Malibu Jax
11-17-2008, 12:46 PM
Ok, I just got off the phone with Jesse at wait4me and am really confused. I have a LS1/4L60E that I put in my 1979 Malibu with a painless 18 circuit interior fuse block. The computer has a park/neutral position switch wire that needs a ground signal when in park or neutral. I have a B&M megashifter that has a switch that has the keyed hot (12gauge purple) that completes the circuit when in park or neutral and interrupts it when in gear or reverse. Jesse tells me that I need a relay for that switch, but I checked the B&M and Painless directions and nether has anything like this listed. I have it hooked up by both manufacturers instructions to a tee. Jesse then tells me that I need the park neutral hooked up from the computer in order for the computer to shift right.
I don't understand how to hook this up due to the switch being a interupt for the keyed hot and where would the ground signal come from with my setup?
I also don't understand why the computer would need this to shift right since the neutral safty switch is there so you cannot start the car in drive or reverse. Any help would be appreciated.
