole saw to put some cup holders in and modify the radio plate. Looks like just a flat piece of carbon fiber or plastic fastened in place. Then they re-covered the deck lid, and put in a custom shifter. You could do most of that yourself pretty easily.
Mathius
ROBS6T8
01-07-2009, 07:02 AM
I built mine for $30.00!! With some wood left over! It was the covering that was expensive. It cost me $200 to have it covered in some nice soft black vinyl with the boot for the shifter. It also has a storage compartment in the rear between the seats and 2 cup holders behind the shifter. I've had nothing but compliments on it... saying, " it looks like it belongs there". I will try to post some pics or pm me with your email and i'll send them that way. Easy to build.
fishtail8
01-07-2009, 09:32 AM
Any more pics of the console in the red car above? I like how they worked around the shifter and would like a bit of a closer look...
