View Full Version : Which heater hose is IN and OUT??
skeeters65
11-17-2008, 11:02 AM
2002 F-Body LS1
Which hose off the water pump is the IN and OUT??
Also which is the IN and OUT on the Heater Core? 69 Camaro small block non-A/C heater core??
Also can I just loop the 2 on the Water pump just for initial start up??
parsonsj
11-17-2008, 11:53 AM
Small diameter is from the pump. Bigger diameter is the return hose.
I think the heater core is the same way.
Yes, looping on the water pump is fine for initial startup.
jp
CarlC
11-17-2008, 01:03 PM
Can't screw it up. Hook the 3/4" heater core hose to the larger outlet on the pump. Hook up the 5/8" to the smaller.
